Question about Frigidaire AEQ7000EG Affinity Series Electric Dryer
Won't spin The dryer will spin if I give it a push start (door open with door switch depressed). Otherwise, I hear the motor making a noise attempting to spin.
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
The start relay on the motor is bad and you will need to replace the motor. The relay is not sold separate. Here is the motor you need to order.
Posted on Nov 01, 2012
SOURCE: Thumping drum noise
ngfam1,
You are reminded, this is a SELF HELP web site. You are supposed to encourage people with you knowledge of how to repair appliances. Not to discourage them and tell them to call a repairman. The whole point of this forum is to AVOID a service call and NOT to promote your repair service. Give you a good rating for what? Stop begging for ratings and start actually helping!
Posted on Sep 06, 2008
  • 130 Answers
SOURCE: dryer wont start
its one of three things, check your thermal fuse on the back inside of the vent, the door switch or the start switch
Posted on Jan 29, 2009
  • 124 Answers
SOURCE: Dryer keeps running after the door is open. Is
Hi.
Yes door safety switch may be faulty or stuck.
Normal for them to go out over time & usage. Switch is usually $5.00 to $20.00 labor well you can guess as usual more than it should.
Another possible problem could be wire shorted. But that would be a rare occurrence.
Posted on Mar 11, 2009
  • 61 Answers
SOURCE: Dryer won't spin
hey first make sure the timer knob is set on drying cycle and not off ( know it might sound stupid but people forget sometimes) and if its making that noise the humming it means you need a new motor 100% sure its not easy to do if you have never done it before
Posted on Jun 07, 2009
  • 154 Answers
SOURCE: Humming, but no spinning
It could be the capacitor which kick starts the motor.
they are relatively cheap to replace.
Ash
Posted on Oct 22, 2009
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Rgx4634kq2
make sure push start switch is not stuck pushed in.Also sounds like the switch mounted on the motor could be stuck, which means new motor. Does motor start and stop with timer being moved to the off position ?.If so then not the motor.
Jul 01, 2013 | Dryers
Indesit G74V dryer won't spin
Some dryers have a belt tension idler and switch combination that works to keep the belt under tension and shuts down the dryer if the belt breaks or falls off.
Apr 28, 2017 | Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
Jul 14, 2011 | Frigidaire FEQ1442ES Electric Dryer
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Maytag Gas Dryer has power (light is on), but when I push the Start Button, nothing happens. The Dryer is a Maytag MGD5570, just under 4 years old. I checked the Thermal Fuse with a continuity tester and...
I had the same problem. Here's a quick test you need to do. It will take two individuals (unless you're extremely talented) Open the dryer door and push in the door switch... and hold it in. Have the other person push on (and hold) the start button on the console. At that same time everyone is pushing the switches take a free hand and reach into the dryer and try to spin it. Sometimes just a little push (assistance) is all it takes and..... bingo the dryer starts up! If that's the case... your motor is on its way out or it's gone. Usually due to the bearings on the motor being badly worn.
Feb 03, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Heating element heats up, but dryer will not spin.
Since you stated that the heating element is heating up I believe it rules out the thermal switches.
When you push the start button does it make the motor make any noise? Maybe hear the motor humming? Two things to check for are Broken Belt or Bad Motor:
This requires common sense and since you are going to be bypassing the safety features you need be CAREFUL.
First, with door open, manually press in door switch to by-pass door safety, then press "start", try to manually start the dryer by spinning the drum by hand, If you hear the motor humming but it does not start spinning on it's own; most likely it is a broken belt which can be changed without much difficulty for less than $15 bucks. NOW if it then continues to spin on it's own GET YOUR HAND OUT OF THERE and close the door; you have a bad motor and even though it started it needs to be replaced. A motor for that is available for just under $100 bucks and is not to bad to replace, I would recommend replacing the belt at the same time since you will be in there. Good Luck!
Apr 29, 2009 | Whirlpool LEQ7030KQ Electric Dryer
Whirlpool dryer will not start
open top panel should flip up two screws at lent trap screen if on top of unit when top panel is up push start button then push drum while you hear that buzzing noise if drum starts it needs a new motor
Feb 21, 2009 | Kenmore 63942 Dryer
Frigidaire AEQ7000EG Affinity Series Electric Dryer Logo
89 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
