I broke the door handle on Malber WD 1000? Do they sell a replacement part like the handle or door?
SOURCE: Malber WD 1000 dryer help...
jack it should start turning after a while as soon as the dryer has warmed up.
Does it dry however?
SOURCE: Malber WD 1000 takes four plus hours to dry one load
i would check the thermostat and heating element. one or the other is not on enouph to dry your clothes.
SOURCE: We broke the door handle on our Malber 1000 Can we
Mike, in Washington D.C., again. Of course you can do it yourself. First call Joel (Malber in NY) at 800-600-8913 or 516-294-6660 . Tell him which model machine you need a door latch for (if you aren't sure, check label in rear). Once you've received your new latch assy (about $20): Open door, and notice white plastic "ring" around glass is actually 2 pieces (front and rear) snapped together - with a seam around periphery. Unsnap (separate) them by either getting your fingernails into the seam and pulling them apart - or prying them open with a spackle knife or thin screwdriver blade. Once it starts coming apart, just work the opening all the way around. Remove front "ring" and set aside. Using a 1.5mm Torx screwdriver, remove 2 small screws holding broken latch assy. Note the way the ends of the spring go under the 2 screws. That's the way it has to go back. Slip new latch assy into place, pressing vertical "hinge pin" and ends of spring into slots (near screw holes). Replace 2 screws. Test latch with door open - is it working? Try closing door. All good? Replace front "ring": Open door and, while pulling out on latch handle, slip the ring over the latch handle and get it into approximate position. Let go of latch (it snaps into "closed" position) and adjust ring so it doesn't bind the latch handle (meaning it's free to move). Now, beginning anywhere on outside edge, begin snapping rings together - and continue all the way around. Test that door latch still operates smoothly and that door latches shut properly. FYI: There is no adjustment for this latch assy - it just fits precisely where it's supposed to. Good luck and God Bless ...
