Question about Canon PIXMA MP210 Photo All-In-One Printer
I can't use my Scanner. there is always appears a note that the printer is in use.. etc.
  • 673 Answers
An unfinished printing task might be in pending. Clear them from the system. Then it will scan.
Posted on Oct 30, 2012
12/24/2012: XBOX 360/RB3-WIRELESS FENDER MUSTANG PRO-GUITAR: WON'T PLAY "FRET NOTES"
If your guitar was not purchased new (since it was hard to find these guitars late in the life cycle) then perhaps it was already faulty before you received it.
Dec 25, 2012 | Mad Catz Rock Band 3 Wireless Fender...
Hp printer 1312 fadad print how to fix
Check any refilled cartridges?.. No.Go to main menu select default setting.. check for the quality..No..
Need to clean reflecting mirrors in scanner assembly..Only professionals can perform this activity..
Remove right, left & back doors..
Detach the cable which came from flat bed assembly, remove two screws back side just below of flat bed, gently push flat bed assm back to front, lift & take out the flat bad unit.. remove upper cover, you can observe the scanner assm ( see the snap shot) "Note: to take out scanner assm cartridge & cartridge bank must be present in to the printer to prevent the damage to transfer kit, other wise scanner will fall down on transfer belt" Unlock & remove scanner secure pins(4nos), detach scanner flat cable connected to DC controller, take out scanner assm, open the bonnet of scanner assm, clean surface of the mirrors very very gently with ear buds.Don't disturb any factory settings, once its cleaned refix every thing back.. "Note: scanner flat cable which is connected to DC controller is not that much lengthy, before powering on check once cable connected in properly or not, if any thing goes wrong in this area printer wont power on & it may damages the DC controller or scanner assm .." But I am sure that only professional can perform this activity, if you are not qualified pl don't try it..5_25_2012_8_24_06_pm.jpg
May 25, 2012 | HP LaserJet CM1312 All-In-One Printer
Scanner error 5
The only fix that I know is to get the scanner/copier assembly(that's the assembly at the very top where the copier is) replaced.
I don't imagine that it is cheap. Get an estimate 1st.
Nov 12, 2011 | HP LaserJet 3055 All-In-One Printer
Scanner Error 5
Remove flat bed glass take out optical scanning assembly(detach flat cabl & belt).gently hold the unit & remove bannet of the unit care fully clean the reflecting glasses with ear buds gently. fix it back & clen flat bed glass both surface with glass cleaner fix every thing back,take care of finger prints not to print on glass, check if not resolved replace optical scanner assm.Note:technical skills & patiency required to do this process ..Best of luck
Oct 11, 2011 | HP LaserJet M1522nf Multifunction Printer...
Hp laserjet 4345 when scanning from adf copies too light
Take copy with default settings, if quality is poor, need to clean inner parts like reflecting glass, engine reflector of optical scanner assm(CCD)..& flat bed glasses both sides.
Note: with out proper knowledge pl don't open this printer..
Sep 30, 2011 | HP LaserJet 4345mfp Printer
It says connect cable to computer but will not scan. When you try and access menu or settings in scan mode does not appear
un-install & re-install driver of your printer; if driver still having the same problem for vista & windows 7, try downloading windows update & check the OS if it has available driver for printer.
May 12, 2011 | Office Equipment & Supplies
How do i reset my printer? it always shows a LOW TONER, even though it was newly refilled. There is also a vertical line that appears on the side everytime I copy something (photocopy).
Step 1: Toner Reset Menu for Brother HL 3040CN and HL 3070CW
1. Open Cover where you can access toner cartridges
2. Press CANCEL & SECURE PRINT buttons at the same time and you'll see
the toner menus on the screen
3. Press + or - to navigate through to the toners you need to reset.
Note that each toner has 2 entries here, reset them both (STD means Standard, STR means Starter)
4. The OK button will reset of the toners.
Apr 18, 2011 | Brother DCP 9010CN - multifunction ( /...
The scanner won't scan to the computer, but when I test it in scanners & cameras it says it is working.
This is my solution :
1st step : Turn on your *HP Deskjet F4185*.
2nd step : Click the Start menu.
3rd step : Click Devices and printers. A new window will appear.
4th step : Then, click the "Fax button ".The window Fax and Scan window will appear.
5th step : On the lower left corner , click "Scan" below the "Fax" button.Scanned documents (if there's any) will appear.
6th step : Click "New scan" button below the "File" button. And your printer will start! Glad to help..
Mar 29, 2010 | HP DeskJet F380 All-In-One Printer
Canon Pixma MP198 error code 2 114 0
i got a same prob..i can't print,scan and copy and the refill warning always appeared..i hv refill the cartridge and i shut it down and try again and again..it's the cartridge prob or the printer prob..?
Feb 21, 2010 | Canon PIXMA MP190 All-In-One InkJet...
EPSON PX700W
I would take them out and double check for any remaining packing material etc and then make sure they are fully inserted. The simple things are always the ones to start with
Sep 26, 2009 | OKI C3200n Led Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
14 people viewed this question
old marine
old marine
