Question about Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY DOOR LOCK
Purchased a Garrison keyless entry deadbolt lock - the programming code does not work - how can I program my lock?
When trying to programming a user code I realise the programming code does not work. What can I do about this?
4 Suggested Answers
leafsveteran
  • 74 Answers
SOURCE: Kwik Set keyless entry lock. We
With the door open so u dont get locked out,did u remove the batterys and try to re-set your door code ?
Posted on Dec 18, 2010
  • 1751 Answers
SOURCE: I have a Sclage Plymouth deadbolt lock system
The only man that can do this
is the one that you bought it from
all the others way are against the low and
can not be righting in this site
Posted on Jan 03, 2011
  • 963 Answers
SOURCE: I have a touchpad Zurich
I have been searched unsuccessfully for "Zurich deadbolt keyless remote" in order to help you. However, if the picture shown in your request is accurate for your lock, I have found some information which may be useful to you!
The brand that I found is Lockstate, which looks like the lockset pictured. Go to this webpage (copy & paste into your browser search window):
http://www.lockstate.com/manuals-and-downloads.html?start=10
Go to the bottom of that page, to "LOCK LS-DBS" and click on Download. This will download a PDF file of the installation and programming instructions.
If you cannot open and view the download, you will need to download and install Adobe Reader. You can get it here:
http://get.adobe.com/reader/
If this is not the correct information for your lock, please re-submit the problem and I'll try again. Any further model info, etc., will be helpful.
Good luck--and please provide feedback if this helps!
Posted on Aug 26, 2011
Is there a warranty on keyless entry locks if deadbolt weld breaks
You need to contact the supplier or manufacturer and ask them.
Dec 16, 2017 | Heating & Cooling
Hi, We are in high Wycombe, Bucks', I have stupidly bought a Bose music system on eBay and now realise that the units cd doesn't work. Is it poss to repair Awr3cp unit.
Hello Chris
I corrected your spelling of 'nose' to 'Bose' to help future Fixya users looking for help.
Repairs are done direct from Bose. Here is the link to Support. Try a Product Reset which you will find when you click through to your product.
Bose Product Support
Andrew - Fixya Moderator
Nov 15, 2016 | Audio Players & Recorders
Where do i find the english instructions for installing Garrison keyless entry deadbolt lock? 046-2667-4. Got only french in box
Is this model sold in the USA or Canada? If not then you may have a problem getting the booklet in English. You could post the instructions and then use google to translate them.
Aug 12, 2016 | Deadbolt Locks & Locksmithing
How can i drill a hole into my keepsafe wall safe to open it?
Keep the drill motor in the toolbox, you'll likely just ruin the safe.
Go here instead: https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
There are 3 possible ways to unlock and access
the safe:
1. Factory code
(Found on the first page of the factory guide) You can
always open the safe by entering the pre-set 5-digit
factory code. This code cannot be deleted.
2. User code
If you prefer to employ your own code, you can
program the safe to open using a 5-digit user code
of your choice.
3. User pin
If you wish to give someone else temporary access
to the safe, you can program a 5-digit user pin that
can later be erased.
Programming the user code
NOTE: One (1) user code is allowed.
To add:
1. Press the Prog key , then enter the 5-digit
factory code.
2. Enter the 5-digit user code of your choice.
To delete:
1. Press the Prog key.
2. Enter the 5-digit factory code twice.
Programming user pin
NOTE: One (1) user pin is allowed.
To add:
1. Press the Prog key 2 times.
2. Enter your 5-digit user code.
3. Enter the 5-digit user pin of your choice.
To delete:
3. Enter 0, 0, 0, 0, 0.
NOTE: If your safe does not appear to be working,
please check batteries before calling Sentry
Customer Care.
Jul 26, 2014 | Sentry KeepSafe Combination Fire Safe 12...
Casio TE-2400 cancel button wont work,
This is not a programing problem . Please consult a qualified technician. Or try to re-allocate the cancel button somewhere on the keyboard
Nov 06, 2013 | Retail Supplies
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
We have a garrison keyless entry deadbolt lock with remote entry. when we press the unlock on remote it locks and when we press the loke button it unlocks. If we press the onlock button on keypad it u
If you remove the inside housing from the door, and look inside on the left hand side of the circuit board, you will find a slot marked "L R".
Slide the switch to the opposite of what it is set for. This will solve the problem.
Jan 14, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY DOOR LOCK Logo
1,830 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
David Belitz
David Belitz
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
