Question about Mitsubishi VS-45607 45" Rear Projection Television
Black Lines goin through screen
Hi, well i just got a older tv it was made in 2001 and somtimes when i turn it on it works fine but there is like a ranbow color on the top but sometimes theres black lines that go through the screen and i cant get them to go away also when i hit the PIP button the screen goes crazy and is all scrambled like and the only way to fix that is unplug it and plug it back in PLEASE HELP ME!!! :)
YOUR TV NEEDS TO BE SERVICED
Posted on Aug 08, 2007
Hello! My Panasonic QuintrixSR picture becomes fuzzy then thick squiggly black lines appear. The whole screen turns black yet sound still on. Can I fix this or is the TV toast? Please help, thanks.
Hi there!
Your tv is not toast yet it can be fixed. get another screen and see if their any changes .if other circuitry are fine your screen should work perfectly
May 18, 2017 | Panasonic Televison & Video
Recently I turned on my TV and I have vertical white area with some lines that are colored on the left side of the screen. The rest of the screen looks fine.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 04, 2015 | Sharp Televison & Video
Why appear blue and black lines on my tv screen?
Feb 11, 2015 | LG Televison & Video
I have blue arched lines on my sony kp 57wv600 is there a fix for this
Those are retrace lines, the screen controls which are a technical control located under the front gray panel of your tv needs adjusted. This also could be an indication of a bigger problem, most common would be the focus block failing. it could also be of the picture tubes failing but this is not as common or possibly the crt driver ic's. There are specific diagnositc steps to preform to isolate the potental failure. this could lead to the tv going very bright then shutting down.
The first thing a tech is going to do is to adjust the screens and leave, somtimes this is enough, but sometimes it is not. if you want to try and adjust the screen i have an instruction set below, but i must warn you that there are high voltages present when attempting this adjustment and can be dangerous if you are un familure with tv repair.
Turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
Aug 05, 2009 | Sony KP-57WV600 57" Rear Projection...
There are faint lines at the top of the screen when the TV is on.
There are capacitors in the set's vertical output circuit that need to be replaced. TV repairs should be handled by a professional because of the hazards involved, particularly with larger sets. This is a pretty minor repair, probably under $100.
Apr 23, 2009 | JVC AV-32D305 32" TV
Faint red curved lines on Sony KP 51ws500.Converged = no work???
Hi There!
This sounds like a typical problem related to a older CRT.
If you remove the front cover of the tv, you can then remove a wood panel. Behind this panel you will see a block (high voltage splitter) it will have 6 "knobs" on it, 3 will say focus, 3 will say screen.
They will also be labeled R - G - B
Put the tv on a blank input so you can see the lines clearly on a black screen  - Find the knob for red, and SLIGHTLY turn it down until the red lines disappear.
Dec 22, 2008 | Sony KP-51WS500 51" Rear Projection...
Lcd black while in picture taking mode
Your ccd appears to be bad. Canon USA will repair this for free. Go here for details. They will send you 2 emails. One with the UPS label and another with info sheets to be sent with the defective camera
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
May 28, 2008 | Canon PowerShot A75 Digital Camera
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Mitsubishi VS-45607 45" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
