Question about Air Conditioning and Heat for Buick Enclave
Heated seat shuts off
Hi There, the driver side heated seat shuts off after 2 minutes. This just started happening after I had it serviced about 2 weeks ago. What do I look for?
  • 3 more comments
  • Tom Chichester Nov 03, 2012
    Can you tell us the year of your Buick Enclave?
  • trbujold
    trbujold Nov 03, 2012
    Hi Tom, it's a 2009. I so miss my heat.
  • Tom Chichester Nov 04, 2012
    Something may have been dsturbed when your Enclave was in for service. The fuse must be OK, otherwise the seat heater would not work at all. If the heat is programmable, I would have the service people check the problem area
  • yadayada
    yadayada Nov 06, 2012
    There is a pouint whwre a manmade thing works tha a pouint where is doean
  • yadayada
    doesn't. I think you wouls lose in court on this one.
    Top Expert:
  • Buick Master
  • 76,132 Answers
The most common cause of this problemis that the heated seat heating grid in the seat cushion is shorted or an open circuit. You need the dealer to test the grid and see if it is any good.
Posted on Nov 05, 2012
  • Tom Chichester Nov 06, 2012
    I still think maybe something went awry when she had it in for service
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
The driver door on my 2010 Volkswagen Passat Sedan Komfort doesn't always latch shut.
The latch sounds like it could use wd40 or some kind of lubercant and have the pin checked to see if there is any ware on it, if there is then you may need new hinges and a pin for the latch.
Jan 28, 2014 | Cars & Trucks
Heat on drivers side but not on passengers side
Have to remove the seat & replace the blower
The dealers usually have seat people that come in
one day a week after the service bays close,like 5:30
to 8:30 at night
Could be a seat control module or other
neat little semi conductors hidding in the back of the seat
Need pro scan software to get enhanced codes
A repair shop may do seat work,would be cheaper
Nov 29, 2012 | 2007 Toyota RAV4
I got new brake pads fitted three weeks ago and noticed the drivers side where only wearing down on one side of pad im looking for advice why this happening
Sounds like the piston which supplies pressure to the pad is not functioning properly or the pad was not seated properly. Return to the place that serviced the brakes and have them fix it.
Oct 10, 2011 | Cars & Trucks
I have a 2005 Chevy Silverado whose driver side seat warmer goes on by itself. It may cycle through all of the settings and turn off but usually will immediately turn itself on again. No amount of manual...
May be a slight short in the switch/button. Enough that it cycles the settings or just stays on. If you want it to stay off for now, look for a fuse or relay to pull. Come to think of it, might be a bad relay. If there is one for each seat, try swapping them out and see if the problem starts on the other seat. If it follows the relay, then there's your problem.
Apr 28, 2017 | 2005 Chevrolet Silverado
I have a 2004 Chevy Silverado. The heated seat on the drivers side does not work. When you push the button to turn it on, the lights come on briefly then turn off.
Would you say it stays on about 30 seconds and does the passenger side do the same thing? If possible retrieving the codes will narrow down the search for a correct solution.If the passenger side is ok we may be able to eliminate the passenger side as bring part of the problem.Please advise so will know which way to go with your solution.
Condition/Concern:
Driver and passenger heated seats inoperative or shut off in 30 seconds. There will be DTCs B2435, B2440, B3606 and/or B1825 set in the Drivers Seat Module. The adjustable pedal position sensor, seat recliner position sensor and both heat seat thermistors share the same 5 volt reference internal to the Drivers Seat Module. A fault in any of these components/circuits can make the heated seats inoperative or shut off in 30 seconds, as well as, the seat recliner and/or adjustment pedals may move in short increments when operated. A fault in heated seats, adjustable pedal or seat recliner will affect BOTH heated seats.
Note:: Even if the vehicle is not equipped with adjustable pedals DTC B3606 still may set.
