Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Is there anyway to test start relay for a freezer
Not sure if this is exactly the right freezer, but the model number is FFU20FC4AW2. The freezer runs but doesn't cool. I checked the start relay and the capacitance is right, but is it possible that the relay is still bad?
  • Jeff Pippin Nov 02, 2012
    Okay, thanks for everyone's help, I'll try these solutions and let you all know what I find.
  • Jeff Pippin Nov 09, 2012
    This isn't the problem, checked the condenser and it looks almost brand new, no dust!
  • Official Brand Answer
  • 4,342 Answers
Hello - When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
Posted on Nov 02, 2012
    Thanks for everyone's solutions, will try them and see if any of them are viable solutions to my problem
3 Suggested Answers
diths_kri
  • 67 Answers
SOURCE: Frigidaire Upright freezer FFU20FC4AW2
Sounds like the timer could be getting stuck and not releasing the defrost cycle
Posted on Jan 07, 2009
oldTech2332
  • 2341 Answers
SOURCE: I have model TFU12MOAW3 upright freezer and it
The relay can be tested by putting meter leads in the 2 holes on it where it attaches to the compressor and it should be closed (zero ohms of resistiance) if you have the rectangle one thats how to test it. If its older style and has the wire coils on top of it must turn it upside down but still closed w/zero ohms.
to test overload thermostat disconnect it from compressor and it to should be closed with zero ohms from spade to where wire connects to hole where it connects onto prong on compressor.
both the realy and overload should be removed from compessor to test
if both check good test compressor by one meter lead on prong where overload fits onto and other on one then the other prong. Both the start and run winding on compressor should be between 5-20 ohms if either is open compressor is dead
Gene
Posted on Aug 12, 2011
Testimonial: "Thanks for the help, I should get the freezer back in operation soon."
Where is the control knob for Frigidaire upright freezer Model No FFU20FC4AW2
It is on the back wall, about 2/3 of the way to the floor on the right hand side... Knob will look like this: Frigidaire Freezer Control Knob 216707200
You probably have food in front of it!
Jul 31, 2016 | Frigidaire Freezers
Why Frigidaire Upright freezer FFU20FC4AW2 compressor starts and stops
Hello Friend, thank you for your question!
From what you have described it sounds like the compressor is cycling on when cooling is necessary and cycles off when the temperature inside your freezer has reached the set temperature. This is normal. If you feel that there may be some other issue occurring, feel free to go to the manufacturer website where you can easily locate a service provider in your area.
Jul 14, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
I have model TFU12MOAW3 upright freezer and it does not run. I tested the voltage from the freezer control to the compressor relay and I have 120 volts. Could tell me how I can test this relay (P/N...
Gene
Aug 12, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Chest freezer power light on, run light off and all my food is defrosted. How do I fix it
Take off the service panel and check for the compressor running. Can you place your hand on
it or is it too hot. If it is you might change the relay to the compressor.Take your model no. to your local parts store and they will help you look at the part and exactly where it is located (on the compressor) Easy change out.
If the compressor is not running at all then remove the two wires to the thermostat and plug them
together (They will plug together if you turn one backwards and plug it into the other.)
Make sure you have unplugged the freezer while you are doing this.
Now you have routed around the thermostat.
If it runs then replace the thermostat and youre done!
If not after the relay and thermostat check it wont run then you have a bad compressor.
On the relay ask for a hard start relay for a freezer or ref. at the parts store. They know exactly
what it is. Its even easier to install. Don't be shy to repair this. You can do it or condemn it
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Magic Chef Freezers
Power off for electrical repair. Plugged floor freezer back in and a loud buzzing noise is ongoing. Not sure if this is a temperature alert or if there is another problem. Thanks for your help.
This sounds as if its a start relay problem. They are attached to the compressor
You will need the model and serial number to get a new one at the appliance
parts store. They are usually under a plastic cover on the side of the compressor
and the cover is retained by a metal spring clip. Remember to unplug unit before
replacing this part. The model and serial number should be located near the compressor.
May 04, 2011 | GE Freezer  14.8 Cu. Ft. Manual...
I have a Kenmore 5 freezer, model 253.9135180. It's several years old granted but was working fine until 2 weeks ago. I unplugged it because it was clicking every minute or so like it was trying to turn...
Good day,
The clicking sound is the compressor trying to start and can't. The relay is clipped onto the side of the compressor and can be removed by pulling the relay off the compressor once the retrainer clamps are removed.
You can take the relay to most appliance parts houses. They Will be more than happy to test it. If it tests bad, replace it. If not, I'm afraid it is probably an internal problem with the compressor itself, and you will need to call a qualified tech since it will take special tools to test it.
Nov 10, 2010 | Kenmore 5 cu. ft. / 142 liter Upright...
Freezer fan on compressor off
They make generic "compressor packs" to solve these. Your capacitors and relay and parts that support the compressor operation went out.
If you're really really like just the temp overload switch went and you can jumper bypass it. It usually looks like a piezo electric type of disc connected right onto the comp case itself.
But you're right with the DT, the motors go out on them a lot. They are usually for 4/6/10/12 hours depending on make and model. Sometimes the contacts go So if you could isolate them... they're on the larger side and will go from the power to the compressor. Use a jumper and test for a complete circuit to the plug and through the compressor before trying it.
By law all freezers and ovens have to have a schematic diagram on them. Often it it in a little plastic package and sometimes just wallpapered to the inside of a large piece of sheetmetal in back.
Good that you know how to use a meter!
Jul 13, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore Chest Freezer Model number 1987191852 has started to defrost own its own. Compressor starts and shuts down after appx 2 seconds. Has this unit reached the end? is it cost effective to repair?
Good day,
That short cycle you hear, is the compressor trying to start, and can't.
It is possible one of the start components has failed. Under a cover on the side of the compressor are either 3 or 2 components.
The start relay, the protective overload and on some models a start/run capacitor. These components can be removed by pulling them off of the pins of the compressor.
Most appliance parts houses will be glad to test them for you. Replace any that test bad.
If all test O.K. then it is an internal problem with the compressor itself, which would take the services of a trained tech and pretty pricey.
Apr 11, 2010 | Kenmore Freezers
My freezer needs new door seal . Where can I purchase one on line
depending on your exact model,
most brands and mkaes of gaskets can be ordered
www.appliancepartspros.com
type in your model number on the home search page
look at whichever door you need on the left
then look for the gasket below with the right part number
hope this help
usually ships in 24 hrs
Oct 19, 2009 | Freezers
Sounds like the timer could be getting stuck and not releasing the defrost cycle. If you have to do it again, you should have the timer checked, or just replace it.
Jan 02, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
734 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
