Question about Dell Inspiron 1525 Laptop
How to re assemble - Dell Inspiron 1525 Laptop
  • 4 more comments
  • max carson
    max carson Oct 30, 2012
    "how to re assemble"..........What?
  • Samuel Oct 30, 2012
    dell inspiron 1525 laptop, after replacing the motherboard
  • max carson
    The obvious answer, not trying to be a smartass, the same way you dis assembled it. Replaceing a motherboard in a laptop can be quite a meticulous task. If you didn't take notes/pictures of the process then , in a word, you are screwed. Someone brought a laptop to me in a box they had disassembled and ask if I could fix it. I declined. It was a jumbled box of componets and misc. screws. GOOD LUCK
    Similar situation for me. A friend brought me the bag of stuff and said he gave up, and if I could assemble it, I could have it.
  • max carson
    Is that the laptop your working on?
  • Samuel Oct 31, 2012
    yes
  • Dell Master
  • 7,627 Answers
My friend, There is and old saying, " you have a rough row to hoe".
With patience and some online how-to videos on how-to remove/replace a laptop (insert your model) motherboard if you are meticulous and fastidious it can be done. I would rather slam my fingers in a car door, but that's just me. GOOD LUCK.
Posted on Oct 31, 2012
    I'll send an ice pack for your fingers, I'm going in.....
  • max carson
    max carson Oct 31, 2012
    Lots of time,coffee and patience. May be leave out the coffee. Let me know how it goes. I'll send the "Men in the White Coats" if need be.
How do i replace the heater core 1997 isuzu hombre
See me at website for images can only send one through this channel. www.autorepairhelp.us
Best Regards,
Master Tech Lee
HEATER BOX SHIELD
Heater Box Heat Shield
Remove or Disconnect
1. Fasteners that retain heat shield to heater box assembly.
Image [ Heater Box Heat Shield
Install or Connect
1.Fasteners that retain heat shield to heater box assembly.
Tighten
-Bolts Screws to 2.2 N.m (25 lb in).
HEATER ASSEMBLY
Image ' Heater Hoses
Image ' A/C Evaporator Tube Assembly
Image ' Evaporator Core
Image ' Evaporator Core Assembly
Image ' Heater Assembly
1.Engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
2.Heater hoses. Refer to Heater Hoses.
3.Instrument panel. Refer to Instrument Panel Replacement in Interior Trim.
4.Air inlet assembly. Refer to Air Inlet Assembly Replacement.
5.Vacuum lines.
Important
-Clearly label vacuum line connections.
6.Heater assembly studs inside engine bay.
7.Blower motor resistor. Refer to Blower Motor Resistor.
8.Stud inside heater core housing.
-Stud is revealed by removing the blower motor resistor.
9.Rear case screws.
10.Heater assembly.
11.Seals.
Imagt
Imagt
Imagt
Imagt
Imagt
Heater Hoses
Evaporator Core
Heater Assembly
Install or Connect
1.Seals.
2.Heater assembly.
3.Rear case screws.
4.Stud inside heater core housing.
Tighten
-Stud to 1.9 N.m (17 lb in).
5.Blower motor resistor. Refer to Blower Motor Resistor.
Tighten
-Studs to 1.9 N.m (17 lb in).
7.Vacuum lines.
8.Air inlet assembly. Refer to Air Inlet Assembly Replacement.
9.Instrument panel. Refer to Instrument Panel Replacement in Interior Trim.
10.Heater hoses. Refer to Heater Hoses.
11.Engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling.
-Check the system for leaks.
Sep 06, 2014 | 1997 Isuzu Hombre
How do I replace ATDC Sensor
Hi ordered a replacement servisakov call and they'll assemble free of chargeHi ordered a replacement call and they'll assemble free of chargeHi ordered a replacement scall and they'll assemble free of chargeHi ordered a replacement serviceman call and they'll assemble free of charge Hi ordered a replacement servisakov call and they'll assemble free of charge Hi ordered a replacement servings call and they'll assemble free of chargeHi ordered a replacement servings call and they'll assemble free of chargeHi ordered a replacement servings call and they'll assemble free of charge.
