Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Dials are on zeros
I cannot get this thing to work.
  • pkien39 Jan 03, 2009
    How do I get off of zeros.
    I set the thermostat on 73 and furnace will come on and then it goes off
    Genius:
  • 1,142 Answers
Try removing the batteries and leave it turned off for half hour then insert the battery to get it operated back again
Posted on Jan 03, 2009
  • 916 Answers
Sounds like the furnace is trying to run, but is getting cut out on some safety device. Depending on the furnace there are many different proving devices that could be cleaned and/checked. one thing you can do is take the cover off the thermostat and take an alligator clip and jump from red to white this should bypass the thermostat. if you still have no heat then it's probably not the thermostat.
    Scholar:
  • 46 Answers
Is there a hard reset button? Using a pin you could reset it, or simply resetting the circuit breakers might work.
    Genius:
  • 1,199 Answers
Try to press and hold the select button untill it goes into mode
  • 19,396 Answers
Try removing the battery to reset the unit, and see if it works after reset.
Follow the manual to ensure you are using the thermostat correctly.
The face on my dial calipers is turned 90 degrees to match up to 0. How do I adjust it to be correct and readabel?
There should be a small set screw you can loosen by hand and adjust the face of the dial to zero with the jaws closed....this is typical of most calipers...it allows you to zero the dial on a given thickness of material and only read variations based on that thickness.
Take care.
Dec 09, 2010 | Mitutoyo Dial Calipers
My caliper is .030 off of zero I don't know how this happened . How can I fix this problem
Just loosen the screw that clamps the dial in place, close the jaws, and turn the dial to zero. Then tighten the screw clamp
Sep 18, 2010 | Mitutoyo Dial Calipers
Fowler 12" dial caliper measures 0.025 when shut, how do I zero
There should be a small thumb screw near the dial that you loosen to turn the dial to zero it, then re-tighten the thumb screw.
Apr 27, 2010 | Fowler Shockproof Dial Caliper - 0 - 6"
Hi display dials of my nissan terrano are not working any more. Diesel, speed etc..all show zero. Can you help? Thks!
check the connection under the dash..i think they come off..that why every thing stay on 0
Apr 21, 2010 | 2000 Nissan Xterra
I have two questions. The first is what is the
The dial is for selecting which of the "multi" things you need for measuring (metering).
Set the dial to the DC area and select 20V or whatever is the lowset DC voltage setting that is higher than the battery voltage.
The meter does not put a "load" on the batteries, so the test is just an estimate of freshness of the battery.
Notes:
The meter voltage does not present any danger to the user. If you are not experienced, do not check any AC voltages.
Oct 12, 2009 | Kitchen Appliances - Others
How to adjust Mitutoyo 505-101 caliber
You don't. What you did to adjust zero is what you do to adjust zero. Do not "go inside to adjust the dial". If the dial reads zero when the jaws are shut there is no problem.
Mar 18, 2009 | Measuring Tools & Sensors
Dial calipers .06 off from zero
With the caliper set to zero, you must turn the dial body to set it to zero. This should be done every time before the caliper is used.
Jan 24, 2009 | Measuring Tools & Sensors
Cannot delete old quick dial numbers
quick dial numbers cannot be deleted.you just have to make sure you print first the auto dial list for you to know where it is located.go to that location,enter zeros and then menu/set to save the number as a zero
Nov 05, 2008 | Brother IntelliFax-2820 Laser Fax
Time on the phone
This must be done at extension 10 or 11:
Press Feature and dial zero zero
Press the left intercom button twice
To set the time, press the pound (#) key and dial 103. Enter the correct time using a 24-hour clock (if it's afternoon, add 12 to the hour...i.e. 3pm is 1500)
To set the date, press the pound key and dial 101. Enter the correct date using the format MMDDYY (two digit month, two digit day, two digit year).
Press Feature and dial zero zero to save your changes.
Nov 01, 2007 | Avaya Eurostyle 18D Corded Phone
Change time
Oct 30, 2007 | Avaya Eurostyle 18D Corded Phone
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
105 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
