Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Delonghi magnifica esam 4200 lost bar pressure for frothing milk
Does not froth milk properly due to a serious lack of pressure from when operating previously
  • DeLonghi Master
  • 1,711 Answers
The most possible problem is that the machine have build up scale both in boiler and in pipe system. Your are still in good chance to solve it easily since it operates normal by performing a good descaling of the machine. You can buy a very good product posibly from ebay like the Urnex DEZCAL which is an excelent descaler and if you perform a couple of descling procedures in a period of one week your machine will perfom better and better.
Posted on Oct 31, 2012
5 Suggested Answers
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
SOURCE: Delonghi Magnifica Coffee Maker the milk is not
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Posted on Oct 08, 2009
#1 Taper
  • 1040 Answers
SOURCE: Delonghi Magnifica Rapid Cappuccino machine has
Your problem is the holes in the cappuccino maker and
steam nozzle are clogged. Clean the holes in the cappuccino maker and the steam nozzle.
IMPORTANT: Before cleaning the holes in the steam nozzle, make sure that there that it is not hot and there is no pressure on the machine.
I'm sending you a free pdf manual download of what I believe to be your machine. If this is not it, give me the model # and I will try to find it.
Good Luck!
Jim
Posted on Oct 01, 2010
  • 586 Answers
SOURCE: Delonghi ESAM3500 with not froth milk. Water will
Hello there,
Make sure that the milk container lid is clean; rise it vigorously with hot water, Make sure that you are only using 2% milk and Make sure that it's cold 2% milk.
Once that is checked, and not to be the problem, then it requires you to replace the coupling block.
There are many possible points that you may have the leak. The pump, boiler, volumetric dozer, water/steam valve are connected together with Teflon pipes and supports at the ends with the clips and one "o" ring. In one of this point the clip can slip out so the Teflon hose to be loose and so the leak which is at the point which you can see. There are also some cases if the machine is more that 2-3 years one of the above parts to leak itself due to tearing out and it might need to be replaced. So you need to remove first the top panel and then the side panel and work the machine with extra safety since we have power wires and with visual check to find the point of leak.
If it is just the Teflon pipe and clip slip out the secure it back again, if it one of the part you can try to tight up and if the leak insist then you need to replace it.
Would be glad to know if the information was helpful to you. All the best Elect_Comp
Posted on Sep 26, 2011
I have a Delonghi PrimaDonna ESAM 6600. Just recently it stopped frothing milk. To explain fully, I have outlined the sequence of the fault below and resolution steps that I have already tried.
That sounds like the spout is blocked, when the pump goes quiet it is because it has built up pressure and the solenoid is barely moving. Have a probe up the nozzle and see what happens.
Jun 29, 2015 | DeLonghi Coffee Makers & Espresso Machines
Delonghi esam 5600 will not froth milk
Here is the manual:
http://www.delonghi.com/Global/InstructionManuals/EN/ESAM5600%20Intro%20EN.pdf
Two causes from the troubleshooting section:
The froth regulator is incorrectly adjusted. • Adjust following the instructions in the section on preparing drinks with milk.
The milk container lid is dirty. • Clean the milkcontainer lidasdescribedin the section "Cleaning the milk container".
Feb 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
Delonghi magnifica promblems with water and milk
Frothing jug
For milk frothing issues, soak the milk jug cover in hot water and rinse several times. If it has a froth control that can be removed by sliding in the direction of travel towards the edge whilst jiggling it gently up and down. Clean off the little o-ring with a toothpick, be gentle. The control should easily slide and click back in place when done.
Froth still no good? Examine the milk coupling to ensure the o-rings are in the right spot and are pliable and undamaged. There should be an o-ring (usually green) on the top spigot, a (black) o-ring at the front of the bottom spigot and a (red) oring at the rear. The groove halfway along the spigot should be clear. Now with the toothpick and a hot moist cloth clean all the crud from the milk coupling, especially inside the smaller spigot. Check the tiny hole at the back of the larger spigot is not blocked.
Check the flow from the hot water spout is good. If not, there are internal issues, try descaling. If it is, test the frothing jug, if it is still weak either the jug cover or the milk coupling needs to be replaced. Get them to try a known good test jug at your local coffee service center to find out which, most will be happy to do this at the counter.
Jan 19, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
After frothing the milk it can take ages to reset back to prepare black coffee again. Both lights flash green for up to 15minutes before being ready to make another cup. Does anyone know why?
Hi Jan, This happens because the machine is too hot, due to higher heat being required for the frothing. After frothing, press the button as if you would want to brew a cup,I should blink. At that very same time, turn the steam knob fully open to let some steam out, ,which will lower the inside temperature. This should solve your issue.. Good luck, Claudio
Dec 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Magnifier doesn't get enough steam to warm milk or froth milk
sounds like you need it stripped down and serviced ... bsc appliances bristol 07779933829 postal service too.fully trained by delonghi.
Feb 16, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
There is no milk coming out of the frothing part of the Delonghi Coffee Maker, it just makes a noise and steam comes out.
If no milk comes out of frother, check the o-ring on the upper "plug" where the milk jar connects to the machine. There are two connectors; only the bottom one corresponds to the steam output while the upper one is a plug. Mine had a worn out o-ring on the plug, and this keeps the machine from frothing milk.
May 17, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica 3500 not frothing
use cold low fat milk and keep the milk container in the frig.
Make certain that when washing water come out of both holes.
Jul 09, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
I have a Delonghi Magnifica Rialto EAM4500 coffee maker. Recently it has stopped frothing milk. Per delonghi I have replaced all of the gaskets that connect between the milk container and the unit. When we...
Apr 09, 2009 | DeLonghi Coffee Makers & Espresso Machines
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
1,060 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
