Question about IBM ThinkPad T22 2647 Notebook
Cannot find server
Have acer aspire1 on linux notebook was working fine 1 day then the next would not connect to internet, tried to go to networks to check set up but nothing there at all any ideas ???
Why wont my acer netbook allow me to enter the network centre or to connect to virgin internet either wired or wireless. i'm running linux lite not windows
go to the command line and type ifconfig
find the network adapter you are trying to connect with likely eth0 or eth1 if ethernet or wlan0 for wifi
then type
dhclient wlan0 (or whatever adapter you're using.)
if this doesn't give you an ip address, the virgin internet access point may not play nice with linux.
Mar 02, 2011 | Acer Aspire One Netbook 8.9" Notebook
My acer 5520 will not allow me to access the internet via wifi?
1)Turn ON the wireless feature on your laptop. It will be a combination of function keys.
2)Remove preferred networks
3)Assign DNS server address manually in Wireless Network Connections Properties
4)Try to scan for wireless networks in range now with/without security
5)Try Internet explorer, else mozilla firefox, else google chrome.
It will surely go online wireless
Jan 17, 2010 | Acer Aspire 5520-5908 Notebook
Acer linux internet connection problem
open a terminal windows type the following:
tell me what you get.
also try to disable the connection and then reenable the connection. I doubt that the manufacturer sells a linux system withe the drivers fully installed.
Mar 20, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire one - network connection problems.
Open terminal, and type, server networking restart let me know if this solves it.
Feb 23, 2009 | Acer Aspire One PC Notebook
All internet connections failed with Acer Aspire One with Linux
Atheros AR5007EG adapter only WEP compatible. Wireless networks using WPA(2), or anything else won't work. If network is unsecured, it should connect.
Dec 30, 2008 | Acer Aspire One AOA150-1570 Notebook PC
Internet connection problems
We have been made aware of the network icon issue in Linpus Linux , and have been provided with a temporary workaround, while the software vendor investigates this issue. Please follow the steps below:
1. Open the terminal by "ALT+F2" and then type "terminal" ->Run.
2 Run "mv ~/.gconf/system/networking ~/" to clear all the root network connections.
There is one space between mv and ~ and one space between networking and ~
After doing this, it will not have "ANY" network connections that may have been previously setup in network manager.
Reboot the unit and the network icon will appear. You will need to configure your network again.
Please advise if this is useful or not.
Dec 30, 2008 | Acer Aspire One PC Notebook
Connection to the internet issue
When you boot it, does Linux find and attempt to configure the network card? You should see messages about it installing drivers for it while it's booting.
If it does install the network card, try opening up the eNet Management software. First, make sure your network connections are on.
If the LAN card drivers are loading as they should, go here...
for step-by-step instructions on creating a new profile. One caveat, I'm reading the manual from the Acer site, and I'm hoping the software looks the same for you as the pages look to me.
Post back with how this goes.
Dec 28, 2008 | Computers & Internet
I cannot connect to MSN Messenger on a new Acer Aspire1 netbook. It keeps coming up with Our Protocol is not supported by the server. Please help!
get your download from a different site
7.5 or higher
first remove windows messenger from control panel add/remove
then get your msn download from a different download site
Dec 26, 2008 | Acer Aspire 5050-3242 Notebook
Acer one not finding any server
Check the wireless card connections physically. I received a Aspire one that had a wire disconnected from the card itself. if that is in tack find out what driver you are using for your card using "lsmod" see if there are alternatives. Try a live boot USB linux and see if your wireless card functions under that if it doesn't it is hardware if it does it is software. I would switch to another linux like sabayon or ubuntu eeepc versions they function better. I run Sabayon on both of my netbooks. Ubuntu ha sbetter support though.
Dec 25, 2008 | Acer Aspire One AOA150-1570 Notebook PC
IBM ThinkPad T22 2647 Notebook Logo
62 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
