Question about JVC Televison & Video
JVC 52 inch tv, about 8 years old has sound but no picture and WE CAN read the cable guide on teh tv screen......please help! Thanks so much!
    Top Expert:
  • JVC Master
  • 14,553 Answers
Try another input on the set, if you have on screen display set is working to some degree, also try to unplug set and or box or other gear hooked to it for a while and power back to allow all to reboot or try to===problem is NO video or no rastor if menu comes on screen. Also please check which input the set is currently on......
Posted on Oct 31, 2012
SOURCE: lamp going out on jvc flat screen tv 52 inch,how do you change
Versed, you have to open the back panel (cover) to access the lamp. replacing is easy as soon as you can see it. loosen the mounting bolt and pull to unplug the lamp from the SMPS Lamp power supply. Thats it.
Posted on Dec 29, 2007
SOURCE: JVC i art 32" flat screen
Does anyone know where can I buy a screen for a 27" LCD Insignia TV. Model is NS-27LCD? My screen creaked. I checked out e-bay and have not found a broken TV with a good screen. Does anyone know where I can buy a screen at.
Thank you all for you time.
JC
Posted on May 16, 2009
SOURCE: Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Posted on Sep 21, 2009
SOURCE: LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Posted on Jan 04, 2010
  • 1632 Answers
SOURCE: Sanyo TV DP42647 No picture or sound, remote does nothing
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
I have a 52 inch Magnavox LCD tv. Yesterday the screen went black **** sound is still good. I started smelling a burnt plastic smell so I unplugged from the wall. What could be the problem?
Tv turn on now,have a flashes of picture a few sec.than dies have sound left only?Yes.The 2 long board call the LCD inverter board are dead.These 2 long LCD inverters help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Jun 01, 2010 | Philips Magnavox 52MF437S/37 52 in. LCD TV
No picture only sound ( plasma 52 inch )
Hello Fixya customer,
Thank you for your question.
There are several possibilities here including the signal source, a fault in the video processing, or panel display drivers.
This can be narrowed down further for your model. Please supply the full model number of your TV.
Thank you for using Fixya, and I look forward to your response.
Apr 29, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have a 52 inch JVC tv. The power will stay on but, no sound or picture on it
Let me know model number of your JVC tv to find out helpful info to fix it.
Model number would be written at back of tv.
Thanks.
Feb 09, 2010 | Televison & Video
52 inch rear projection tv turns off after a minute
try turning off the auto shut off feature in you set up screens . you can find them through the menu button on your remote. scroll through till you find it and turn it off.
Jan 18, 2009 | JVC AV-56WP74 56" Rear Projection...
52 inch sony rear projection t.v.
Whining sound most likely is a bad flyback transformer. You are probally looking at a 350-450 bill depending on the repair shop. If your picture was "great" go for it. If the tv has a lot of wear let it go. Nothing the repair shop does to fix your problem will make your picture better than it was before it went out. Somthing to contemplate.
Feb 05, 2008 | Televison & Video
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
No picture
Same problem, worked fine this morning and then tonight I million green horizontal bars - sound is fine. I think from reading up on this we are doomed. I am so pissed, the TV is not even 2 years old.
Oct 01, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
