Question about Maytag Pye2300ayw Dryer Door Switch Assembly Part 53-0148 Or La-1005
WHY MY MAYTAG DRYER PYE2300AYW WON'T START
It worked fine yesterday but now it won't even start
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Test the thermal fuse on the side of the heater housing. It should read closed for continuity. If open, you will need to replace the kit. Here is a link to the kit you need.
Posted on Oct 31, 2012
  • 6277 Answers
SOURCE: The dryer works fine, but
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer. Also I will have to presume that, as the first fuse was blown/bad, the fault has caused the replacement to go the same way (??)
It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 04, 2011
CRTN
  • 716 Answers
SOURCE: Maytag LSG7800AAW Dryer not working
Its Either One Of Two Problems If Its Electric Its The Thermostat but if its gas it can be either the thermostat or the igniter. If its gas you can watch the igniter or listen to hear if its lighting. If it lights its the thermostat cause if the thermostat is malfunctioning it will turn the gas off when it doesn't detect the flame. It turns the gas off to prevent your home from filling with gas. Hope this helps.
Thanks For Choosing Fixya
Sincerely,
Michael Scott
Posted on Jul 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a maytag Bravo
F-51 RPS senses rotation when basket ought to be stopped.
Posted on May 19, 2011
heatman101
  • 43501 Answers
SOURCE: Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 13, 2011
ginko
  • 19396 Answers
SOURCE: Maytag top-load washer Mod.MTW6600TBO Push to
Hi.
To find the tech sheet you need to remove the top. The top is held by two clips that can be removed using a putty knife.
Regarding the error code F1 means Pressure Signal Out-Of-Range. Some forum incorrectly says that F1 means defective control board. Even if F1 may be caused by defective control its meaning according to service literature is: "F then 1 flashes when the control detects an out of range pressure signal."
Unfortunately the error sometimes occur when control board is faulty. Other times means that there is a clogged pressure hose. In some case the error is caused by use of incorrect detergent that clogs the pressure hose.
• Check pressure hose connection from tub to machine/motor control. Is hose pinched or kinked?
• If F then 1 repeats numerous times after POWER is pressed and the pressure hose connection is not pinched or kinked, replace the machine/motor control.
Here the service manual.
Regards.
Ginko
Posted on Aug 21, 2011
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 | Dryers
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
GE gas dryer won't start
you need a new motor
Apr 11, 2012 | Dryers
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My maytag dryer got to hot heating a blanket and now it won't work at all. When u push the power button I feel it wanting to kick in but it won't do anything!! I know nothing about dryers Help...
heatman101
Jul 04, 2011 | Maytag Dryers
Our 8 year old kenmore dryer won't do anything when you press the start button. We don't hear even a hum. It worked one day and then just wouldn't start the next day. We checked the fuse box...
Here is a good link for basic troubleshooting... But 10 to one the culprit is a thermal fuse or thermal cut off.... they are usually pretty cheap and easy to replace....
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
One final note on these: if you find your thermal fuse\cut off (or element) open, before replacing it, be sure to check the airflow out your dryer's vent system. Even though these devices do 'wear out' with age, poor airflow's the #1 cause of failure of these devices, and if your vent's partially clogged, a new thermal won't last very long, but will do its job again, and leave you 'cold' (a new element won't last long if the vent's clogged, either).
More info and pics:
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Jun 16, 2011 | Kenmore Dryers
When we push the button to start dryer it buzzes, it won't go and won't dry clothes. maytag admiral dryer ADG7005AWW
heatman101
May 19, 2011 | Maytag ADG7005AWW Gas Dryer
My dryer will not start
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 12, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Pye2300ayw Dryer Door Switch Assembly Part 53-0148 Or La-1005 Logo
175 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
