Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Whirlpool dishwasher drainage problem..
My whirlpool dishwasher is 4 yeras old. I am having following problem with it. The clean cycle starts fine. water intake is fine. Cleaning cycle is fine.water drainage the first time is fine. I checked that complete water was drained first time. after that more water intake was fine. rinse cycle was fine. but the final water drainage cycle does not happen. I am confused as the ist water drainage cycle is fine then why the 2nd drainage cycle is not working. Pls help. Thanks. -IA
    Problem Solver:
This sounds like a bad timer. The timer is what tells the pump to drain at specified times. If it gets a bad contact, that timed cycle won't happen.
PS: Do you know for sure that the drain is occurring in mid-cycle? If not, you may just have an obstruction in the drain and/or anti-siphon valve (where the hose connects under the dishwasher.
Posted on Jan 03, 2008
SOURCE:
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
Whirlpool Aqua Steam dishwasher, coming up for 3 years old, starts cycle but gets stuck with fault code F4. Have cleaned it out and persisted and it did drain but once again went to F4
You have actually posted your Dishwasher problem onto the (garment) Washing machine forum!
However I have checked my Whirlpool list for dishwashers and for some models 'F4' stands for 'drainage' (as you have checked) but for others it mentions (quote) 'no heat, relay, NTC (thermostat), connections, underfilling are all possible'(unquote).
When there is an NTC problem with washing machines we often suggest pouring the contents of a couple of boiling kettles into the washer as it sometimes kicks the NTC into life! Might be worth doing that with your dishwasher before calling for service ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 19, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Start / resume light blinks. dishwasher won't cycle
my dishwasher runs through the cycle as normal for 20mins and then starts bleeping nonstop. opening the door the start light flashes without any pauses and the light above prewash is on. my engineer cnat figure this out as the flashing has no pauses. help.
Jul 02, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Starts but will not go into wash cycle
My solution to this problem was to simply unplug the power from the wall for a few seconds...plug back in, try to cycle again and the wash cycle starts fine now. May have been caught in a cycle loop or something. Any way this solution worked for me hope it works for someone else.
May 23, 2010 | Whirlpool GU2400XTPS Built-in Dishwasher
Our less than 1 year old Whirlpool dishwasher model DU1145XTPQA is taking as much as 2 and 3/4 hrs. to complete the entire dishwashing (normal)cycle. This is much longer than it used to take.
Contact Whirlpool service immediately to get a service call scheduled before the warranty expires.
Most dishwashers that begin taking longer to complete the cycle have a failed heating element but that also normally means that the dishes do not get fully clean and the glassware has a film on it after the cycle ends.
Good Luck!
Apr 07, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
I have a whirlpool Dishwasher and it will not turn on?
keep the start button pressed in - the machine will empty out the water and cancel the cycle....then start over again.
Jan 07, 2009 | Whirlpool 24 in. DU948PWPQ Built-in...
Broken dishwahser
Check to see if there is a waste basin at the bottom of your dishwasher. Some models have them and they require regular maintenance / cleaning every 6 months or so. If one does not exist, try to purchase one of the JetDry Dishwasher cleaner and set your dishwasher to run at its hottest (usually "pots and pans" or "extra hot") for about 2 cycles. That should clean the drain of the large food particles that have accumulated in the dishwasher drainage. Should the above not provide satisfactory results, you may want to try a VERY SMALL AMOUNT of drain cleaner in the middle of an empty cycle to try and remove the debris. (CAUTION: too much drain cleaner will damage the waste bin if not rinsed properly and render your dishwasher useless..please only do this at your own risk)
Jul 24, 2007 | Whirlpool 24 in. ADG6340 Built-in...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
834 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
