Question about Sharp Aquos LC-32D42 TV
Why p10nk80z always damaged? - Sharp Aquos LC-32D42 TV
    Top Expert:
  • Sharp Master
  • 74,198 Answers
What is the problem now?
Posted on Oct 31, 2012
Must I use the wall mount to charge the Dyson V8?
always charge any item that comes with its own charger that way you can not damage it by trying to charge it another way.
there is always other ways to charge things up but its best to use what it come with (more so for safety reasons)
Nov 30, 2016 | Dyson Vacuums
Tip
How to maintain long life starter year and years
first of all repair your starter if old change brass and clean starter, if you got new car here's the tips to take longer life starter,always check stater for oil leak from engine to avoid short circuit always protect terminal positve and solinoid to the starter or put silicone to cover terminal protect from oil and water,during start cranking engine always released immediately when the engine start the key on crank position to avoid damage brass from the starter,dont try to punch hammer the stater or any metal to avoid damage magnetic core in the starter
on Sep 15, 2010 | Lexus IS 300 Cars & Trucks
I need to recover information from my damaged Hitachi Life studio
If the hard drive is damaged then it is near impossible to recover your data without expert help.
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Check the Internet for companies near you that can service hard drives.
Nov 14, 2011 | Computers & Internet
Hape lambat sering mati mendadak
if your saying that your phone is slow than usual, have it reset to factory settings, if it doesnt work, there are some possibilities.
1::: LCD is dameged (including Display IC) making the display slow or delayed. 2::: UEM ic is damaged, making "processing" power slow 3::: FLASH IC is damaged also making "processing" power slow
all of these aren't user serviceable, then i suggest you take them in for repair, either from where you bought the phone or any authorized nokia repair shop.
Aug 18, 2010 | Nokia 1600 Cellular Phone
Voice frequently not working. this problem intermittent. what do i need to do to ensure voice always works? Turning sound off and on again sometimes works. Turning on before using sometimes gets voice...
Are you using a synth voice, or a sampled voice? If the latter, one of the voice files might be damaged, and in that case, as soon as the Tomtom accesses it, the whole voice function will shut down.
Try changing the voice and see what happens. The synth voice does not access any sample files and should always work (or never at all).
To restore the functionality, download again the voice files, or try restoring from the PC backup. At least, this worked for me when I had the same problem (but MY file was damaged at the end, so I was able to notice that the last thing the Tomtom said was always "In sevent*". The damaged file was, I suppose, the one with the word "seventy".
May 29, 2010 | Tomtom GO 910 GPS Receiver
It will not spin
1. Check the fuse for damage.
2. Check the power switch if this is still OK.
3. Check the motor drive for damage. Damaged motor
drive always smell burned enamel.
4. If all of the above are OK, check the control card,
for replacement (if damaged)
Oct 14, 2009 | Dryers
D1911 always damage
check the component around it , check diodes, transistors, resistors, and capacitors. check also the power supply voltage.May its too high.
Jun 04, 2009 | Televison & Video
My micorwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
More info on such problems:
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
Always spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Always use the vent fan when cooking on the stove top to keep steam and grease out of the controls.
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
I recommend a soft cloth since paper towels can scratch the plastic.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
Sep 10, 2008 | Samsung MW1030WA Microwave Oven
Cannot download music from my pc to lg cell phone
Lg is a difficult cell. Check if you got the correct cable for correct cell, Check inside the connector where you plug the cable in if you didn't damage some connector pins, because some people sells cables that does not work on lg cell and damage the conector pins when you plug it in. Ps Did you loud the drivers for your cable, and is it usb or serial cable.
Dec 22, 2007 | Nokia 1100
MT3140 Emerson Microwave Oven
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 02, 2007 | Microwave Ovens
Sharp Aquos LC-32D42 TV Logo
29 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