To help isolate the area of concern use the Tech 2 or a comparable scanner and go to "Sensor Data" in the Drivers Seat Module. Monitor the following parameters for being out of range:
Recline Position- Normal range .39V-4.58V
Pedal Position (if equipped) - Normal range .39V-4.58V
Psgr. Seat Heat Sensor- Normal range 1V-4V
Drvr. Seat Heat Sensor- Normal range 1V-4V
If a parameter is found to be out of range inspect circuits for any opens, shorts to ground, or voltage. If none found replace the suspect component.
Please be aware of the following common areas of concern:
  1. The adjustable pedal position sensor internally shorted pulling the 5 volt reference low. Disconnect the adjustable pedal position sensor and see if the heated seats start working correctly, if so replace. Note Important:: The APP (Accelerator Pedal Position) sensor is NOT the adjustable pedal position sensor. Make sure the correct sensor, adjustable pedal position sensor, is disconnected.
  2. The seat recliner position sensor internally shorted pulling the 5 volt reference low. Disconnect the recliner position sensor and see if heated seats start working correctly, if so replace.
  3. An open in either heated seat thermistor circuits (signal or low reference). The most common is the passenger thermistor where it passes through seat connector C305 pin "L" or "K" or C399 pins "R" or "G".
  4. A chaff to ground on either heated seat thermistor signal circuits. The most common is circuit 5475 black/red or dark blue shorted to ground in the passenger seat near the buckle. Note Important:: The heated seat thermistors act differently to "OPENS and SHORTS" than the adjustable pedal position sensor and seat recliner position sensor. The adjustable pedals and seat recliner sensors can be disconnected for testing of the heated seats. Where as the heated seat thermistor circuit must be working correctly before EITHER heated seat will operate. Disconnecting one thermistor, which may have a concern will not allow the opposite heated seat to work correctly, BOTH side must be operational before EITHER heated seat will operate.
Clearing DTCs
If DTCs will not clear when using the Tech 2 or comaparable scanner after a repair has been made, try operating the device in which the repair was made. Example, if a repair was made to the passenger heated seat thermistor circuit, the DTCs may not clear unless the passenger heated seat is operated.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Nov 17, 2010 | 2004 Chevrolet Silverado 2500HD
Driver side heated seats keep coming on when they want to, on my 2005 Chevy Suburban Z71. They get really hot. I have found that if you leave the base of the seat on the low seating then the back or lumbar...
The problem could be the drivers seat module.It is under the seat and controls the drivers seat functions.There is a service bulletin for seats that will only work for a few minutes and then shut off by themselves.The fix for this is having the drivers seat module reprogrammed but I don`t know if your problem would fall in this bulletin.Only the dealerships can program these modules.Hope this helps.Good luck.
Feb 04, 2010 | 2005 Chevrolet Suburban
2003 chevy Avalanche. The heated seat shut off prematurly.
There is a service bulletin for this concern from GM.What you will have to do is go to the dealership and they will reprogram the drivers seat module.It should only take a 1/2 hour.The bulletin number is 05-08-50-008.Hope this helps.Good luck.
Dec 24, 2009 | 2003 Chevrolet Avalanche
2003 Suburban---Heated leather seat problem
there may be a software issue, there is a reprogram for seat heater issues. Bulletin 05-08-50-008 may pertain to that, a AC DELCO Shop or the dealer can ck that and see if this bulletin applies.
Sep 29, 2009 | 2003 Chevrolet Suburban 1500
Buick Lesabre Heated Seats not working
The problem is most likely caused by shorted heating grids in the seat cushion itself, kind of like the heating element in an electric blanket, very expensive to replace.
Dec 12, 2008 | 2003 Buick LeSabre
Air Conditioning and Heat for Buick Enclave Logo
356 people viewed this question
Top Buick Vehicle Parts & Accessories Experts
Marc Taylor
Thomas Perkins
Thomas Perkins
Jeff Turcotte
Jeff Turcotte
Are you a Buick Vehicle Part and Accessory Expert? Answer questions, earn points and help others
