Question about IBM SureMark Printer TF6 Thermal Label
Does any one have a 64 bit version of IBM suremark 4610-TF6 thermal receipt printer, please help
The current available version works for only 32 bit version and i tried to install it in a 64 bit system and it failed. any suggestions please
3 Suggested Answers
SOURCE: driver IBM printer 4610 suremark for windows xp
You can find the driver here: http://www-01.ibm.com/support/docview.wss?rs=219&uid=pos1R4000123
Posted on Dec 09, 2009
micromatikal
  • 2777 Answers
SOURCE: I have a 4610-TF6 thermal
If it is in the same exact spot every time it is not just a cleaning issue, although it wouldn't hurt to try I suppose. Do you know how to get to the thermal print head? Try rubbing a q-tip soaked in rubbing alcohol on the print head.... If it doesn't make a difference, which I don't think it will, the print head will need to be replaced.
Thanks, let me know! Just reply here
Tim
Posted on Oct 26, 2010
As the tickets print there is a blank line through the receipt. I was told at one time that this is because of the thermal head. How do we fix this?
Clean the thermal head surface.... If the line is still there, then the driver for the head probably has a shorted device. This will require repair at a shop capable of this work.
May 22, 2010 | IBM SureMark Printer TF6 Thermal Label
Stopped printing
reinstall your program for printer.if it dont work.
printer is bad.let me know.ok
Jul 21, 2009 | IBM SureMark Printer TF6 Thermal Label
Printing only one side
Most likely the small 'roller' on the LHS of the paper feed shaft is missing. This roller engages the metal 'yoke' on the LHS when the printer lid closes and provides a suitable pressure for the paper to contact the thermal head. They break into 2 pieces sometimes and fall away from the shaft. Solution: remove circlip and replace the roller if you can get one. I have them made.
Mar 26, 2009 | IBM SureMark Printer TF6 Thermal Label
Printers Spew out 18" of journal tape every morning x 8 registers
Talk to the software suppliers on your Tills, they may have an idea.
Jun 17, 2017 | IBM SureMark Printer TF6 Thermal Label
Cannot get printer to print
very possible but you may need to disable the firewall if you have one then disable the antivirus . then try to reinstall software for the printer and follow directions closely. biigg53566
Dec 05, 2008 | IBM SureMark Printer TF6 Thermal Label
IBM 4610 suremark receipt printer
Hello all,
had the same problem and my solution was to install the latest driver available at the IBM service/driver website. Then unistall it with another IBM driver cleaning tool, then repeat both processes a couple of times, until the printer responded. There is some bug on these latest drivers an older Windows versions, so only after some installations and repairs on the first install, windows gets it right. VERY STRANGE but it worked in 2 machines, both IBM terminal and 4610-tf6 IBM printer.
By the way; RS232 ibm cable...I believe its a null modem 9 pin...not a regular serial cable.
Dip pin config: my printers have 4 so; 1ON 2ON 3OFF 4OFF which means
1 size of paper you are using 80mm
2 if you use an IBM software or other:other
3 if xon/off or DTR/DSR:hardware
4 com speed: 9600baud or 19200baud, 9600
That's what I igured out. If you need any more info: mail
fit.frederico@gmail.com
FredP
Sep 28, 2008 | IBM SureMark Printer TF6 Thermal Label
IBM SureMark Printer TF6 Thermal Label Logo
105 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
