Question about MTX Thunder 4122 Car Audio Amplifier
Hooking up sub woofer to mtx thunder 4122 - MTX Thunder 4122 Car Audio Amplifier
  • 19 Answers
SOURCE: mtx thunder 1501d
Noise from an amp setup (often a buzzing or hum) is often the result of something being grounded that shouldn't be, or that a ground or power connection is not as secure as it should be. Check for proper, clean and solid connections.
Posted on Dec 03, 2008
  • 149 Answers
SOURCE: MTX Thunder problem
Make sure that your connection at the battery is still good-sometimes the wire corrodes up front when your system is installed for a long time-so check that out and of course the fuse that you installed a foot away from the battery so that you dont burn your vehicle down if a short occurs somewhere down the line
Posted on Jun 04, 2009
thepot
  • 188 Answers
SOURCE: Sub not working and red light on amp stays on?
the amp is under to much pressure get a bigger 1
Posted on Nov 18, 2009
SOURCE: MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Posted on Jan 23, 2010
kcarmax
  • 30 Answers
SOURCE: i have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Posted on Mar 01, 2010
I just bought 2 12 inch mtx thunder tc512 to replace my old school mtx blue thunders, everything worked great, but when i hooked up the new 12s i get nothing, zero, zip, nadda, there is nothing wrong
use a d cell battery and touch + of speaker to + of battery and hold it by doin the same with the -'s too if move they work if not there junk
Sep 09, 2012 | MTX Car Audio & Video
What is best way to wire 2 mtx thunder 4500's to a kenwood kac-7205? thanks! james
I would hook up the subs in parallel set up. Lower the resistance causes the amp to create more power to the amp. Your amp can handle 2 ohm load so from my stand point it is best to set up this way. Here is the link that displays how to set up subs:
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Feb 12, 2011 | MTX Thunder 4500 T4510-04 Car Subwoofer
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
How do i wire up my mtx 15 5500 sub woofer dual voice coil any one know i have tried several ways
there are several ways, it all depends on the bass response you want, and with that, it also changes the ohms in the amp. i'm going to give you seval ways to hook them up. if you are running more than one just follow these steps per sub. the first one is if your sub is dual 2 ohm. Wiring Option #2
1_2ohmdvc_1ohm.gif Wiring Option #2
this is for dual 4 ohm coils
1_4ohmdvc_2ohm.gif Wiring Option #2
Mar 06, 2010 | MTX Thunder 5500 T5510-04 Car Subwoofer
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
Jan 23, 2010 | MTX Thunder 81000D Car Audio Amplifier
Nov 18, 2009 | MTX Thunder 421D Car Audio Amplifier
My friend sold me his subs today and one sub doesn't work. they're mtx thunder 8000 will mtx fix the sub for me?
They probally would, but i just found that sub for 51.00 im sure it would cost that and more to have.it fixed
Nov 09, 2009 | MTX Thunder 8000 T8104 Car Subwoofer
Carlos
i have a 81000d for sale for 250 dollars car money still in perfect condition i am pushing 3 12 inch alpine type r subs
Apr 25, 2008 | MTX Thunder 81000D Car Audio Amplifier
Mtx 895 trouble
check your fuse up front first. some amps will turn the light on with only the remote wire (the 12 volt signal from the head unit). That may be your issue. If not you need to check your signal input. try hooking the rca's to a diffrent source, i.e. other radio your tv anything with Rca out put. If still you get nothing then pull your subs out and take a regular 9 volt battery and touch the leads to the positive and negative of the sub. Just for a moment though if the subs move when they come in contact with the charge from the battery then my last suggestion would be to take it to a store where you can have an authorized tech check out the equiptment. Good luck
Nov 19, 2007 | MTX Thunder 895 Car Audio Amplifier
MTX Thunder 4122 Car Audio Amplifier Logo
56 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
