Question about E-Machines eMachines Desktop PC
Bootmgr is missing and cd drive dont work
F8 wont work at all. only allows me to use f2 and f10. I can't can't do anything on computer it just has black screen and says push ctrl alt delete.
  • E-Machines Master
  • 27,725 Answers
First up check your keyboard whether ps2 or usb connected make sure all power and data leads have secure seatings or even try another keyboard
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Insert your Windows XP installation CD or recovery disc, and restart the computer.
Instead of attempting to boot Windows as it normally would, the computer will give you an option to boot from the CD.
Press a key when prompted, then wait for the setup program to load.
Press the "R" key on the "Welcome to Setup" screen.
This will cause the CD to launch the Recovery Console instead of attempting to install Windows XP on your computer.
If you have an administrator password on your copy of XP, then you will need to enter it in order to log in to the Recovery Console.
Choose the installation of Windows XP that you want to repair (generally the only option). Wait for the command prompt to appear, then enter "fixmbr." Press "y" when prompted to let the FixMBR utility overwrite the corrupted bootloader with a new copy.
Remove your XP disc or recovery disc, then type "exit" into the command prompt.
The exit command should cause the computer to reboot, allowing the computer to load the new bootloader file and then continue Windows XP startup as normal.
Hope this helps
Posted on Oct 31, 2012
3 Suggested Answers
sayedmohu
  • 633 Answers
SOURCE: BootMGR is missing Ctrl +Alt+Delete to restart
You will have to repair your operating system or do a complete system recovery.
Posted on May 31, 2010
savers2008
  • 286 Answers
SOURCE: My emachine e250 saying bootmgr
Its sounds to me as you may have to re-install O/S
hope this helps.
Posted on Apr 08, 2011
Boot menu cant working
Press DEL to get to your bios options then disable fast boot. This will allow you to hit the appropriate key to enter the boot menu.
Mar 30, 2014 | Lenovo Computers & Internet
How can i get past an error reading BOOTMGR is missing?
Hi.
To recover the system from the hidden partition follow the instructions below.
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the left Alt, and the F10 keys.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the Acer eRecovery Management application has loaded, select your restore type.
  5. Read the notice, and then click Next when you are ready.
  6. Click Next to begin the restore process. The restore can take anywhere fom 10 minutes up to an hour.
  7. Once the restore is complete your computer will reboot. Upon rebooting it will load Windows and start installing your drivers and software. Your computer will reboot several times during this process. After everything is complete your computer will be like it was when you first purchased it.
Regards.
Feb 04, 2013 | Acer Aspire Computers & Internet
Cd no boot record
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error.
also make sure you have set it boot from you hard drive in BIOS
Restart your computer and enter BIOS mode.
On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on.
Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it.
Once you've selected your desired options, continue to boot.
Hope this helps.
Nov 19, 2012 | Computers & Internet
BOOTMANAGER IS MISSING
make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
The latest versions of Windows, including Vista and 7, use the Windows Boot Manager to read the boot configuration files and data in order to load your Windows Desktop.
If any of these files are corrupted or damaged, you will see a "BOOTMGR is missing" error. Fortunately, you can use a number of Windows tools to repair or replace the BOOTMGR or any related file that may be the cause of the problem.
Insert your Windows installation CD disk in your computer's CD drive and restart the computer.
Press "F8" repeatedly while the computer boots up.
This command enters the "Advance boot options" screen.
Select the "Repair my computer" option and then press "Enter."
The System Recovery Options screen opens.
Select the "Startup Repair" option at the top of the list and click "Next."
The utility will scan your system for the cause of the BOOTMGR problem and repair it.
Hope this helps
Oct 30, 2012 | Computers & Internet
Sony f series missing BOOTMGR
Bootmgr is missing - Vista, Windows 7
Go to this WEB site for instructions to fix this problem
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
Jul 21, 2012 | Acer Aspire Computers & Internet
I NEED TO INSTALL NEW OS ,BUT CAN'T CHANGE PRIORITY CD DRIVE ,THERE ARE PASSWORD PROTECT ,AND I TRY TO PRESS CTRL+ESC OR DEL+ F2 ALSO SHOW SHORTLY AND APPEAR BOOTMGR MISSING MESSAGE ,I HAV
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html
CmosPwd - Cmos password recovery tools
http://www.syschat.com/download121.html&act=down
Good Luck!
Jun 26, 2012 | Acer ASPIRE 9410-4933 COMPATIBLE LAPTOP...
My laptop says bootmgr is missing and i dont know how to fix
First make sure that all usb devices are unplugged and remove all cd's or dvd's or sd cards etc.
If you are running Windows 7 or Vista you can try do a repair by hitting F8 while it boots and then select repair. If this does not work you will need a install disc. If you have Windows XP you will need an install CD to do a repair. I have attached a few links that may help explain in detail. Thanks for using fixya.
bootmgr-is-missing-error-while-trying-to-boot-windows-vista/">http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
May 15, 2011 | Acer Aspire 3050-1733 Notebook
Windows will not repair or load, "bootmgr not found, press ctrl-alt-delete to restart", no cd drive.....just USB
your missing the bootmgr partition ill take it you don't have a cd drive? you may have to restart teh computer and press f10 right away to get into recovery mode. i am not sure what laptop you have so if you can tell me i can give you exact details and instructions.
-Brian
Mar 25, 2011 | Computers & Internet
BOOTMGR MISSING
Bootmgr missing is a state when the system is not able to get the information about the bootable files or the OS.
This can easily be fixed by repairing the bootmgr provided you have the OS disk. You can order a recovery disk for Acer Travel mate from acer support site or if you can arrange for a installation Disk for your Operating system.
Incase you need any assistance to order an OS disk or recovery disk for your system please let me know.
Can you let me know if you are able to go to the Recovery options when you press Alt + F10 or it simply does not respond the keypress.
Please revert with your comments
Thank you for choosing Fixya
May 27, 2010 | Acer TravelMate® 8210-6245 (LXTEH06118) PC...
Operating system not working
I think you need to open it in dos Mode.. You have to restart it PRESS F8 when restart is starting And select open in command prompt ...
NOTE:You have to go BIOS option for selecting boot from USB too (To enter DOS mode you may press DEL key /F2 when booting is abt to starting or in progressing)
OR format XP using Xp cd
OR insert any boot able cd(strongly recommend that it can possible to enter in Dos MODE{Win 98 CD is ready to enter in DOS mode}) Now you can change to any Drive even USB By using command CD space drive letter
Mar 28, 2010 | Computers & Internet
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
