Question about Claude Valentini Watches
How do i change battery in my claude valentini watch
Model number cl700
A Geneva watch model number 10026 water proof to replace battery
I only suggest you have watch service shop do the battery change, if you try to remove the back cover chances are unless you know what is what you will seriously damage the watch finish.
Mar 28, 2017 | Geneva Watches
Battery indicator issue
Although your watch is solar-power all Eco-Drive watches contain a rechargeable battery known as a capacitor. They last longer than a regular battery but are difficult to get replaced because nobody carries them. Firstly I assure you whoever opened the watch did damage it. The solar sell is under the dial so removing the back would not have exposed it to anything. Rechargeable batteries do not hold a charge forever and do need to be replaced every 5-10 years. In order to know which capacitor you need you need to find out what movement model is in the watch (this is different than the model number of the watch you must physically look at the movement) (unlike batteries capacitors all have the same number on the cell so you need to know the movement number to order the proper size). Once you have obtained the capacitor repairing your watch because no more difficult then changing a battery. I'd ask those people to take the back off again so you can find out what movement is in the watch. Typically it's a 4 digit number but sometimes it also has letters in front of it and I've also seen them with only 3 digits. If you could supply me with the movement number I can supply you with a the proper capacitor at a price of $45 with free shipping and tracking.
Dec 26, 2013 | Citizen Skyhawk A-T Watch for Men
Armani Exchange Watches AX2072
Je cherche un notice d'utilisation de la montre Armani Exchange AX2077.
Merci pour votre aide
Claude
Nov 21, 2013 | Armani Exchange Watches
I have a timex watch with both analogue and digital.... only the digital is working after a battery change. What do you recommend
Take the battery out again and let the watch "rest" for a couple of hours without the battery. That sometimes resets the Quartz mechanism, and will allow a clean restart. Also, refer to the following info if needed.
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Sep 05, 2010 | Timex Watches
What battery number and type for a colt chrono
Depends on the year. Google however is your friend Google Breitling Source and the watch type and see which year yours is.
Assuming its a 2006 to 2010 model it takes a 394 battery. I suggest a google to Breitling source and look in the watch archives there.
Consider sending it to breitling UK, you have a watch worth at least many hundreds of pounds that is waterproof. If you nip down the local muppets he will change the battery and charge you GBP20 not GBP70 but he will not change the case seals or pressure test the watch to ensure the seals are doing their job. Worst case you write off the watch when it gets wet or when you next get sweaty which is the same thing.
Specify you want the battery change service only and thats what Breitling do.
Good luck whatever you do.
Oct 15, 2009 | Breitling Colt GMT 292/SLV/FGHT Wrist...
How do I change the quartz battery on a Longines La Grande Class
Just unscrew the screw at the back if your model have screw if not the other one snap to open.Use a pocket knife then open it look the number battery and replaced it with same number battery. Its you use Renata battery it is swiss 3years to last.
Hope it may helps;
Regards;
VOTIT
Jun 16, 2009 | Longines La Grande Classique L4.709.2.42.9...
Need instructions manual for my solsuno watch
you can go to solsunoworld.com and visit the order page, you will find the instruction next to any genuine solsuno, our movment is used by zeon for their zeon tech
You can contact me for info via solsunoworld.com
Claude
Mar 28, 2009 | Watches
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
105 people viewed this question
Top Claude Valentini Watches Experts
Jimmy Accardi
Are you a Claude Valentini Watch Expert? Answer questions, earn points and help others
