Question about Ignition System for Chevrolet Monte Carlo
2000 chevy monte carlo key wouldnt turn in ignition
Car would not turn ignition will open doors and trunk
    Top Expert:
  • Chevrolet Master
  • 76,630 Answers
Has the battery been removed and tested? If not do that first. Autozone and others do the testing for free.
Posted on Nov 05, 2012
Key wont turn in ignition but works in trunk and doors
Could be a damaged lock cylinder, or excessive pressure on the lock from the steering wheel or shifter.
Dec 09, 2012 | 2000 Chevrolet Monte Carlo
97 chevy monte carlo trunk pops open and locks lock and unlock on their own while car is runnning and off
I have a 97 Monte Carlo that has locked me out a number of times. I have never experienced the trunk doing it's own thing. What I have done is simply remove the fuse to the power door locks. I drive it to work and am usually the only rider so no big hassle for passengers.
Feb 22, 2011 | 1997 Chevrolet Monte Carlo
03 chevy monte carlo can't turn key
Tumblers are going bad. Get a locksmith or dealer to replace.
Apr 15, 2010 | 2003 Chevrolet Monte Carlo
Ingition key will not turn 2003 chevy monte carlo
WD-40 Put key in the ignition, RAP while trying to turn. Also get a new key cut by code. Maybe your key is worn
Mar 26, 2010 | 2003 Chevrolet Monte Carlo
Why does my 2003 chevy monte carlo trunk light stay on and beep
the trunk ajar latch switch is defective, it is signaling the system the trunk is open when it is indeed closed
Feb 12, 2010 | 2003 Chevrolet Monte Carlo
How do i program keyless entry remotes on a 1995 Chevy Monte Carlo
open the trunk, pull the carpet back, were the radio antenna is you will see a single wire connector. take a jumper wire and hook to this connector and ground it to the radio antenna. you should here your door lock, it should lock and unlock at this time press any key on the remote and you should here the locks activate again . then unhook the connector from ground and try your remote it should be programed now.
Jan 10, 2010 | 1995 Chevrolet Monte Carlo
2005 monte carlo keyless remote does not open doors ? batt is goo
remote key fobs very sensitive & not durable.You probally need a new remote.Try E-Bay much cheaper than chevy store.They will need to be programmed to you car when you get them.chevy for that.hope this helps
May 15, 2009 | 2005 Chevrolet Monte Carlo
Key will not turn in the ignition 2003 Monte Carlo SS
Be sure its all the way in park or try neutral.Its possible that security system does not recognize the key. Is security light flashing or on steady? Shut all doors and windows,trunk,hood, turn off all accessory's,roll down drivers window, turn key off and remove for at least 1 minute, insert key into ignition, try to start leaving key to run position for 20 minutes, turn key to off,wait 15 seconds, try to start again leaving key to run, wait 20 minutes, turn key off,wait 15 seconds, try to start, This should relearn key code. It may relearn after 1 learn cycle and start if system is ok. Hope this helps and that the weather is dry and warm for this procedure!.. i think this may solve ur problem..
thank u rate me!!!
Feb 10, 2009 | 2006 Chevrolet Monte Carlo
Ignition System for Chevrolet Monte Carlo Logo
164 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
