I need a replacement stand for my Toshiba Regza 26 inch TV. (26A3030DG) No longer want it wall mounted
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The only one who may have this part is Toshiba, worth a phone call to find out.
Posted on Oct 31, 2012
SOURCE: toshiba 52 inch flatscreen
I have just completed removing tha base from a Toshiba 52 inch HDTV. There are 5 screws in total. Three about 8 inches form the base and another 2 about 4 inches from the base in the arrangement shown below
(X) is a screw
(l) center line
X X X 3 screws 8 inches from base
X l X 2 screws 4 inches from base
______l______ The base
Keep your feet clear as your undoing the last screw..the base slides out vertically downward and weighs about 10-15 pounds so keep your the toes, fingers etc safe. The risk of being sued may explain why Toshiba didn't this publish in the US manual.
Posted on Mar 03, 2008
SOURCE: taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
Posted on May 17, 2009
welcomejee
  • 10594 Answers
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
Posted on May 18, 2009
ldaala
  • 65 Answers
SOURCE: need screw size for 26" niko tv stand. to mount the tv to the stand
man i looked and couldnt find a size but here is a number to a company who might can tell u, its called peerless mounts 1-800-473-3753 good luck
Posted on May 26, 2009
  • 5 Answers
SOURCE: I have a Toshiba Regza 42HL67US
First you should lay the unit face down on a blanket or the like, being careful NOT to damage the screen. I don't have one in front of me right now but if memory serves well, there is a plastic cover on the back side of the base that you can pop off giving you access to the base mounting screws. Remove the 4 screws and viola, the base should slide off.
Posted on Jul 21, 2010
Remove stand on Toshiba TV
To disassemble it, you have to see some illustrations. If you wish to get more details about how to disassemble Toshiba TV, check this link. http://electronicshelponline.blogspot.com/ Pull up older posts there. Disassemble procedure to many TVs are given in detail, with illustrations.
Jun 13, 2013 | Toshiba REGZA 47HL167 TV
How do i get the stand off so that i can mount the tv on my wall
Lay down the tv picture screen on a soft flat surface.Check all the screws holes and take out all the screws.Take ur hand holding on to the tv and base stand tight.Pushes in and out few times.The base stand should came wright out..
Dec 24, 2010 | Toshiba Regza 42RV535U 42 in. LCD HDTV
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
What is the correct wall mount for this tv? and cheapest too! westinghouse sk26H730S tv (26 inch lcd tv)
You dont need a correct one you just need one wall mount that can fit 26 - 30 inch search wall mount on trademe or ebay realy cheap and they can ship it down to you thats the cheapest way
Aug 01, 2009 | Westinghouse Electric SK-26H730S 26 in....
Cant get my stand of my tv to mount it on the wall can you help?
If you turn the set over you will see a set of screws attached to the bottom of the stand (inside hollow area). There also two screws I believe on the back of the unit near the stand area that need to come out. The stand should come off now. But do you really want to mount it on the wall?
Oh well,
Hope this helps
Skyassoc
Jun 22, 2009 | Toshiba REGZA 47HL167 TV
Taking stand off toshiba regza tv
Jan 25, 2009 | Toshiba REGZA 47HL167 TV
Tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Sep 01, 2008 | Insignia LCDTV26 26 in. Television
Removal of stand
There are 5 screws in the back of the TV, immediately above the stand. From the stand, they are at the 10:00, 11:00, 12:00, 1:00, and 2:00 locations. If you remove the screw, and find a washer with the screw, then it's probably the right one. Once all 5 screws are removed, the stand slides right off the bottom. Unfortunately, once the stand is removed, the opening is left in the bottom. It's not too bad since once it's mounted to the wall, it's not high enough to see the bottom of the TV anyway. Good luck!
Aug 09, 2008 | Toshiba REGZA 47HL167 TV
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Electro Med Services...
