Question about Yamaha HTR-5830 Receiver
Sound problems Can only turn sound up or down manually, will not pick up any remote signal to be turned up or down. remotes will work everything but sound, i believe it is a receiver problem
  • 336 Answers
If the remote can work other functions of the receiver then check the owners manual, it may tell you how to reset the receiver.
Posted on Jan 12, 2009
Sound is pinned at 100% output. Remote nor physical buttons on device are working.
If any of the buttons on the remote or tv work, then try going into the menu and turning the sound down manually.
Jan 08, 2017 | Televison & Video
32'' insignia TV volume stuck down
This may turn out to be a failed component internally.
Dec 31, 2013 | Insignia Televison & Video
Trunk won't open with either remote but will open with trunk button on drivers door
I would check the owners manual or with Cadillac - its possible the remotes lost part of the signal and need to be reset. It sounds like the receiver is not getting a signal from them by using that button.
Could be the receiver too.
Sep 27, 2012 | 2005 Cadillac CTS
I have a Sony CDP-CX350. I recently discovered the remote will not control anything on the player. The remote has fresh batteries and displays that a signal is sent out. The same display usually shows...
If you have turned it back on then this would indicate the receiving module that picks up the infrared signal is not working and has become defective, but I would double check your manual so nothing was over looked.
Jan 30, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
I have a 98 GMC JIMMY. Remotes and Dome Lights stopped working. Car would start then immediately die. Took it to the dealer and they stated it was the Body Control Modual (BMC). Picked up the vehicle...
Keyless Entry System Circuit Description
The Power Door Locks/Remote Keyless Entry control system provides several functions. The driver operates the vehicle door locks and rear window release from outside the vehicle using a hand-held radio transmitter. The transmitter sends coded signals to the remote control door lock receiver. The remote control door lock receiver detects and decodes the signal from the transmitter. The remote control door lock receiver issues signals to the body control module (BCM) through a serial data link. The BCM actuates relays to lock and unlock the doors and liftgate. The BCM can also release the liftglass. The power door lock switches provide manual control of the door locks.
Transmitter Programming
Important: Different keyless entry systems are used on General Motors vehicles. The parts are not interchangeable even though the parts may appear to be similar. Observe the back of the transmitter in order to properly identify the system. On 1998 S/T pickups and utilities, use a transmitter identified with GM/UTA preceding the part number.
With the driver door closed, hold down the power unlock button on the door panel.
Turn the ignition switch to the ON position.
Turn the ignition switch to the OFF position.
Release the power unlock button on the door panel.
The remote control door lock receiver will respond in the following manner in order to indicate that the receiver is in the programming mode:
6.1. Locking the doors
6.2. Unlocking the doors
Important: All extra transmitters must be programmed at this time. When a new transmitter is programmed, it will deactivate the old transmitters.
Hold down the lock and unlock buttons on the transmitter until the remote control door lock receiver will respond in the following manner:
7.1. Locking the doors.
7.2. Unlocking the doors.
Repeat step 7 for each additional transmitter.
Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
May 04, 2017 | 1998 GMC Jimmy
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Infrared sensor won't work in a Toshiba TV
The remote wouldn't work on my brand new 46" Toshiba TV. Comcast person said the tv gave off an infrared signal that interferred with the Comcast remote.
Solution was to turn on cable box FIRST, then TV ( now I use All On button, which turns on cable first). If I turn on TV first, the remote wouldn't work consistently. Hope this works for you.
Aug 09, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
TIVO Remote Control Problem
A similar problem happend to me. Buying a new remote fixed it - for about three weeks.
Maybe your new one will work longer.
Mar 06, 2008 | Tivo DirectTV Remote Remote Control
Remote control no longer responds for Konka K2001UM
You can test the remote by holding it very close to an AM radio receiver and pushing the buttons on the remote. You may have to tune the radio accross the AM bamd to pick up the remote's signal. You should hear a popping sound each time a button is pressed. You need to hold the remote near the tuner of the AM radio. If you can't pick up a signal then you need to replace the remote. If you do pick up a signal then possibly the remote receiver in your TV is bad or the remote is not putting out the proper IR signal. Stargazer
Aug 16, 2007 | Konka K2001UM TV
Remote won't turn on tv
no, there is no fuse on the television that control the remote, there is a component that they call IF means infrared.its a circuit that recieved the signal from the remote,amplify them and convert them to signals then decoded by the system control.if the remote is not working with the two tv then the IF circuit needs to be repaired.since you say that the remote works with the direct tv box.then i could assume that the remote is working.it could also be that the remote is not compatible with the tvs.try getting the the right remotes for the tv and see what happens.if it does not turn the tv on then we safely say it is the IF circuit.then you will have to take your set to a repair tech for repairs.good luck.
Mar 19, 2007 | Sanyo AVM-3259S TV
Yamaha HTR-5830 Receiver Logo
83 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