Oct 06, 2012 | Konica Minolta bizhub 250 All-In-One Laser...
How to remove headlamp assembly 2006 Ford Five Hundred
bulb replacement?
You may be able to clear bumper cover by pusihing down while pulling out lamp.
Please rate.
SECTION 417-01: Exterior Lighting 2005 Freestyle/Five Hundred/Montego Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/14/2005
Headlamp Assembly - Five Hundred, Montego adobe.gif Printable View (211 KB) n0050703.jpg
Item Part Number Description 1 W702706 Top headlamp assembly bolts (2 required) 2 W704551 Side headlamp assembly bolt 3 W702706 Front headlamp assembly bolt 4 13005/13006 Headlamp assembly (RH/LH)
Removal
  1. Remove the front bumper cover. For additional information, refer to Section 501-19.
  1. Remove the 4 bolts and the headlamp assembly.
    • Disconnect the electrical connectors.
Installation
  1. Connect the electrical connectors and position the headlamp assembly in place.
  1. Install the side headlamp assembly bolt.
    • Tighten to 11 Nm (8 lb-ft).
  1. Install the front headlamp assembly bolt.
  1. Install the top outboard headlamp assembly bolt.
  1. Install the top inboard headlamp assembly bolt.
  1. Install the front bumper cover. For additional information, refer to Section 501-19.
Aug 03, 2011 | Ford Five Hundred Cars & Trucks
How do you remove the headlights off a Pontiac grand am 2004
Lighting Headlight, Side Marker, Park & Turn Signal Assembly Removal & Installation To Remove:
  1. Open the hood.
  2. Remove the front air deflector.
  3. Apply light pressure to the headlight lens to hold the headlight in place while disconnecting the retainers.
  4. Lift up the headlight retainers to release the housing.
  5. Remove the headlight assembly, pulling straight forward from the headlight mounting panel. NOTE: Note the location and position of the adjuster retainers and locator tab.
  6. Disconnect the wiring harness from the headlight assembly.
  7. Rotate the bulb(s)/socket(s) as needed counterclockwise to release.
  8. Remove the bulb(s)/socket(s) from the headlight assembly.
To Install:
  1. Install the replacement bulb(s)/socket(s) to the headlight assembly rotating clockwise until fully seated.
  2. Connect the wiring harness to the headlight assembly.
  3. Position the headlight assembly to the mounting panel.
  4. Apply light pressure to the headlight assembly lens to hold the assembly in place while installing the retainers.
  5. Align the headlight assembly retainers and slide them over the assembly mounting tabs
  6. Install the front air deflector.
  7. Close the hood.
Feb 02, 2011 | 2004 Pontiac Grand Am
Need help changing out the low beam on drivers side of 2006 buick rainier
Bulb Replacement
To Remove:
CAUTION
Halogen bulbs contain pressurized gas.
Mishandling a bulb may result in the bulb shattering into flying glass
fragments.
CAUTION
Make sure to wear eye protection when
handling a halogen bulb.
CAUTION
Do not touch the glass of a halogen bulb,
only handle the bulb by the base.
CAUTION
Do not allow a halogen bulb to come into
contact with dirt or moisture.
CAUTION
Make sure to dispose of a used halogen bulb
properly.
CAUTION
Do not allow children to handle halogen
bulbs.
  1. Turn the lamp switch to the off position.
  2. Make sure the bulb is cool before changing.
  3. Remove the headlamp assembly from the headlamp panel.
  4. Remove the rear access cover from the headlamp assembly.
  5. Disconnect the headlamp connector.
  6. Remove the bulb from the headlamp assembly by rotating the bulb and socket
    counterclockwise.
To Install:
  1. Connect the headlamp connector.
  2. Install the bulb into the headlamp assembly by rotating the bulb and socket
    clockwise.
