Question about Uniden GMR 3040-2CKHS Two-Way Radios with Charging Kit 2 VOX Headsets and 2 Carabiners
The rx icon is always showing and i have constant static. How do i get rid of the static? It will go away if the rx mode is on a number but then i cant communicate with my old 2 way. when it is in the off mode i always have static.
    New Friend:
Did you get this solved?? Having the same problem. One handset is perfect the other 2 are constant static.
Posted on Dec 30, 2012
Uniden gmr2638_2ck is always stuck on receive. Rd is always showing and static coming from the speaker
Adjust your SQUELCH control or setting so that the noise disappears. The RX indicator will go out.
Mar 01, 2015 | Uniden Radio Communications
One of three Uniden GMR3740-3CK constantly recieves static that goes on and off. tried swapping batteries and did not work. rx display goes on. Very annoying. Other 2 radios are fine. Is there a setti
Well, it IS the squelch level. Most radios do not have an adjustment for this. Take the bad one back, you've done all the tests you can. Good job.
Jan 07, 2015 | Uniden Radio Communications
My uniden UH3O5sx is always stuck on receive (rx is always showing) can receive but not transmit
Set up your privacy tones or adjust the squelch level to stop the static and bring the handy out of receive mode. Some models have a busy channel lock out, that if it beleives it hears something it will not let you transmit over the other station.
Oct 04, 2014 | Uniden Radio Communications
Static noise rx
Check your batteries. Static can be a sign of a bad or low battery. Swap batteries between the units to see if the problem moves to another radio.
Also, check your antenna and antenna connection.
Best regards.
May 13, 2013 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
How to get rid of static
Your radio allows you to listen for weak signals on
the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press MON button. The RX
icon blinks.
• Press and hold MON button for 2 seconds until
two beeps sound for continuous listening. The
receiver circuit stays open, letting both the noise
and weak signals to be heard.
To turn OFF Monitor Mode:
Press MON button to return to "Normal" mode,
and the RX icon stops blinking and disappears.
Dec 28, 2011 | Uniden GMR22382CK Two Way Radio
Uniden uh064sx-2 2-Way RX Stuck On
Didyou have any luck resolving this issue? We currently have exactly the same problem
Aug 05, 2009 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Jul 23, 2009 | Cobra Radio Communications
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Jul 06, 2008 | Cobra PR4100-2WXVP 2-Way Radio
Uniden GMR 3040-2CKHS Two-Way Radios with Charging Kit 2 VOX Headsets and 2 Carabiners Logo
262 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
