Question about Maytag Dryers
Maytag neptune dryer will not dry in sensor mode
Will not dry in sensor-mode
  • 1 more comment
  • Philip Devole
    Philip Devole Oct 31, 2012
    MODEL: MCG8000AWW
  • Richard Roth
    Richard Roth Oct 31, 2012
    Troubleshooting the Sensor-Dry circuit: • Check for incorrect wiring of the electrical connector at the electronic control board. Dryer runs for 2 minutes, jumps to a 1-minute cool down and then stops. Open Sensor Dry circuit. Check Sensor Bar. Refer to Sensor Bar Diagnostics section. • Dryer does not shut off. Check sensor for continuity. If found, replace sensor bar or clean with alcohol. Some fabric softener sheets will coat the sensor bars.
  • Richard Roth
    Also, I have the complete service manual if you should need it.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Oct 31, 2012
5 Suggested Answers
SOURCE: Gas dryer does not dry clothes
try replacing the solenoids/coils.
Posted on Jan 10, 2008
  • 1028 Answers
SOURCE: Maytag Neptune MDG9700AWW gas dryer. Problems
be sure vent is clear all the way to outside try a load with vent disconnected ..also if gas dryer may be a problem with burner reigniting after heat up if so try replaceing both coils on burner valve
Posted on Jun 06, 2008
protek480
  • 1714 Answers
SOURCE: How do you remove the bottom cabinet of a Maytag Neptune Dryer
OR..... you could watch the video...
Posted on Aug 07, 2009
Illeagle
  • 525 Answers
SOURCE: My Maytag Neptune gas dryer gets hot for about 30 seconds.
Below is a link courtesy of www.repairclinic.com. This shows the Gas Valve Coils, which is the number 1 failing component.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG5500AW-%3d%3di3479&PartID=3479
Below is the disassembly/diagnostic procedures page that may help on teardown.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
For more information visit, http://homemanagement.services.officelive.com/FieldServiceHelp.aspx
Posted on Sep 23, 2009
Our Maytag Neptune gas dryer runs but no heating of the air either on sensor dry mode or timed drying we have cleaned out the lint tripa etc and it does not seem to change anything
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Model MDE5500AYW. Seems like dryer occasionally overheats when in sensor dry mode. Lint screen and vent are clean and plenty of air flow. One time the sensor works fine (minute timer drops and unit shuts...
there isn't a timer on this machine,you have a control board,if the time isn't counting down correctly sounds like you have a bad control board that's inside the console
Feb 10, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE9700AYW electric dryer doesn't stop in sensor dry mode.
The link below contains the service manual. Detailed Troubleshooting begins on page 10.
Good luck
MDE9700 Service Manual
Sep 22, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune sensor and time drying settings
Fixed the problem, not the machine, needed a new dryer vent. Just unhooked the vent and
the dryer worked perfectly. V
Feb 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Oct 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number 200258764242.
Premmy
Oct 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer purchased 5 years ago - panel completely lit up
you may have it in advertising mode
Try Pressing the damp dry and sensor dry keys
for 5 seconds will take it out of the
Advertising mode.In Advertising mode No functions will be run
except illuminating the LEDs
Let me know if it works
Oct 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer
the glow plug sensor not accurate send to timer /replace sensor
Nov 30, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
111 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