  3. Install the rear access cover onto the headlamp assembly.
  4. Install the headlamp assembly into the headlamp panel.
Headlamp Assembly
Chevrolet
To Remove:
Headlamp Assembly (Chevrolet)
  1. Remove the grille from the front of the vehicle.
  2. Release the headlamp assembly retaining tabs.
  3. If equipped, disconnect the headlamp leveling motor connector.
  4. Disconnect the headlamp connector.
  5. Remove the park/turn and side marker bulb sockets from the headlamp
    assembly.
  6. Remove the headlamp assembly from the headlamp panel.
To Install:
  1. Place the headlamp assembly into the headlamp panel.
  2. Install the park/turn and side marker bulb sockets into the headlamp
    assembly.
  3. Connect the headlamp connector.
  4. If equipped, connect the headlamp leveling motor connector.
  5. Lock the headlamp assembly retaining tabs.
  6. Install the grille onto the front of the vehicle.
GMC, Oldsmobile, Buick, Isuzu, and Saab
To Remove:
Headlamp Assembly (GMC, Saab, Oldsmobile, and Buick)
  1. Release the headlamp assembly retaining tabs.
  2. Disconnect the headlamp connector.
  3. Remove the park/turn bulb socket from the headlamp assembly.
  4. For GMC, Saab, Oldsmobile, and Isuzu vehicles, remove the side marker bulb
  5. Remove the headlamp assembly from the headlamp panel.
To Install:
  2. For GMC, Saab, Oldsmobile, and Isuzu vehicles, install the side marker bulb
    socket into the headlamp assembly.
  3. Install the park/turn bulb socket into the headlamp assembly.
  4. Connect the headlamp connector.
Oct 28, 2010 | 2006 Buick Rainier
I need to change the headlights
REMOVAL PROCEDURE
  1. Open the hood.
  2. Remove the push-pin retainers that secure the top of the upper fascia and grille assembly to the upper tie bar to allow the upper fascia and grille assembly to flex forward.
  3. Remove the bolt and the push-pin retainer that secures the top of the headlamp assembly to the upper tie bar.
  1. Gently pull the upper fascia and grille assembly forward only far enough to remove the bolt located at the bottom inboard side of the headlamp assembly.
  2. Pull the headlamp assembly straight out to disengage the snap-in retainer at the lower outboard back surface of the assembly. Turn the assembly so that the front inboard corner clears the front fascia.
  3. Pull the headlamp assembly out and away from the vehicle
  4. Disconnect the headlamp electrical connector.
  5. Remove the headlamp assembly from the vehicle.
  6. Remove the headlamp bulb cover from the headlamp assembly.
  7. Remove the headlamp bulb socket from the headlamp assembly.
CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Remove the headlamp bulb.
  2. Remove the side marker bulb socket from the outer side of the headlamp assembly.
  3. Remove the side marker bulb.
  4. Remove the parking lamp bulb socket from the inner edge of the headlamp assembly.
  5. Remove the parking lamp bulb.
INSTALLATION PROCEDURE
  1. Install the headlamp bulb to the socket.
  2. Install the headlamp bulb socket to the headlamp assembly.
  3. Install the headlamp bulb cover to the headlamp assembly.
  4. Install the side marker bulb to the socket.
  5. Install the side marker bulb socket to the headlamp assembly.
  6. Install the parking lamp bulb to the socket.
  7. Install the parking lamp socket to the headlamp assembly.
  8. Connect the headlamp electrical connector.
  9. Install the headlamp assembly to the vehicle by placing it back into position so that the bolt holes align and the snap-in retainer located at the outboard back surface of the headlamp assembly engages.
  10. Gently pull the upper fascia and grille assembly forward only far enough to install the bolt located at the bottom inboard side of the headlamp assembly.
NOTE: Refer to Fastener Notice in Service Precautions.
  1. Install the bolt and push-pin retainer that secures the top of the headlamp assembly to the upper tie bar.
Tighten the bolts to 6 N.m (53 lb in).
  1. Install the push-pin retainers that secure the top of the upper fascia and grille assembly to the upper tie bar to allow the upper fascia and grille assembly.
