Question about Whirlpool Dishwashers
Whirlpool ADP 4508 water not circulating
Model ADP 4508 freestanding dishwasher. Fills but does not circulate water through the spray arms
  • 1462 Answers
SOURCE: dishwater fills with water, hot...but doesnt wash?
when in the wash phase, listen for a low hum near the wash pump. if you hear this it indicates the wash pump capacitor is faulty or something jammed in the pump.after that you will have to access the wash pump and check if there is any supply to it
Posted on May 04, 2007
  • 14 Answers
SOURCE: Whirlpool dishwasher model gu1200 not working
I checked. There is no sheet of any kind inside or below the door of my Whirlpool dishwasher.
In any case, opening up the non-washing washer revealed that the filter behind the chopper assembly was clogged with food. I cleaned it off, put the thing back together again, and it was washing dishes again, until about three days later. I took it apart again and found food clogging the filter behind the chopper. I thought the chopper wasn't chopping, so I replaced it. It was around $16. About three days later it wasn't washing dishes again.
Further examination (dis-assembly of the sump motor and impeller) revealed that the end of the impeller (which is designed to engage the chopper) had broken off, thus the chopper no longer spins with the sump motor. The impeller costs about $20 and isn't too hard to replace, as long and you keep track of what you've dis-assembled and put it back together in reverse order.
On whirlpool dishwashers, the sump motor drives the impeller (it's connected via the threaded end of the motor shaft) and the impeller, in turn, drives the chopper. The chopper you can replace from inside the tub, without removing the dishwasher from its home or taking apart the sump assembly. But save your $16, as that probably isn't what is wrong... The impeller, being screwed onto the motor shaft, requires complete removal of the dishwasher so that you can completely remove the base assembly that holds the motor assembly.
If you have a GU-series whirlpool washer, the tech manual can be found here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
It has complete instructions for the replacement of every part.
Posted on Dec 29, 2007
SOURCE: frigidaire fdb949gf dishwasher won't spray water from arms
I found on my first dishwasher the arm holes were plugged. I had to clean out each and every hole with a small wire. They would not even turn until I cleaned them God luck.
Posted on Jan 31, 2009
SOURCE: Dishwasher does not circulate water
I had a similar issue and it was the Motor Circulation Pump. Part #239144 @ Marcone Appliance Parts Center (860) 548-0080
Posted on Mar 03, 2009
  • 188 Answers
SOURCE: Hi I have a Kenmore model
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to because the door will be open, but if you feel more comfortable shutting off the power to the dishwasher, do so.
Posted on Mar 06, 2009
I have a Whirlpool dishwasher Type 583-1 Model WDT720PADM2. It is suddenly not washing or drying well. Leaving bits of food and layer of film on dishes/glasses. Soap is sometimes not dissolved.Help!
Assuming the machine fills and drains water ok, and is heating the water too, and you can hear the circulation pump running during the wash, the most likely problem is blocked jets in the spray arms. You have to remember that a dishwasher is NOT a garbage disposal unit, and plates must be scraped clean before they are put into the machine for a wash. Bits of uneaten food in the machine will clog the filters, coat the walls of the machine and work their way into the spray arm jets especially at the very ends. These end jets are the only reason the jets rotate, and if blocked the arm just sits still and poor washing results. Remove and / or examine the ends of the spray arms carefully - often fruit pips or pasta can be seen blocking the jets. Remove this with a pin and running water. Also then run a dishwasher cleaner through the machine, with No load in - do this regularly to reduce blockages and smells.
spray arms can be taken to pieces in most cases to clear blockages. Always use a top quality detergent in the wash for best results.
Feb 03, 2018 | Whirlpool Dishwashers
Aeg oko favorit 50500w water not coming in through spray arms
There are several reasons if spray arms doesn't spray water. First you need to check efficiency of circulation pump. If it works, then should check the turbine of circulation pump. Sometimes turbine blades can be broken and the pump does not produce enough pressure to turn the spray arms. Be sure to check that the filter is not clogged which can also causes same problem. Finally, check that the nozzles of spray arms are not clogged.
So, could be:
- motor circulation pump
- circulation pump
- filter
- spray arms
- electronic or power board
Dado
Jul 12, 2014 | AEG Dishwashers
DISHWASHER DOES NOT CIRCULATE WATER
It means the spray arm is not moving correctly. Or there is something blocking it. Make sure you don't load tall glass, large plate or cutting boards. There is no waste basket in a dishwasher, only mesh filters. Unfortuantely, all debris ends up in the motor/pump assy. They do have something called a macerator, which breaks-up large food particles. If this macerator is clogged, you will have to replace it.
Mar 10, 2014 | Dishwashers
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 | Dishwashers
The wash spray arms are not turning the water line is free and not pinched water is on wiring is right whats up model its a ldf7920st
This sounds like your motor is not circulating properly, this will cause the spray arms not to operate properly, or at all. Are you receiving any kind of error code on the display? Also, how far is the dishwasher filling up?
Mar 07, 2011 | LG LDF6920ST Fully Integrated Dishwasher...
I have a Vikin Dishwasher Model DFUD042 and the arms are not circulating water. When we start a cycle it drains previous water then fills it up after that it runs thought its regular cycle but the arms are...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
42gda
Apr 21, 2010 | Viking 24 in. Professional Series VUD141...
The dishwasher appears to not pump water through the spray arms. the nozzles are not clogged and both are not rotating. any assistance would be appreciated
what makes the circulation in the dishwasher? the circulation pump. just check the water going in and the water going out.
Mar 06, 2010 | Dishwashers
Kenmore elite dishwasher 665 purchased in 2001
Sometime objects tend to build up under the screen and around the circulating pump. These objects will block the water ports and cut the ability of the spray arms to rotate. If you are carefull you can disassemble the unit under the bottom spray arm and inspect/clean the screen and circulating pump.
Jan 10, 2008 | Kenmore 16872 Built-in Dishwasher
Dishwashers Logo
128 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
