Question about Dell V305w All-In-One R840635AU InkJet Printer
Disassemble v305w printer
Need to remove cover as I have power connection problem
  • Brian Staples Nov 06, 2012
    As there were no replies to my question I assume nobody had any valid suggestions,so I have now thrown the printer away.
What is the IP address for my printer v305w i'am trying to connect it to my iphone
the DHCP supplied ip address currently assigned to the printer can be found by going into the network settings of the DELL Toolbox software.
Jan 25, 2013 | Dell V305w All-In-One R840635AU InkJet...
Dell v305w shadow printing
Hi
Try re-installing the black cartridges.
Also check them for possible clogging.
Feb 19, 2012 | Dell V305w All-In-One InkJet Printer
My dell v305w wont power up
If you have tried plugging it in to a different power outlet or used a different power cable and the issue is still the same then it can be a major hardware issue. You can call Dell Technical Support so that they can just replace the printer if its still under warranty.
Hope this helps
Thanks
Dennis
Oct 27, 2011 | Dell V305w All-In-One R840635AU InkJet...
How do i remove the ink cartrige
while the printer is plugged in and power on, you open the cover and should see the cartridge
Feb 03, 2011 | Dell V305w All-In-One R840635AU InkJet...
My dell V305w printer has a 'carrier jam' I cannot seem to be able to get it going after I replaced the B/W cartridge
The easiest way to attempt to free a stuck carriage is to try to move it yourself. Open the printer's cover such that the carrier will attempt to move in a maintenance-friendly position, where you'd easily be able to get at the print cartridges. After opening the cover, unplug the printer's power. Now look for the little belt with gear teeth on it that moves the carrier back and forth. Give it a gentle tug and see if you can get the carrier to move. Even if the carrier doesn't move, or it moves into a strange position, plug the printer back in to power (after removing your hands and everything else from inside of course) and close the cover. Turn it on if necessary, and it might just take care of itself. Do note that you may get some ink on your hands when you reach inside the printer, and that you're working at your own risk.
Jan 16, 2011 | Dell Office Equipment & Supplies
Recommended printer port for v305w in vista
If you connecting it through USB cable try COM1, COM2 and COM3...If you connecting it through Serial/Parallel cable use LPT ports.
For more help stay connected with us.
Thank you.
Good Luck
Aug 17, 2010 | Dell V305w All-In-One R840635AU InkJet...
Im trying to connect a dell v305 printer to a new mac
NO Dell do NOT support Macs on there printers - BUT most of Dells printers are re-branded Lexmark engines - so if you can find the equivalent lexmark - you may find a driver lexmark makes all of dells printers the v305 or v305w is a lexmark model X4650. the Mac driver is here http://support.lexmark.com/index?page=content&productCode=LEXMARK_X4650&actp=PRODUCT&id=DR9768&segment=DOWNLOAD&userlocale=EN_US&locale=en
Apr 11, 2010 | Dell V305w All-In-One R840635AU InkJet...
I own a Dell V305w and have it wirelessly connected to my dell inspiron windows 7 pc. Prior to installing windows7 it worked beautifully right after I installed windows 7... NOTHING... I've updated...
If it is connected wirelessly, the computer needs to see it as a network printer. If it sees it as a local printer, it will not be able to print.
In addition to your print queue, make sure the Spooler service is running.
Nov 26, 2009 | Dell V305w All-In-One R840635AU InkJet...
The Printer cannot communicate with the computer.
you need to reinstall the printer driver follow this steps.
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Sep 18, 2009 | Dell V305w All-In-One R840635AU InkJet...
Dell V305w All-In-One R840635AU InkJet Printer Logo
66 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
