Question about Epson WorkForce Pro GT-S50 Scanner, 600 dpi, Gray
Fe : fatal error
When i press the scan button, i get fe: falal error on screen
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
In display shown FE
"FE" error code - over flow error
-Check water conection
-Check Water valve for proper operation
When the "FE" error code is displayed the drain pump will be turned on to pump the water out of the washing machine. LG Washing Machine Error Codes
This error code comes up when there is a over flow condition. The error is coming up because a part inside the washer has failed. I suspect the water valve on the back may be the culprit, it's fairly common.
Hope helps.
Aug 10, 2011 | Washing Machines
How do I change the default file format from Jpeg to PDF on a xerox M24??
The following information provides an Overview of the Printer's available Scan Settings. 1. To enter the Scan mode, from the Printer's Main (Copy) Screen press the Menu button.
2. On the two-button selection screen, press the right-hand Scan/E-mail button. Note: If you press the lefthand "Copy" button by mistake you will be returned to the Main (Copy) Screen. You will then have to press the Menu button again to return to the two-button selection screen.
3. The Scan screen consists of three Tabs, with each Tab displaying a number of feature settings. From left to right, the three Tabs are labeled: Basic Scanning, Scan Options, and Image Quality/File Format.
4. When the Basic Scanning Tab is selected, three columns of settings are displayed. The first (left-hand) column of settings contains four "Output Color" selections, including: Auto, Full Color, Grayscale (256G), and Black. The second (center) column of settings displays four scan resolutions. The available selections include: 200 dpi, 300 dpi, 400 dpi, and 600 dpi. The third (right-hand) column of settings displays "2 Sided Original" selections including: 1 Sided, 2 Sided (H to H), 2 Sided (H to T), and More.... If you press More..., a screen displays with two setting selection buttons on the left, enabling you to select either 1 Sided or 2 Sided. If you choose 1 Sided, you can select an original orientation of Head to Top, or Head to Left. If you choose 2 Sided, two additional orientation buttons (Head to Head, and Head to Toe) become available for your selection. Note: To support "2 Sided" (Duplex) Scanning you will need to use the Printer's Duplex Automatic Document Feeder. When changing or viewing More... settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
5. After an Output Color is selected from the first column of the Basic Scanning Tab, and the Image Quality/File Format Tab is pressed, a screen is displayed allowing you to choose and configure the settings for Original Type (Text & Photo, Text, Photo), Image Compression (High, Normal, Low), Contrast, File Format, and Auto Exposure.
- Press the Original Type button to select the most effective scanning for your original image type. Options are Text & Photo, Text, and Photo. - Press the File Format button to select your scanned file format. Options are TIFF/JPEG, JPEG, DocuWorks, and PDF. - Press the Lighter/Darker/Contrast button to adjust scanned image density (lightness and darkness) and contrast. Use the supplied arrows to make the desired setting adjustments. - Press the Image Compression button to set the degree of data compression, used especially with JPEG scans. Options are High, Normal (default), and Low. - Press the Auto Exposure button to enable or disable this scanning feature with the ON or OFF buttons. When changing or viewing settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
Mar 28, 2011 | Xerox Workcentre M24 Color Copier
My Acer Laptop opens and runs for about 5 minutes...then goes to blue screen of death with c000021ls windows logon process system process falal error...and shuts down.
Hello
To solve this problem i do the following steps
Rebooted the system and continued pressing F8 -> got a screen that allowed for a F1: Boot -> did the F1 and continued pressing F8 and got the Safe Mode screen -> selected the Last Know Good Configuration and repeatedly pressed Ctrl+Shift+Esc sequence -> Windows XP loaded correctly! -> opened the C drive ->windows folder ->system32 folder ->restore folder -> and started the rstrui application -> selected a date prior to the download of the bad files -> and now the problem is all gone!
Hope it helps, if so do rate the solution.
Good Luck
Dec 22, 2010 | Acer TravelMate 4010 Notebook
Falal error 173 on oki c5650 after changing fuser unit
Cause:
This error indicates that the Image Drum Up/Down Process is not working properly.
The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Resolution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
http://my.okidata.com/PP-C7200.nsf?opendatabase
Apr 23, 2010 | OKI C5650n LED Laser Printer
Program factory remote keyless entry for 2003 Hyundai XG350
This bulletin supersedes TSB# 02-90-001.
DESCRIPTION: The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03
or newer) and Data Link Connector (DLC) Cable. SERVICE INFORMATION: The keyless adapter cable can be used on the following vehicles:
  • 2001 - 2004 MY Elantra
  • 2001 - 2004 MY Santa Fe
  • 2002 - 2004 MY Sonata
  • 2001 - 2004 MY XG300/350 0390020a.gif
NOTE
  • The 2003 - 2004 MY Tiburon does not need the Keyless Adapter Cable to add keyless entry remotes to the factory security system. Instead, the Hi-Scan Pro connects to the vehicle using only the DLC cable. See page BE-60 in the 2004 MY Tiburon Shop Manual for the latest instructions.
  • The most current Keyless Adapter Cable Instructions are available in the following shop manuals:
SHOP MANUAL
PAGES
2004 MY Elantra
BE-73 - BE-74
2004 MY Santa Fe
BE-43 - BE-44
2004 MY Sonata
BE-40 - BE-41
2004 MY XG350
BE-46 - BE-47
KEYLESS ADAPTER CABLE INSTRUCTIONS:
  1. Connect the keyless adapter cable to the Hi-Scan Pro DLC cable. 0390020b.gif
  2. Plug the keyless adapter into the vehicle's 10-pin multi-purpose connector located behind the driver's side lower instrument panel (next to the DLC). NOTE Sample vehicle shown is the Santa Fe.
  3. Turn the Hi-Scan Pro ON
    and press ENTER
    . NOTE "Release date 29. Sep. 2003" OR LATER
    must appear on this screen. To update your SOL card with the latest software go to www.hmaservice.com and refer to TSB 00-00-001.
  4. Select option "HYUNDAI VEHICLE DIAGNOSIS"
    and press ENTER
  5. Select vehicle model and press ENTER
  6. Select option "TRANSMITTER CODE SAVING"
    and press ENTER
  7. Ensure that the key has been removed from the ignition cylinder before proceeding. 0390020h.gif
  8. Follow the steps noted on the Hi-Scan Pro screen to program the remote(s). NOTE The factory security system can only be programmed to accept two remote transmitters and MUST be programmed for both remote transmitters at the same time.
  9. Press ESC
    on the Hi-Scan Pro and verify that the remote(s) are functioning properly.
  10. Turn the Hi-Scan Pro OFF
    and disconnect the adapter cable from the multi-purpose connector.
May 22, 2009 | Hyundai Motor 2003 XG350
Olympus FE-310
The reset option is located when you hit the Menu button when in shooting mode - it is on the left hand side of the screen. You would click Reset and press Ok. It will show Reset Yes or No. Select Yes and press Ok. The camera will now be in factory default settings.
Jan 15, 2009 | Olympus FE-310 Digital Camera
Copier light will scan but will not print.
Black toner supply mechanism malfunction. It could be a bad toner cartridge.
Nov 19, 2008 | Office Equipment & Supplies
Olympus fe-210 screen probloms
try the power reset by pressing the power button for about 10 seconds with batteries out... if this does not work then repair
Aug 30, 2008 | Olympus FE-210 Digital Camera
Epson WorkForce Pro GT-S50 Scanner, 600 dpi, Gray Logo
122 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
