Question about Panasonic DMRES15 DVD Recorder
Not an easy one to answer. I seem to be following the instructions, yet I cannot connect my DMR ES15 to my tv. I have the white,red and yellow leads, yet it mentions a blue,green and white lead. Is this the problem? There no request for scart leads so none are attached. There's a freeview box too. Currently I'm still getting tv pictures, but no dvd. HELPPPPPPPPPPPPPPPPPPPPPPPPPPPPP!
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Yellow is composite video, the red and white are audio
Blue, green and while are component connections (in US white would be red)
Posted on Oct 31, 2012
3 Suggested Answers
SOURCE: No picture when connecting CRT TV to Panasonic DVD/VHS Combo
If you combo get activated the progresive scan function you never see the videio only sound you need to deactivate
Posted on Feb 14, 2009
sonicboomele
  • 1557 Answers
SOURCE: hi there, please can you
you need to change the settings in the dvd player menu to cyoma or nstc rca
Posted on Dec 22, 2010
I'm trying to connect my camcorder with the red/yellow/white lead however my lg tv doesn't seem have these sockets to plug into. It has two AV sockets one says rgb the other has two input sockets one
You are probably looking at a component input, which is a high definition set up. Often the red/yellow/white (or composite) inputs on newer TV's are located on the side for easy access. Check both the left and right side of the set to see if thats where they are.
if they are not there, what model LG TV do you have?
Nov 23, 2014 | LG LM6700 47 in. Cinema 3D Smart TV
Which cable should be hook up to tv. Trying to hook up DVD player. I have cable with Red, white, yellow.
hi that"s easy thing. first connect rca wire red white yellow to dvd hook up same colour red white & yellow female rca connection. then use another rca wire connect to your tv be video input in yellow one . red & white be sound input - red to red . white to white. just that. good luck!!
Jun 03, 2011 | JVC C-13920 TV
How to connect to an analog tv
Try to locate the composite video/audio in(1) and audio (2) out sockets of your tv.
(1): three small round sockets, one yellow, one white, one red (2): two small round sockets, red and white. (only if you want sound from your tv on your marantz receiver)
You will need a composite audio/video cable: 51433a4.jpg
and a composite audio cable: db5db51.jpg
Connect the composite video/audio cable (1):
the yellow lead to MULTI OUT (yellow) the white lead to MULTI OUT (white) the red lead to MULTI OUT (red)
on your tv: connect these cables to the respective yellow, red and white input. (there should be a text like: game in/dvd in/ext in/AV-1/VCR) If all you see at the back is a big socket like this one: 0f41fcb.jpg
you will need a SCART-to-composite adapter, like this:
(2) To get audio from your tv to your Marantz, locate an 'audio out' (red + white round connectors) on your tv, and connect these pins using cable (2) to TV (complete bottom left on your Marantz).
Dec 13, 2009 | Marantz SR7002 6.1 Channels Receiver
I am trying to play back video from Sony Handycam on tv, the sound is perfect but i have no picture, im sure it must be something simple. i have handycam a/v out attached to the yellow red and white...
    First remember that the "Yellow" is for video signals the Red and White are for audio.
    first connect the camera leads directly to the TV. First yellow connector of camera attach with the "Video in" of Tv and same as Red and White of camera as Audio IN of Tv. And you will both get sound and audio.
     Now same as connect the camera connectors Yellow in Video In of the DVD and Red & White For Audio In in the DVD, Now a new lead connect to DVD out Video "yellow pin" to the TV Video IN ans same as Red & Whit in TV IN. By this procedure you will get the Video and Audio from your camera.
     Hope this will help you.
     Thanks.
Dec 01, 2009 | Sony Handycam DCR-TRV245 Digital-8 Digital...
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
No colour when watching dvds ok for everything elese
You will have to make sure you are connecting them with the red and white cables on audio and the yellow on video at both ends, as both your dvd and tv have low def and hi def cabling options.
That means Red and White to Audio at each end and Yellow to video at both ends. If you connect the yellow cable to one of the other three connectors at iether end you will only get black and white as they are meant for a different type of connection.
To get the maximum quality out of your sets you may want to purchase a set of Hi-Definition Component cables which will give you a set of five cables, still red and white for audio but now red, green, blue for video.
Hope this heps a bit more,
Chris
Apr 30, 2009 | Panasonic DMR-ES35VS
How can i connect the dmres15 to my cable box, dvd/vhs player
Yea I have the same set up and did the same thing as that your trying to do and what you have to do is run both the cable box and the VCR through your TV using the inputs. As well as a PS2 running through imput 3.
Hope I helped
Jan 30, 2009 | Panasonic DMRES15 DVD Recorder
Panasonic DMR ES20DEB blank screen but sound
THE CONNECTION HAS BEN CHANGED FROM AV CONNECTION (RED, WHITE, YELLOW ) TO COMPONENT CABLE (RED, GREEN, BLUE) YOU WOULD HAVE TO SOMEHOW RESET THE DVR TO DEFAULT SETTINGS TO GET IT BACK TO NORMAL.
Nov 11, 2008 | Panasonic DMR-ES20EG DVD Recorder
DMR-EH50
Check the cable eventually try a replacement cable.
Nov 04, 2008 | Panasonic DMR-E50 DVD Recorder
DMR-E50 DVD recorder versus DMR-ES15 are these equivalent recorders
The DMR-ES15 is a later model (around 2006/07) than the DMR-E50 (2003/04), but essentially both should do the same job so technically - a good equivalent in terms of recording and same brand so yes. The connections on the rear (of the replacement recorder) should suit and work with your other devices just as the old one did.
According to some other online reviews, the DMR-E50 has had a few issues with recording, and finalizing certain discs.
I'd say go for it - accept the replacement - as long as it comes with some kind of guarantee, works fully and has all the accessories (including remote, instructions etc.) you should be good. Contact the store and seal the deal.
I hope you can get this in time for Christmas.
Dec 21, 2017 | Panasonic DMR-E50 DVD Recorder
Panasonic DMRES15 DVD Recorder Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