  2. Close the hood.
Oct 21, 2010 | 2006 Cadillac SRX
Servicing front hubs
Automatic Locking Hub
  1. Shift transfer lever to the ``2H'' position, then move vehicle forward and rearward approximately three feet.
  2. Raise and support vehicle, then remove wheel and tire assemblies.
  3. Disconnect brake hose from caliper.
  4. Remove caliper locking bolt.
  5. Rotate pad assembly upward then remove pad retaining clip and caliper assembly
  6. Remove brake pad support bracket.
  7. Remove hub cap retaining bolts, then the hub cap, Fig. 15.
  8. Remove housing assembly, snap ring and shims.
  9. Remove drive clutch assembly, inner cam and lock washer.
  10. Using tool J-36827 or equivalent, remove hub nut.
  11. Remove hub and disc assembly.Manual Locking Hub
    1. Shift transfer lever to the ``2H'' position and set free wheeling hub into Free position.
    7. Remove housing assembly retaining bolts then the housing assembly Fig. 16.
    8. Remove snap ring and shims.
    9. Remove body assembly and lock washer.
Jul 02, 2010 | 1991 Isuzu Trooper
Replace right rear break light
PLEASE DON'T FORGET TO RATE!!!
Signal & Marker Lights Removal & Installation Rear Lamp Assembly Sedan To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove the luggage compartment quarter trim panels.
  3. Disconnect the rear lamp assembly electrical connector.
  4. Remove the lamp assembly mounting nuts.
  5. Pull the lamp assembly away from the body.
  6. Disconnect the rear lamp assembly bulb connectors.
  7. Remove the rear lamp assembly.
To Install:
CAUTION
To prevent water from entering the luggage compartment, make sure the rubber grommet is fully seated.
  1. Position the rear lamp assembly near the body and connect the bulb connectors.
  2. Install the lamp assembly into the body.
  3. Install the lamp assembly mounting nuts. Tighten to 53 in-lbs (6 Nm).
  4. Connect the rear lamp assembly electrical connector.
  5. Install the luggage compartment quarter trim panels.
Jul 16, 2009 | 1998 Ford Taurus
How to replace front turn light bulb on Caddy SRX 2004?
  1. Open the hood.
    8. Remove the headlamp bulb.
    9. Remove the side marker bulb socket from the outer side of the headlamp assembly.
    10. Remove the side marker bulb.
Feb 12, 2009 | 2006 Cadillac SRX
Printer won't print
60.2
printer error
The tray 2 lifter-motor is not functioning. 1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
This is straight out of the manual.
Tray 2 lifter-drive assembly
Remove the following assemblies:
● Rear accessory cover. See Accessory covers and the tray 2 extension door.
● Top cover. See Top cover.
● Right-side cover. See Right-side cover.
● Formatter cover. See Formatter cover
● Formatter. See Formatter assembly
● Paper-pickup drive assembly. See Paper-pickup drive assembly.
2 Unplug the tray 2 lifter-drive assembly connector from the dc controller PCA (location J93) and
the two flat cables (callout 1, locations J80, J81). Unweave the wire-harness from the cable
guide (callout 2).
NOTE You might have to remove additional wire-harnesses from the cable guide to gain
access to the lifter-drive assembly wire-harness.
Figure 6-51 Tray 2 lifter-drive assembly (1 of 3)
Main assemblies 227
Unhook the tension spring (callout 3) at the lifter-drive assembly, remove one screw (callout 4),
and then slide the support plate (callout 5) out of the printer.
Figure 6-52 Tray 2 lifter-drive assembly (2 of 3)
228 6
Rotate the top of the lifter-drive assembly away from the printer to remove it from the printer.
NOTE You might have to remove some cable guides to easily remove the lifter-driver
assembly.
Figure 6-53 Tray 2 lifter-drive assembly (3 of 3)
Main assemblies
unfortunately i couldn't paste the pictures to help you.
Assembly is the exact reverse of removal, Good Luck!
Nov 20, 2008 | HP LaserJet 4250n Printer
Dell Inspiron 1525 Laptop Logo
mukhtar21 shaikh
mukhtar21 shaikh
