Question about Frigidaire FFUS2613L Side by Side Refrigerator
Where is the defrost timer located on frigidaire ffus2613ls2
How long before a timer go bad
5 Suggested Answers
  • 531 Answers
SOURCE: defrost timer location
the timer in the refrigerator console were the control is
Posted on Apr 03, 2009
VtToolMan
  • 704 Answers
SOURCE: where is defrost timer located on frigidaire
I couldn't pull up a line drawing for this model, but I recall that on these, (and other fridges of this age and era) had the defrost timer mounted under the front edge of the fridge, just behing the toe kick panel.
Some manufacturers mounted them at the rear behind the thin paperboard "cover", but I'd look for it at the front first.
In either location, it should be mounted behind a metal plate with a small hole in it that has a plastic or metal adjustment shaft that a flat bladed screwdriver slips into to manually advance the cycles.
Just remember to unplug the fridge before you disconnect the timer or attempt to replace it. Once you're done, you can advance the timer to initiate the defrost or cooling cycle, to gets things going.
Hope you find this Very Helpful and best regards!
Posted on Aug 21, 2009
  • 1218 Answers
SOURCE: Frigidaire side by side - replaced defrost timer.
Good day,
Sounds like a bad timer to me. Forget the tstat. Power comes from the power cord and goes directly to the tstat. The tstat sends the power to the timer where it is directed to either the compressor or defrost heaters as needed.
Recheck your plug connector to the timer carefully. I have installed many timers that did not work, or work right, right out of the box.
As well, to cover yourself, I would replace the defrost tstat which is located behind the rear panel in the freezer compartment.
It's a small round disk clipped to the top of the cooling coil, and is the component that is by far, the component that fails most often.
Check the connections to the main heater as well, while your in there.
The defrost tstat looks like this.
Posted on Aug 17, 2010
The defrost doesn't work?
The defrost timer is located behind the toe plate cover on the bottom of the fridge. Take it off to expose the timer. It is probably bound up. Replacing the timer isn't too bad of a job. Get a replacement from an appliance parts store. A screw driver and pliers to pull off the wires from the timer is all you need to replace the timer.
Jul 15, 2015 | Frigidaire Refrigerators
How to fix a bad defrost control timer frigidaire ffu14fk1cw
Good Afternoon Friend,
I understand you want to know how to fix a bad defrost control timer on your Frigidaire freezer, model# FFU14FK1CW. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to fix the defrost control timer with ease. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Freezers
Location of defrost timer on frigidaire model lfus2613f3
Hello Friend, thank you for allowing me to assist you!
It appears that the defrost timer of your Frigidaire refrigerator (LFUS2613F3) uses the main control board to energize defrost. The defrost timer is located at the front of the control console in the fresh food compartment (display that controls all functions). I do hope this information proves to be helpful! - Z
Jun 04, 2014 | Frigidaire FRS26KR4A Side by Side...
Where is defrost timer location on fridgedaire mod # ED25DQXVN00
Your mechanical defrost clock timer is located in the control panel where the rotary knobs are for the ED25 model given which is a Whirlpool SxS, For the Frigidaire Mod FRS, your defrost control will most likely be located in the long housing running down the center wall (front to back) of the fridge near the outlet vent, this is an electronic adaptive defrost control. Pleazer Appliance...
Apr 18, 2014 | Frigidaire FRS26KR4A Side by Side...
Freezer fan keeps running & I have frost buildup
Hello Jerry. Your SXS refrigerator has one of 3 possible problems. 1-the defrost timer is bad. 2-the defrost terminator is bad 3-the defrost heater is bad.
Out of the 3, the most probable is the defrost Terminator, p/n 297216600, $12.00 If this goes bad, and many do, then the refrigerator will not be able to initiate a defrost cycle.
The next likely is the Defrost Timer, p/n 215846602, $ 16.00
To test, using a flat blade screwdriver, located the defrost timer, down on the bottom left side of the refrigerator, and turn the timer until a click is heard. stop turning and check for 120vac on the defrost line at the evaporator. it is either a brown or a pink wire. If you have a non-contact voltage detector, just probe around for voltage. If you have voltage, then you need to replace the defrost terminator. if you have no voltage, replace the defrost timer.
The last possible is the defrost heater. this should ohm out at or around 15k ohms. But in reality, anything other than an open circuit is ok.
Timer, terminator first !
Apr 10, 2014 | Frigidaire FRS20ZSG
Frigidaire side by side - replaced defrost timer. defrosts as should for a few days and then the evap freezes up. After advancing the timer to defrost cycle and powering off and on it will defrost properly...
Good day,
Aug 17, 2010 | Frigidaire Refrigerators
Location of defrost timer for frigidaire side by side
REMOVE BOTTOM FRONT TRIM UNDER FRONT DOORS
THE TIMER I BELIEVE IS ON THE LEFT SIDE YOU WILL SEE TWO PHILIP SCREWS REMOVE AND UNPLUG THE WIRE HARNESS FROM TIMER AND VOILA!
Jan 19, 2010 | Frigidaire Defrost Timer 215846602 ...
Where is the defrost timer located on a Frigidaire model # FRS24WNF?
its a defrost trermostat located near the evaporator coil and defrost heater coil
Oct 24, 2009 | Frigidaire Defrost Timer 215846602 ...
The bottom of my frigidaire is not cooling properly; and the freezer works great; is it a minor problem i can fix
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 19, 2009 | Frigidaire FRT17G4B Top Freezer...
Frigidaire FFUS2613L Side by Side Refrigerator Logo
90 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
