I need a schematic diagram of philips tv 21PT2001/71R
My power supply stages burned i need a value of wornd parts
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
You are going to find no paper schematics are available--only on the internet to authorized Philips service centers with a user name and password to access the Philips database.
Posted on Oct 31, 2012
4 Suggested Answers
  • 556 Answers
SOURCE: Resistor R410, in schematic diagram FILE NAME: power, for TV Samsung CK-5339ZB was burn, I replace with new one, but it burn again. What can be reason for this
if you are talking about vertical section 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. hope this will help. as per schematic diagram go to www.serviceinfo.com good luck
Posted on Oct 06, 2007
  • 346 Answers
SOURCE: finding a schematic diagram
www.samswebsite.com
Posted on Mar 18, 2008
  • 63 Answers
SOURCE: Schematic diagram of Philips 28PT4403/43 TV.
have you tried scribd dot com.........
Posted on Jun 30, 2010
Do you have Inotech color tv schematic diagram model no it-29?
I need 29" inotech crt tv schematic diagram(it -29).I need to replace a burned resistor but can not see the value.It's causing pincushion destortion on picture.
Aug 17, 2014 | Televison & Video
Power supply
What is the brand name and model number to your TV? Provide more details please. To give you the proper value of that resistor, i must get its position or part number. for more information go to http://electronicshelponline.blogspot.com/. It has schematic diagrams to many popular TVs' power supply. Hopes, it might help you.
Nov 12, 2013 | Televison & Video
Sanyo crt tv model st-21cf1 all burned resistor....may i ask what is the value of resistors
To which section circuit you are referring here? Power supply regulator section? If you wish to get some information, check the link below. It has schematic diagrams to Power Supply Regulator sections to some popular brand TVs. http://electronicshelponline.blogspot.com/
Philips md#32PT9100D/37 will not turn on only
Hi
Your tv set may have a short circuit both in the power supply and horizontal output stage. The first approach I suggest is to check the rectifier fast diode in the line supply (90/100V) for short. This model is prone to burn this component and may be associated with some problem in the horizontal output or even in the RGB output.
I would like to point out that this task require a technician as should be supported with a schematic of this model.
If this is helpful, I shall be glad.
Sully
Sep 22, 2013 | Philips Televison & Video
I HAVE A PHILIPS TV THE POWER SUPPLY WAS BURNED ONE PART I CANNOT READ WHAT COMPONENT WAS DAMAGED, I NEED SCHEMATIC DIAGRAM SO THAT I DETERMINE THE SEMICONDUCTOR COMPONENT THE IS 25PT463A/71R THANKS
Try this site .They should be able to get it. www.service manual.net.As info be sure to check all your caps for swelling as it is a common problem.I have had to replace 5 in my samsung 50" screen.
Apr 27, 2011 | Philips Televison & Video
Philips 105E
I have philips monitor 107E there is a supply problem i want to repair it. I need circiut diagram for repair.
May 28, 2009 | Philips 107E61 17" CRT Monitor
POWER SUPPLY BAD, NEED SCHEMATIC DIAGRAM COMPONENT LEVEL
Polaroid will not release component schematics not even to service centers as they are designed to replace the entire modules while under warranty out of warranty there is very little Chance of obtaining new replacement parts. As i have a 2006 LCD and a 2007 Plasma Polaroids and polaroid told me they are considered a disposable TV replacement parts are not available and suggested that I try ebay
Apr 29, 2009 | Televison & Video
In need of the wiring diagram with values
contact the company that makes the amplifier. I have bought schematics from car stereo manufacturers before, it shouldn't be a problem.
Mar 28, 2009 | Philips GEMINI XG-3001 Fan...
P4004 - Blown Components
if burned components are on output stage or amplifier section on board..Then look at the oposite side of amp..Both amplifier section should be a mirror image oof componentc from other..that way you can know the values of parts.If they are on power supply section ..Then you might need manual if available..
Dec 23, 2007 | Rockford Fosgate Punch P4004 Car Audio...
I see only horizontal line on TV Samsung CK-5339ZB
h/line is due to vertical section failure. 1 reduce brightness as you will get h/line due to vertical failure. 2 check v/section for loose contact or yoke connection. 3 check supply to vertical section. 4 check associated parts in v.section 5 at last check for vertical ic. resistor R410 CONNECTED TO high voltage transformator T444 is low value resistor. .5ohm to 10 ohm. it burnt again due to short cht in vertical mainly due to ic. hope this will help. as per schematic diagram go to www.serviceinfo.com
Oct 04, 2007 | Samsung TXN3271HF 32" TV
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
Electro Med Services...
