Question about OCE Office Equipment & Supplies
I have oce tds 100 machine and if i copy a document it will not stick to the paper i.e will not allow the toner to fuse to the paper in some areas of the sheet. Any suggestion on how to remedy the problem. OCE has discontinued the copier
  • Sajo Olatunbosun
    Sajo Olatunbosun Nov 01, 2012
    the toner can not fused with the papaer
  • odipo mark
    odipo mark Jan 30, 2016
    probable cause is media type change from either paper to film or try with a different paper type.
    Odipo Mark
    New Friend:
  • 68 Answers
More than likely the fuser needs replacing.
Posted on Apr 25, 2018
3 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: OCE 7056 Toner Not Fusing To Paper
you need parts to fix the heater. the heater is the part that fuse the ink to the paper.
since part of print is not fused to the paper. I am assuming at this time it must have multiple heater in the machine.
go to the link and see if they can sell you the heater you need.
www.kyoceramita.co.nz/files/1/Parts%20List%20v0405.xls
good luck on finding parts.
Posted on Oct 17, 2008
Dear, This shows that wrong Toner is added so remove it and put the original one ur problem will be rectified. for Oce 7050 series u may aend me the mail stating ur problem on sanjay5in.competent@gmail.com
Posted on Sep 15, 2013
What does error code 0820 on Oce TDS 100 stand for?
NTC Middle right of the fuser assembly. The NTC must be replaced. These are ceramic encased thermistors. Very expensive and easy to break. I recommend calling an authorized Oce technician.
Mar 22, 2018 | OCE Office Equipment & Supplies
I have oce tds 100,this machine is showing this error code: 2201 error what could it be please any help
The safety relay is not activated. There may be a problem with the fuser.
Jun 05, 2014 | OCE 3140 Copier
Have a service manual for OCE tds 100 Copier?
No service manual, but go to downloads.oce.com and see what you can find there.
Jan 20, 2014 | OCE 3140 Copier
Oce tds 400 random black lines on demo print
Check the developer and clean the charge corona and the transfer /separator corona assy.Clean the PH unit lens.
Jan 29, 2013 | OCE Office Equipment & Supplies
KONICA 1015 COPIER - P.27 ERROR MESSAGE - - WHAT DOES IT MEAN?
2. Toner was added prior to adding developer and performing the TDS adjustment. Developer must be added FIRST at new machine set-up so that toner does not fall on the uncovered TDS sensor.
Run 47 mode, output code 51 until the code does not reoccur (may take 5 to 10 attempts) OR open the developer unit and clean the excess toner from the area of the TDS sensor. Then tilt the developer unit to allow fresh developer into this area.
3. Poor connection at CN95. The toner density sensor (TDS) is abnormal (0.2 V DC or lower). Reconnect CN95 (located under the front of the developer unit).
4. TDS failure. If version 16.0 is installed, P27 is displayed when the TDS is disconnected or fails. Check for proper connection prior to replacing the TDS.
Jul 10, 2009 | Konica Minolta Office Equipment & Supplies
Oct 16, 2008 | Office Equipment & Supplies
Patchy Prints
I believe that the Heat roller in the Fuser has a build up of toner on it(in some areas) and as a result is not fully fusing the toner into the paper. when you use a thick setting you are actually slowing the speed down to allow more heat to the toner. the thicker paper causes more pressure allowing the toner to fuse properly. I would say you need a new Heat roller and possibley a pressure roller. You could try running 20 copies of a blank white page. Sometimes this will help. Poor fusing can also cause a previous image to come up on the next page or repeat itself down the page. A service call is in order if this does not work.
Hope this helps
Dave T
Mar 29, 2008 | Ricoh 6513 Copier
71 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
fares
Level 1 Expert
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
