Question about Electronics - Others
The low voltage light/alarm is going off
When I turn on more than one light or attempt to run the furnace/heater the low voltage light/alarm goes off... I have a 2005 Terry RV
    Problem Solver:
  • 13 Answers
Get your altenator and battery checked
Posted on Oct 31, 2012
WE have a Lennox furnace that is 3 years old. We also have a Lennox AC that is 14 years old. Recently we had a board go bad on the furnace after a series of power outages and it was replaced. We also...
your furnace uses 115 power & there is a transformer in this unit that powers the low voltage controls. i would say that when they replaced the board they missed some issues with the low voltage control wires. which is likely to be what cause the board to go bad. theses low voltage wires are the only thing that can tell the outside unit to come on. the lights dimming tells me that you have a bad capacitor or need a hard start kit. the lights normally only dim if the compressor doesnt start.
Oct 13, 2013 | Carrier 38CKC036 Air Conditioner
I have a Honeywell CT500A thermostat. I set it at 68 degrees. the room temperature is 62 degrees. The unit cycles on and the "flame" icon shows on the screen, but then the unit goes off ( the...
Here is a simple way to tell. Remove your thermostat from it's mounting plate, locate the wiring, the red and white are low voltage control wires. Disconnect them from the base and join the two together if the furnace runs you need a thermostat if not it is in the controls to the furnace.
Dec 27, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
When turning on main switch light goes on but no other lights go on. This one has a light for low voltage, flame, ect. none of thode lights lite. Jet heater doesn't attempt to start either.
Is there a reset or an in line fuse ( a little glass fuse )? This is only indicating that you have power to the heater. If I were to guess I would say there is something between the high voltage and low voltage, usually manufacturers will put protection (a fuse ) on the low voltage side of your step down transformer. Remove the electrical cover after powering it down and trace the wires from the plug to the transformer looking for a reset or little glass fuse.
Dec 22, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
The power went out. What should I do to get my furnace running again?
Make sure the thermostat is calling for the respective seaon and see if it works. A power outage shouldnt interrupt the furnace unless you had really low voltage or a voltage spike. Try it and see
Dec 13, 2010 | Goodman GMS90703BXA Heater
How do I run the low voltage wire for a Honeywell bypass humidifier to a new Goodman gas furnace. I need the instructions symplified. Is a current relay sensor necessary? How about the brown wire that...
Take the power from the fan after the on off switch then to a transfomer then up to the stat that goes with the humidfier then down to the humidfier,
Nov 29, 2010 | Goodman GMS90703BXA Heater
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
Furnace not firing up...thermostat said low battery ...installed new batteries. Green (LED) light indicating power to thermostat is off. Furnace still doesn't fire up.
1) Turn the fan to on and if it runs you know that you have line
voltage to furnace and 24volts to the thermostat.
2) You could turn the furnace off remove the doors and get to the
control board. If you can find the Thermostat wires on the board
mark and remove them. If you have a typical Furnace and you
have some electrical background put a jumper wire between
terminals R and W,put the doors back on-there is a door switch
that if the panel is not put back on-it will not run. Turn your power
back on.
3) The Blower motor may come on, the induced draft blower should
come on, the glow coil should glow, the gas valve open and the
burners should come on and the unit should run.
4) If all of this happens, then you have a thermostat problem or you
have bad thermostat wires.
5) If nothing happens then you don`t have power to the furnace or the
little fuse that protects the transformer is blown.
Good Luck
Jan 08, 2010 | Honeywell Electronic Programmable...
Coleman furnace -- fan runs, ingniter won't light,
The chances are that the furnace was running when the power went out. This will cause the high limit switch to cutout and needs to be manually reset.
You will find that switch in the blower compartment near the blower. Usually somewher near the highest point of the cabinet.
Push the little red button firmly till it clicks.
When the power goes out while the furnace is running the heat builds up because the blower shuts down immediately and causes this limit switch to cut out.
If you have a electric tester you can also follow the low voltage circuit till you find the open switch. Ther is usually a wiring schematic on the door cover of most furnaces.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 09, 2009 | Coleman Propane Forced Air Heater...
Main Fan won't turn off even with thermostat removed. Burner not
There is a chart with the wiring diagram and othere charts that will tell you what the 6 blinks are for. That should tell you what is wrong and what part you need. Sounds to me like the board has an issue or the gas valve is locked out.
Jan 10, 2009 | Goodman GDS81155CNA Open Flame Mid-Size...
Pilot lights fine, furnace fires up, when it turns off the pilot goes out
need to have at least 3 feet of vent out of the roof, if it is to low the coll air will cold soak down to the pilot and shut it down.
Nov 08, 2008 | Cozy (W352E) Heater
Electronics - Others Logo
52 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
