Question about Acer Aspire One PC Notebook
Acer/aspire 5742z Pxe-E61 media test failure,check cable,no bootable device-insert boot disk how to fix ? no boot disk
Turned off computer and when turn back on did not start. finally tryed to recover using recovery disks had created when done with disks. now getting problem i listed
freetek
  • 5568 Answers
SOURCE: Aspire 5315, no bootable device, PXE-E61 media test failure,
With any standard laptop (your Aspire included) the default boot disk should be set to drive C:
If the system is not finding drive C:, the boot sector may be damage or the drive may have failed completely.
Depending on your operating system (probably Win XP for this one) you can make a boot disk on a friend's optical drive and change the boot sequence in the BIOS setup to your optical drive. Just make sure the disk you've made is compatible with the drive in your Aspire; such as CD - DVD+-, etc.
Once you can get some kind of prompt, either from a basic Desktop or just E:\ from your boot CD, try typing in "C:" (without the quotes) to see if it is accessible. If not, the drive may be bad.
If the drive is still readable, you have more work to do to restore the damaged boot sector.
Posted on Mar 21, 2009
zabolyx
  • 38 Answers
SOURCE: comp won't boot
This could also happen if the hard drive is dead and trying to boot the next item or the BIOS has the Netboot option set as the first boot device.
Jump into your BIOS and make sure that the boot order is CDROM then USB then HDD. Then try again. Let us know what happens.
Posted on Apr 02, 2009
  • 13433 Answers
SOURCE: my acer aspire 5315 is stuck n i have no disk to reformat
the computer can't detect the hard drive to start from it or, then theres a problem with your windows. Use the recovery discs or windows setup cd to try to install windows to the computer again to fix the problem. Let me know how that goes. Thanks
Posted on Jun 07, 2009
corahudo
  • 3 Answers
SOURCE: No bootable device
Do you have the original cds for the computer? If you do, you will hae to download everything beginning with windows whatever you have. Unfortunately eveerything saved on your hard drive will be erased, but your computer should work after completing this.
Posted on Jun 28, 2009
Keynan
  • 977 Answers
SOURCE: PXE-E61 : Media test failure
It sounds like your hard disk has gone, or not being recognized by the computer... Check if it seats well in it's place.
Unfortunately, laptop HDDs don't last long these days.
Posted on Oct 18, 2010
Recover previous bios
Remove the side panel of the computer case, using the screwdriver to unfasten the screws normally located in the back. Remove the jumper from its normal position on the motherboard and place it in the recovery position. Usually, the jumper will need to be moved over one space to cover a previously exposed prong. If the motherboard does not have a jumper, removing the battery for 30 seconds and then replacing it may have the same effect. Insert the BIOS flash disk and power on the computer. If you used a flash tool or utility and did not create a BIOS flash disk before flashing the BIOS, then you will need to do so using a functioning computer. Since there will be no video, listen for the internal PC speaker to beep. This means it is performing the BIOS upgrade. Power down the computer once the BIOS upgrade has been completed. This process may take some time to complete, so be sure to not turn the computer off before the BIOS upgrade is finished. Without video, the only way to be sure is to listen to the PC speaker. When the upgrade is done, the PC speaker will beep again, and the floppy disk drive will turn off. Replace the jumper back in its normal position and put the side panel of the computer back on. Power the computer on. If the computer turns on as normal, the recovery was a success.
Feb 20, 2013 | Computers & Internet
Tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
on Oct 13, 2011 | HP Computers & Internet
Forgot my password to my hp mini window 7 starter
I know a software can hack HP password windows 7,and I used it before,my friend recommended it to me,it is easy to use,and I do it by myself.It seems called Windows Password Recovery Tool 3.0.You can have a try!
For more detail steps on how to reset password on hp laptop, please feel free to visit: http://www.windowspasswordsrecovery.com/hack-hp-computer.htm
Jun 21, 2012 | HP Mini 1000 Netbook
I used the LG smart recovery and backed up my files by clicking system back-up. Then after it changed my files that will open only to window shell commor.? Any idea how to open again my files I badly need...
So did you mean you performed a system restore after you back up your system?If so,you can try a data recovery software to recover your files.I have succeed to recover files after system restore with Tenorshare data recovery.It can recover data after deeply scanning your hard drive to look for lost data.
Anyway,you can download a trial version and scan your hard drive for free to check out whether your files can be recovered.http://www.any-data-recovery.com/index.htm
Jun 25, 2011 | LG Computers & Internet
Reformat my computer to windows 7
ATTENTION!
Reformatting a computer will reset it to the factor image, all data must be backed up or it WILL be lost. There are several reasons to reformat a hard drive. A few reasons include but are not limited to: driver issues, virus, cleaning up, getting rid of the computer, etc.
RECOVERY DISKS!
