Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Bootmanager missing how do i get boot manager back
  • Microsoft Master
  • 27,725 Answers
The latest versions of Windows, including Vista and 7, use the Windows Boot Manager to read the boot configuration files and data in order to load your Windows Desktop.
If any of these files are corrupted or damaged, you will see a "BOOTMGR is missing" error. Fortunately, you can use a number of Windows tools to repair or replace the BOOTMGR or any related file that may be the cause of the problem.
Insert your Windows installation CD disk in your computer's CD drive and restart the computer.
Press "F8" repeatedly while the computer boots up.
This command enters the "Advance boot options" screen.
Select the "Repair my computer" option and then press "Enter."
The System Recovery Options screen opens.
Select the "Startup Repair" option at the top of the list and click "Next."
The utility will scan your system for the cause of the BOOTMGR problem and repair it.
Hope this helps
Posted on Oct 31, 2012
How can i fix my hp compaq mini notebook? it says bootmanager missing
This message usually indicates that the boot sector is damaged or missing. The boot sector is a region of your hard disk that contains information that is used to load your operating system. If a boot failure is detected when your PC is starting, you may receive this error message.
you can view the below article to troubleshoot.
http://support.microsoft.com/kb/2622803
Aug 02, 2012 | HP Mini 110 Netbook
Bootmanager is missing
its a file required to load OS on the PC....u need to try repairing the PC using a CD...if it fails try doing a clean install
Feb 11, 2012 | Computers & Internet
Emachine w3619 bootmanager missing
the tray can be damaged or if it is not lit at all it has no power or is corrupted..if it is just jammed ..you can try to insert a sharp object into the hole on the tray and push to manually open it and see whats the problem ..
About the boot manager ..it either has a unplugged cable in the hard disk area..and it sees no boot support ..or the operation system is corrupted and you have to reinstall it from the disk or use the recovery partition if it has one ..
Dec 17, 2011 | E-Machines Computers & Internet
Missing bootmanager
download the hiren's boot and run pc from cd then find option boot from hdd. This tool can easy repair boot problems
Nov 10, 2011 | HP TouchSmart IQ770 PC Desktop
Bootmgr is missing
Bootmanager is the "program" that makes the computer able to load operating system.
If this is missing your pc won't boot up.
To solve this issue you should use the windows installation cd and install it again
Beware not to format your hard drive otherwise you will lose all your files.
Let us know if you solved your problem
Aug 21, 2011 | Acer Computers & Internet
Windows boot manager failed to start - message - a recent hardware or software change might be the cause. I don't have a repair disc and it will not reboot. Thank You L
sorry to hear about the problem
I've used easyBCD to repair a windows boot manager, you may have to download it in another working machine, then burn it as bootable cd (using nero or similar image burning software), pop it in and when you start your computer make sure you have your cd/dvd drive unit as the first boot option so you go right into the cd ,
try the following instructions here to see if they may help, post back if you have further questions
repairing bootmanager
hope this helps
thank you!
May 16, 2011 | Advent Netbook
Bootmgr is missing
what happened is u accidentally have deleted ur bootmanager or bootloader or OS loader(all means same) file from ur computer's C drive ... what u would need is a boot loader software and u may search the web for possible solutions... u may also try to use ur recovery disc and try ur luck....
The boot manager or boot loader is what tells the computer brain what OS is loaded in ur computer and which OS to use to interact with u....
Jun 15, 2010 | Acer Aspire One AOA110-1113 Netbook
I was using windows vista on Toshiba Laptop. I got a problem on it then I try to format C: then try to install Windows XP but got a problem. When try to install XP I can get message like Stop:...
Please note before I continue on that XP can not always be placed onto a system that had Vista as some drivers and hardware will refuse to work.
You may be having an issue w/ the boot manager.
I would suggest running the windows xp recovery console this will give you a dos like screen. Once there you can do a lot w/ the system I would suggest trying to rebuild the bootmanager.
If none of this works. You should try a full not a quick format off the install screens or you can run a win98 boot disk and access the partition and format commands.
Please post your findings in as great of detail as possible.
I believe at this time the bootmanager may be confused as to if its dealing w/ visita or if its dealing w/ xp. The boot manager uses a part of the harddrive outside of normal storage to control parts of the OS loading procedures.
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 23, 2010 | Toshiba Satellite L515S4960 Notebook
Missing bootmgr
something has removed the bootmanager from your harddrive your going to need the windows cd, you can try useing the repair console to restore the bootloader, also you can try a repair install or a fresh windows install.
Mar 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
110 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
