Question about Sony Office Equipment & Supplies
My sony vedeo printer up890 prints too white
The paper is feeding good but there is no prints
4 Suggested Answers
SOURCE: HP 7350 printing goes through the motions but nothing
I had the same problem and couldn't figure it out until I found this on the web - I changed the DEP setting and now I can print just fine. Hope this helps you too!!
Julia
Source:
http://www.tech−archive.net/Archive/WinXP/microsoft.public.windowsxp.print_fax/2006−06/msg00081.html
· From: Shawn D <ShawnD@xxxxxxxxxxxxxxxxxxxxxxxxx>
· Date: Sat, 10 Jun 2006 07:40:01 −0700
I just figured out my issue. It had to do with DEP − Data Execution
Prevention. I had remembered that I was fooling around with this a couple
weeks ago and had changed it to "Turn on DEP for all programs and services
except those I select" in which I had Windows Explorer checked. I just got
done selecting the original which states "Turn on DEP for essential Windows
programs and services only", rebooted, and now I can print again to my hp
7350 printer.
The DEP can be found under control panel−>system−>Advanced Tab−>Performance
Settings−>Data Execution Prevention Tab
Hope this helps.
Posted on Mar 06, 2009
cabrooksjr
  • 13 Answers
SOURCE: Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Posted on Jun 21, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
Prints one page and jams, displays paper jam
so it does print and exit one page before it jams? if so you have something wrong with the exit sensor. if it does not feed it all the way thru it might not be feeding paper in to the machine fast enough. the feed tires might be dirty.
Sep 23, 2014 | Samsung Ml3312nd Black White Laser Printer
White streaks and double printing
Usually when a printer can't feed paper evenly anymore, it's worn out. As long as you are using fresh paper and not over or under loading the paper tray, the rollers should feed the paper ok.
Nov 24, 2013 | Office Equipment & Supplies
Paper feed won't work
Sorry no solution but I have exactly the same problem. I have tried everything mentioned in the on-line solutions. Is this problem fixable or is a service required? Thanks to anyone who can help.
May 05, 2010 | HP Officejet J5780 All-In-One InkJet...
Printing
In the print menu, you will see a Settings or Properties where you can set your paper feed as manual or auto. It looks like you have set it up for manual feed. so you have to go back to that settings and change the paper feed to auto.
Hope this will work for you.
Good luck
luciana44
May 04, 2010 | Brother MFC-6890CDW Printer
Prints have a thin white line across all the images printed. Everything else works and prints are ok outside of the thin white line running horizontal across the 5x7 prints.
  • Thermal head — generates heat; prints on paper
  • Platen — a rubber roller that feeds paper
  • Spring — applies pressure to the thermal head, causing it to contact the thermo-sensitive paper
  • Controller boards — for controlling the mechanism
I think that you may need to replace your thermal head, A line means there is a place that the head can not head or it cannot recieve data
http://www.youtube.com/watch?v=LWs74J7EfjM
How to matinence it and clean the head
Oct 21, 2009 | Sony UP DR100 Thermal Photo Printer
Printer is grinding
sounds Like a paper jam , Plus your paper feed rollers are dirty, clear any paper inside the printer, the using a cloth rag and some 409 cleaner , wipe feed rollers to remove white paper dust on rollers, and let dry, then add paper to printer and it should print.
Jul 21, 2009 | Office Equipment & Supplies
Paper not feeding through getting stuck halfway
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle white roller. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Please remove the paper access door from back of the printer and clean the white rollers inside with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust, close the paper access door. Reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 10, 2009 | Lexmark X1270 All-In-One InkJet Printer
Can not get the card to feed the printer
This printer isn't designed to take heavy paper, only office standard, and slightly heavier for smarter documents / photos. Best idea would be to print one on smart bright white paper (or desired colour), and take it to a copy shop where they can print onto card. The problem is that the thin paper will easily roll round the rollers at the back, however the thicker paper can't, and therefore jams with the rollers tickling the end of it.
Good luck, and congrats on wedding :)
Mar 14, 2009 | HP PSC 1610 All-In-One InkJet Printer
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
