Open close button doesn't work - Televison & Video
  • max carson
    max carson Oct 30, 2012
    Not sure what your video is trying to show? Is it the dvd on a laptop?
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 39 Answers
Not sure what it is but cd / dvd drives usualy run on a motor wich turns a cog wich moves the tray in or out depending on the polarity if i was going to attempt a hope repair the first thing i would do is test that motor do not attempt a repair without basic knolage of electrical systems a wireing diagram is a must if its a valuble item if it is a pc type device pcs run of a few difrent powers around 3v 6v and 12v i would expect 6 or 12v most likely 12v but thats where a diagram comes in usefull
motor basics increase the current the motor will turn faster and harder decrease for the reverse
polarity put positive on positive and negitive on negitive it turns say clockwize reverse that polarity swap the wires over reverses the current motor turns the other way
a motor is built to run at up to a certen rpm at a max tempriture of xxxx put too much power in u decrease its life for sure extreamly low power can be bad too
ok u know how a motor is tested i would have the device unpluged and test that motor id look on the motor to see what current it says it runs on if it says at all if u got no idea start lower 3v then if nothing 6v nothing 12v if u get to 12v and still nothing on eather polarity its proberbly fryed it will hopefully have a part number on it
its actualy far more likely that a bit of plastic has broke but when your inside there looking at the motor ull see all the plastic cog / rail system im sure ull get thare again it looks expencive so concider taking it to a pro
Posted on Oct 30, 2012
Lexus 2007 RX350 trunk door doesn't open or close from key, trunk button and power door button
OPEN MANUALLY AND CHECK THE STRUTS PS. IF WHEN YOU OPEN IT AND IT GOES BACK DOWN THAT'S YOUR PROBLEM
Sep 25, 2012 | 2007 Lexus RX 350 FWD
My nokia x3-01 meun button not working
open yoyr mobile and clean all buttoons properly and close your mobile then try menue button
May 18, 2012 | Nokia X3-02 Touch Type Dark Metal Unlocked...
I have a 1987 celica gts hatch back...and my close button and down button doesn't work for my sunroof but the open and up does and it stuck opened....how can I fix this or close my sunroof before it...
Some cars have a small plugged hole in the ceiling above the back seat. You can use an allen wrench there to close the sunroof..
I know Acura has it and several other cars. Try looking around on the headliner.
Hope this helps you
good luck
Jun 29, 2011 | 1987 Toyota Celica
Open the top cover and insert a toner cartridge. message shows when i try to print but top cover already closed properly
check on the left hand side of where the top cover opens , in the inside there is a clip along with a senor
check that it si not stuck . if that doesn't work, open the top cover hold in the cancel button or the bigger play button ( differs printer to printer ) or both for approx 10 - 20 seconds , you will see all the lights flash remove the toner , re-insert the toner & close the top cover . This will reset the drum unit & the printer status. Alternativly switch the printer off ( with top cover closed ) hold in one or both buttons and turn it on for approx 10 - 20 seconds again , you will again see all the lights flash, Your printer will reset its status And clear its page count .
also try open the back cover close the front then the back , press cancel or play button twice there after.
( this is a common diagnostic procedure with small laser printers )\
Please post back if this doent solve the issue
Thanx
May 27, 2011 | Canon LASER SHOT LBP-2900 Printer
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
Motorolla headset h700 pair with blackbery
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open the headset and pressand hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
If this doesnt work: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Jun 06, 2009 | Motorola Mobility H700 Wireless Headset
Heat climate control doesn/t blow warm air when on lower setting
It sounds like the blower resistor is shot. Just change out the resistor and that should take care of it.
Mar 15, 2009 | 2002 Jeep Liberty
Steam works, coffee doesn´t
Try to prime the machine.
Open the steam knob and press the buttom for coffee, when the water comes, close the steam knob.
Aug 24, 2008 | Saeco VIA Venezia
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