Every new windows 7 owner should know that the new computers are not supplied with recovery disks anymore. The manufacturer allows the user to create one set of disks upon the purchase of a new machine. It is important to create the disks early as driver issues and viruses may arise. In order to create recovery disks on windows 7 you want to click on the start menu. Next, type in recovery in the Start Search option area. Next, click on recovery disk creation and follow the process. It will require that you have about 3 dvds or about 7 cds to create the recovery disk.
REFORMATING HARD DRIVE!
Once the recovery disks have been made reformatting windows 7 is quite simple. Insert the recovery disks into the cd/dvd tray on the machine. You are now going to want to turn the computer off. When the computer has turned off, go ahead and turn it back on. A screen should pop up asking you whether you want to boot from Hard Drive or Disk. Choose the disk option. After you make it this far it is a downhill process. Next you follow the on-screen instruction make sure you reformat the machine, not recover it.
Apr 14, 2011 | Computers & Internet
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
Jan 13, 2011 | Compaq Presario 5000 PC Desktop
When I start the my pc then in some time one message receive on the screen ltdr is missing press ctrl+alt+del then restart
You are missing the operating system time to re-install the operating system. It is corrupt and will not start windows without the system files. So simply re-install the original software that came with your computer.
Jan 08, 2011 | Computers & Internet
I'm facing major problem of active desktop recovery.Also I'm unable to restore my active desktop.
If all fails, then the last resort would be Reformat Your Computer. Save Everything. When you do a Reformat, all data is lost.
I found this on the web. You can click on the link to see it more in view.
http://www.ehow.com/how_5039946_reformat-windows-vista-computer.html
Step 1 ATTENTION!
Step 2 Recovery Disk Creator
Every new windows vista owner should know that the new computers are not supplied with recovery disks anymore. The manufacturer allows the user to create one set of disks upon the purchase of a new machine. It is important to create the disks early as driver issues and viruses may arise. In order to create recovery disks on windows vista you want to click on the start menu. Next, type in recovery in the Start Search option area. Next, click on recovery disk creation and follow the process. It will require that you have about 3 dvds or about 7 cds to create the recovery disks.
Once the recovery disks have been made reformatting windows vista is quite simple. Insert the recovery disks into the cd/dvd tray on the machine. You are now going to want to turn the computer off. When the computer has turned off, go ahead and turn it back on. A screen should pop up asking you whether you want to boot from Hard Drive or Disk. Choose the disk option. After you make it this far it is a downhill process. Next you follow the on-screen instruction make sure you reformat the machine, not recover it.
Good Luck :0)
Apr 13, 2010 | Microsoft Windows XP Professional SP3 Full...
How to restore my acer aspire 5515 to default mode like i bought it
Reformatting your computer, save everything. You will loose all of your DATA.
Step 1 ATTENTION!
Good Luck :0)
Apr 11, 2010 | Computers & Internet
I have a presariov2000 lap top and I need to restore it to the manufacturer
Recovery Disks No longer come with HP Desktops/Laptops. There is a built-in program in your Program Files that allows the user to create their own set of recovery disks. But you may not need to use the recovery disks to bring the computer back to the manufacturer state. All the Windows XP and programs that come with your computer are on the hard drive on a separate D:RECOVERY partition you can see in My Computer. But you should create the recovery disks in case the Recovery Partition built on your hard drive becomes corrupted.
Several ways to recover your Laptop and how to create a set of Recovery Disks: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00608578&lc=en&dlc=en&cc=us&lang=en&rule=21872&product=500508
Without the Recovery disks:
Right after you turn on your computer, start Tapping the F11 key. Shortly after the HP Logo screen disappears you should enter the System Recovery.
Click next and on the next screen they should be some information about System Recovery. After each screen that you click next (Go Slow so you don't miss it) One of the screens should have 2 options near the top:
System Restore
Advanced Option
At the bottom of this screen will be another Next Button. Do Not click next right away because this will start a "Non-Destructive" Recovery where the computer will only restore Windows files to the factory default but the addition data and programs you or someone may have put on the computer will still be on the computer after this recovery as well as they may not work properly since all the Windows files have been defaulted back to factory settings.
At the top, click Advanced. You should then get an option to perform the "Destructive" Recovery which will recover the computer completely back to Manufacturer Default. Choose the Destructive recovery and click next.
This process can take awhile, let it finish to completion (Do not turn off your computer or stop this process in the middle of the recovery, or you WILL need disks to recover the Laptop)
After it finishes, the computer will prompt you to reboot. Reboot the computer, it will boot you into a new Windows where it will do some final configuration and will be back to the manufacturer default.
Remember, this will wipe out all your data, so if you have anything of importance on the computer, Back up the data first, and its recommened that you do regular backups when the computer is working as well.
Jan 30, 2009 | HP Compaq Presario V2000 Notebook
Acer Aspire One  PC Notebook Logo
208 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
