LG DVD Receiver HT752 - No sound coming through rear speakers
Inherited a LG DVD Receiver HT752 from a housemate when she moved, but the remote had been lost. The rear speakers don't produce any sound, nor do the front speakers when connected to the rear speaker output. All the speakers work fine when connected to the front speaker output.
  • 163 Answers
SOURCE: rear speakers on 7.1 not working
Most likely you have wrong setup- two rear speakers are assigned for zone 2. Press setup on a remote controller go to OPTION SETUP and assign POWER AMP to S.BACK.
Posted on Apr 09, 2009
  • 92 Answers
SOURCE: Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
Posted on May 20, 2009
  • 245 Answers
SOURCE: No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
Posted on May 23, 2009
SOURCE: Speaker output
Yes, there are relay type switches associated with those outputs. Your RX-V1 is not dying.
Just plug a pin plug in and out of the dead channel to bump the switch. You will hear the speaker
come on. If it doesn't come on,do the plug jack in an out of the pre out again. It will come on.
You can use the test tone to check all channels and rebalance volume levels. You are making the
pre out connect to its power amp. It seems the problem got better when activating those switches. Most likely a cleaning issue. You can also jump the mains and center, and there is also
a modification to jump all channels. I bought my RX-V1 very cheap because of this and love it.
Of course outboard power amp would solve all, but getting this reciever to connect to it's own
power amp has been thrilling as far as bang for the buck. I do use the front effects also, and like
them. It may seem like a pain, but it is worth it to get those channels going.
Posted on May 31, 2009
  • 9 Answers
SOURCE: Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
How do i hookup my memorex dvd player mvd2047 to my dish box to watch movies
I have a Philiphs DFR _1600 Surround Sound Receiver with Built in DVD Player . I Don't Have The Remote , I got the Dfr 1600
ay Gooodwill for $25 Dollars ,
I would like to ADJ The rear Speakers , Turn them up
Is There a Way to turn up the Rear Speakers on the Unit it,s Self .
with out a Remote .
My Kenwood Surround sound Unit has this on the front of the unit .
Thank you
Harry w
Dec 04, 2013 | Televison & Video
I have a Sansui RZ-7001 home theater system but cannot get surround sound when connecting my LG Blu-ray BD 550 to it. What am I doing wrong?
fred i dutoi,
Check your connections first. Make sure your input on the Sansui RZ-7001 menu is selected to dvd. Also, make sure the blue ray cables are also inserted in the correct inputs on the rear of the receiver(dvd input). via. rca cables(red, white & yellow) the yellow is the video, hdmi, or optical. If you do not hear sounds coming from your speakers you need to check the separate volume levels for the speakers within the receiver itself. Front and rears having different volume levels within the receiver. Hope this helps. Also make sure you check the volume on the dvd player. Thanks for visiting FixYa.com. Have a great day !
techguy21
Jul 06, 2011 | Audio Players & Recorders
I have an older model Yamaha HTR 5830 receiver and I want to set it up for surround sound (5.1). When I test the receiver all five speakers give back a signal, but nothing ever comes out of the center or...
The broadcaster of the TV station has to tell you they are transmitting surround sound - sometimes they are just transmitting stereo. Also, the media as in CD's and DVD movies must have surround sound embedded or recorded on it to allow surround sound.
Jan 02, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
No sound from rear speakers with TV and DVD player
You also have to connect a SPDIF coax or optical from both the DVD player and from the STBox into the digital inputs on the rear of the receiver. And select them with the remote control.
Apr 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I having trouble geting the tv sound to go through the dvd surround system speakers and do i also have to have a remote to equile the speaker volume on the surround system
If you have a volume knob on your surround receiver, you do not need a remote. I;m not sure what your problem is, but if you want the TV to be broadcast through the surround sound system, you need to connect audio out from the TV to audio in on the receiver on a separate channel than what the DVD is hooked up to. Then pick that source on the receiver that corresponds to the TV out. I hope that helps.
Oct 26, 2009 | LG 42LC2D 42 in. LCD HDTV
May 18, 2009 | Yamaha HTR-6130 Receiver
I want to run remote speakers from this unit to my bathroom.
you need to hit the multi-source button, then the soucre (fm/video.dvd etc) and then turn on the remote speakers
Jan 10, 2009 | Onkyo TX-DS656 Receiver
Sound comes only fron one rear speaker
Did you try switching Speakers A and Speakers B button on the AV receiver?
Jan 10, 2009 | Bose Acoustimass 10 III System
LG Surround Sound Troubleshooting
I have a lg dvd/surruond sound and the remote suddenly stopped working. I bought a new lg riginal remote but still nothing, any thoughts?
Jan 02, 2009 | LG LH-T754 Theater System
Region code Hack for LG HT752
LG5000.zip - works fine. Just reset my region code to 0.
Dec 05, 2007 | Televison & Video
125 people viewed this question
 Grubhead
Grubhead
