Question about Honda Eu2000i 2000w Generator
Screeching sound-Honda eu2000i
Generator making a screeching sound. Been running for 4 hours or so, just started making the sound
  • 512 Answers
Sounds like a bearing has failed or something has gotten inside the generator or engine area where it spins and is now rubbing against it. There is a bearing at the far end of the generator from the motor and it is most likely to be where the noise is coming from. Best to repair it before it seizes and wears out parts you don't want to have to try to find!
Posted on Nov 06, 2012
I have a deep eu2000i inverter, the problem is to remove the carburetor throttle, it takes some kind of setting as to start the engine low speed, and connect a tool fails ....
if your question is that my Honda generator wont idle up when I connect a load (tool) and it stalls then . first see if unit will run on constant setting (switch on front) if nothing or still barely runs or stalls , then your problem is carb or fuel filter (inside tank) one or both is most likely dirty and needs replaced/cleaned
Oct 15, 2016 | Honda EU2000i Companion Inverter Generator...
What do I check? i have a honda eu2000i that starts and runs but no generator power
The internal monitor is sensing a load does a load make it change tone? Check the 12 v output and see if it is loaded.
Kevin H
Sep 08, 2014 | Honda Eu2000i 2000w Generator
I have a Honda eu2000i generator to run a Husky TAW-1524p air compressor. Initial start/run is fine but subsequent compressor restarts as demand for air is required, put the generator into overload....
If your mechanical enough to figure out how to lower the air pressure switch on the compressor it would help with start up loads. For instances if your pressure switch is set for 75 psi. Lower this to 60 psi. or as low as you can and still operate equipment. Otherwise depending what horsepower and voltage {guessing 110 vac) the motor is, I would try an Hard start capacitor for refrigerators or air conditioners. They are rated by horsepower and have a built in relay that kicks it off automatically after starting . You can find these at any appliance or a/c & heating supply house.
May 11, 2014 | Heating & Cooling
Honda generator
The running on choke is caused by a fuel restriction. Check the fuel flow from the tank to the carburetor.Change the fuel filter if it has one. If its good, then the restriction is in the carburetor. The generator is shutting down due to the low rpm coming from the engine. A carburetor rebuild may need to be done.
Oct 19, 2013 | Electrical Supplies
I have a eu2000i honda generator that will not start. It is getting spark and will fire when I put a little gas in the cylinder. It is obviously not getting gas, but I don't know what to do about
needle valve stuck.on the bottom of the carb there is a bolt holding the bowl. inside there is a needle valve attached to the float. hondas have a spring loaded rubber tipped needle valve and tends to get stuck in storage(unless it is left empty this will happen almost every time) check seals on bolt and bowl before re installing .
Jan 27, 2013 | Motorcycles
Honda generator starts, runs, then stalls and backfires
Honda makes quite good gasoline motors. I doubt it is a valve timing issue but it might be a burned valve or a valve adjustment issue. What does after a while mean? A couple of minutes or 4 hours? Is it running for just a short while and then stops or it runs well for a long time and then stops?
Aug 01, 2012 | Honda Generator Eb4000x Eb5000x Eb6500x...
Honda EU2000i with a washing machine
Yes - it will be a fine machine to have and do well.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore Washing Machines
Open Questions:
See all Honda Eu2000i 2000w Generator Questions
Honda Eu2000i 2000w Generator Logo
188 people viewed this question
Top Honda Electronics - Others Experts
John
Level 1 Expert
Bill Boyd
ray gallant
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
