Question about Vacuums
How remove bag on Power Devil vac
Vac for collecting fallen leaves
  • Vacuums Master
  • 18,424 Answers
Go here for manual > http://dirtdevil.com/file/247/
Posted on Oct 31, 2012
SOURCE: nutone vx550 vac problem
The vacuum is defective, if you call Nutone and tell them the probelm, they will replace it for FREE, no charge to you. CALL 888-336-6151, that is the Nutone Tech Suport line.
Posted on Oct 14, 2008
ukvacfan
  • 328 Answers
SOURCE: Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
Posted on Mar 06, 2009
VacuumRepair
  • 438 Answers
SOURCE: vac keeps shutting itself off!?
This problem is caused by the static electricity which causes the hose controls to jump back down to the off setting. I have seen this issue on several Silver Moon and Blue Moon models before.
The only way to fix this problem is to purchase a brand new, redesigned hose. The new hose can be purchased here; Miele Electric Hose Miele Part # SES 125
In fact, I'm so sure that this new hose will fix the problem to your Miele, that if you do purchase the hose from GoVacuum, we'll give you a 60 day satisfaction money back guarantee. If this hose doesn't fix your problem, you may return it to GoVacuum within 60 days for a full 100% refund, no restocking fees or shipping charges will be deducted. We'll even include a free return label you can use to return the hose to us at our expense!
If you have any questions, please feel free to send me an email, or request a clarification. I hope this helped you. If you found this solution helpful, please remember to rate this solution as helpful by clicking on the four THUMBS UP icons in the top right hand corner of this solution.
Thanks so much,
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
SOURCE: need instruction on dirt devil mop vac
I found very basic direction on eHow
Posted on Mar 20, 2010
SOURCE: Our Dirt Devil D2 bottom has no suction
Check to see if the belt needs changing.
Posted on Jul 24, 2010
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
Power devil garden vac where can I get parts for Model PDG4026
Power Devil would be a good parts availability and source to check.
Jan 11, 2015 | Vacuums
Dust shoots out the back of my shop vac...
Use collection bags or change the filter.
Jun 04, 2010 | Vacuums
Hoover windtunnel dirt finder light stays red. We've cleaned the elbow the roller the hose and have a clean bag. The vacuum is new only had it for 3 months.
I'm not sure about a 3 month old vac, I'd probably go the warranty route. However, for the older vacs thy start getting false positives. The sensor is simply a microphone hooked to a computer chip detecting sounds of dirt entering the bag.
To rig it to start working, you'll need to remove the tool accessory tray and elbow that enters the back of the vac, and attached to the bag. This will reveal the microphone at the elbow, and wire that runs into the bottom area of the vac. When on, a large amount of air comes from the bottom screw and area where the wires enter. My fix was to clean up the microphone contact points a little bit with a screwdriver, and then leave the vac running while putting in dampering in the hole at the bottom, and around the back of the elbow. Cotton balls and electrical tape at the bottom hole, and napkins around the outside of the elbow (wedged between the back of the vac assembly and elbow did the trick). The schematic for the vac is here: http<colon>//www<dot>vacsrus<dot>com/CartGenie/pg_U6485900<dot>asp
Look for micrphone.
May 12, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
The bag indicator shows full but the bag is empty
In my bag vac, I have found that when the light shows the bag is full when its not that there is something between where it sucks into the vac to where it empties into the bag...maybe cat hair, dog hair....etc. Try removing the bag and running it, this may allow the air to flow alittle faster and force out the jam. You may also try removing the bottom of the vac, usually just a few screws, and checking to see if you can see the jam. What is happening is this jam is slowing down the air flow and the vac thinks the bag is full....also check the filter where the air leaves the bag area...also look where the bag connects, sometimes trash can hang there.....good luck
Jan 28, 2010 | Hoover Vacuums
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
I need to know how to change my kirby into a blower?
Raise the light assessory on the front of the vac. Remove the roller assembly by rotating the square dial as indicated by the arrows. Then you must attach the accessory that sort of looks like a 4 inch square open box to the front of the vac where you removed the roller assembly and lock into place. Next you remove your bag assembly by unsnapping at the top of the handle to the vac, then at the base of the bag assembly you must unlock the plastic base from the metal vac unit by turning it counter clockwise and then pulling off. Finally you attach the hose assembly where you removed the bag assembly and lock into place by turning clockwise (reverse of taking off bag assembly base). Put vac in neutral and power on. Now you will blow from the hose assembly.
Apr 20, 2009 | Kirby G4 Bagged Upright Vacuum
Vacuum problem
I bought a dirtdevil 8 years ago and it's still going. As long as the motor works then you have check to see if the brushroller turns. If not then check the roller belt (take the cover apart some have screws or lock tabs on bottom panel near wheels) If the suction is low then check the vac bag, also with bag off, turn on the vac to check if air comes thru.If not the inside tube is clogged(plastic bags, small objects, ect.)Also when you open the bottom panel to check the roller belt, check the flex pipe that sucks up to the vac bag(unclogg it).
Apr 02, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
