Coleman dgaa090bdtb furnace won't light after several power outages in a row. (eight times)
Is there a reset switch on this unit? Thanks in advance Bill N
  • 1 more comment
  • Bill Nickell Nov 01, 2012
    After reading the poorly arranged Owners Manual several times. I discovered that there is a manual reset switch. We are good to go!
    Bill N
  • Rick Abeyta Nov 14, 2012
    Where is the manual reset located?
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Coleman furnace -- fan runs, ingniter won't light,
The chances are that the furnace was running when the power went out. This will cause the high limit switch to cutout and needs to be manually reset.
You will find that switch in the blower compartment near the blower. Usually somewher near the highest point of the cabinet.
Push the little red button firmly till it clicks.
When the power goes out while the furnace is running the heat builds up because the blower shuts down immediately and causes this limit switch to cut out.
If you have a electric tester you can also follow the low voltage circuit till you find the open switch. Ther is usually a wiring schematic on the door cover of most furnaces.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 09, 2009
SOURCE: Lennox Gas Frunace fires goes out, fires goes out, fires goes out
furnace was working fine until the electricity went out for 5 hours now furnace is just humming and then nothing...HELP...
Posted on Dec 29, 2008
SOURCE: Coleman Mobile Home Furnace - Error Code Flashing Two Times
Our mobile home has a 1996 Coleman Evcon. We noticed dripping of water onto the front and back, dripping on the wires. A tech came, repaired the drip pan and cleaned the coils. Didn't help. The tech siliconed around the entire drip pan. Didn't help. The tech cleaned the entire unit where coils are. More water. What should I do next?
Posted on Aug 03, 2009
heatman101
  • 43501 Answers
SOURCE: Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Posted on Nov 12, 2009
I have a Coleman Echelon 9.C Series furnace that is blowing cold air. The red light flashes 5 times and the green light is flashing slowly.I had it checked several times by techsbut that can'
This code Signifies that your furnace's ROLL-OUT-SWITCH or auxiliary switch, may be open. This switch can be reset by pushing the center of red button on your furnace roll-out-switch. Make sure the heater has been cleaned out good, make sure the flue is clean, have the service company check to make sure there is not a cracked heat exchange. Call a reliable service company, not the cheapest there is no reason that they can not find the problem unless they are not qualified. If you have had a company out for the same reason and you have payed them to fix it then they have to fix the problem.
Nov 19, 2014 | Coleman Heating & Cooling
Igniter isnt lighting
IF YOU LOST POWER WHEN FURNACE WAS RUNNING IT TRIPPED ROLLOUT SWITCHES AND POSSIBLY THE HIGH LIMIT . IN CENTER OF ROLLOUT SWITCHES IS A LITTLE RED BUTTON THAT YOU RESET . YOU CAN ALSO TRY FINDING HIGH LIMIT WITH POWER SHUT OFF TO FURNACE PULL BOTH WIRES OFF HIGH LIMIT AND USE PAPER CLIP TO JUMP BETWEEN THE TWO WIRES MAKE SURE YOU DONT SHORT OUT AGAINST ANY METAL WHEN YOU TURN BACK ON IF IT WORKS YOU NEED A NEW HIGH LIMIT SWITCH.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
Auto fan does not start electric furnace
see this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked.
If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide).
If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports.
If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
Oct 08, 2012 | Coleman Mobile Modular Home Electric...
I have a coleman model 7680B series 856 with a pilot light that won't stay lit
You need a themocouple, it's a cheap $10.00 part you can get at any hardware store, you have a standing pilot light furnace like mine, if your handy and safe you can put one in easy, youtube is loaded with videos on how to do it. These other answers are wrong for your unit.
Oct 26, 2011 | Coleman Heating & Cooling
I have a coleman heater (central heating/A/C) Excel energy had a 2 hour power outage this morning unplanned and now I am trying to reset the thermostat so the heater will come back on) I had to reset the...
Hello, You may have this already solved by now but here goes. If your unit was running at the time of the power outage, you may have a limit switch kicked. This would cause your main blower to run non-stop with no heat. Gas furnaces has a main limit mounted on the wall of the heat chamber. This one should reset automatic when it cools down. Then you have a limit (maniual) reset on the blower casing. This is a small round device with two small wires coming off of it that goes toward the main board. If you can find this limit switch it will have a small button in between the two wires where they attach. Push in this button, if it clicks it should light the flame.There may be another limit on the burner casing. Try pushing this one also. When the power goes out when the flames are on this will build a lot of heat up near the blower causing this limit to kick off. Hope this helps.
Feb 03, 2011 | Coleman Propane Forced Air Heater...
Heatman101
Dec 09, 2009 | Coleman Propane Forced Air Heater...
I have a coleman evcon, and once in a while the smaller "blower motor" will come on, the "pilot" ( i think) will glow, and i can hear a relay click on and off, but the funace will not light, you can hear...
You need to change board and ignitor assembly. Go to hvac parts.com with model and serial number to get parts Power surges damage the boards all the time. Rus Let me know what happens
Dec 03, 2009 | Heating & Cooling
Heating & Cooling Logo
113 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
