Question about LG WM Washing Machines
Can't find the tub clean button in my lg front load washer WD14316RD
I cannot find the tub clean button on my lg front load washer
SOURCE: Moldy smell in front load kenmore washer
What you all are forgetting and I can vogue for this and prove it because we ripped our washer down......and I have pics... the mold will collect behind the SS tub in the plastic drum housing... every repair man told me NO POSSIBLE WAY!!!! well I was so sick of being sick and my husband decided time to buy a new washer we did and a (top loader i will add). and when the top loader was delivered we ripped the front loader totally apart (any one that would like to see pics you can email it) but be forewarned they are GROSS!!! I have done all the maintenance they have recommended and nothing helped (bleach, cascade, OXY, vinegar, leaving door open (which i may remind anyone is a risk if you have toddlers ) oh yes and lets not forget the washer magic they push down your throat to buy every time a sears tech comes out) I have a family of 6....4 girls and 2 of them babies so I have a lot of laundry....I will be more then happy to share what we found was hiding in the washer's this is not something you can see until you rip it totally down. CJ
Posted on Sep 26, 2007
jsrock516
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
jan mczeal
  • 632 Answers
SOURCE: LG Washer WM2455H Tub Clean Problem
Yes, it's normal. It is a safety feature because of the hot water used during the tub clean cycle. It prevents the machine from opening while the tub clean cycle is in process.
Posted on Jan 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: lg wm-2277hw front load washer getting a OE error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
When I push the tub clean button on my LG Washer WM2688H, nothing happens. How can I fix?
I would go to the LG website and look up the manual for this model. All of the 'push button' control panels have a particular sequence which must be followed in order for them to operate correctly.
Jun 13, 2014 | LG WM-2277HW Front Load Washer
I am trying to figure out JW's code to deep clean LG WM2301
If you cannot do it that way then toss a packet of Tide washing machine cleaner in there witout clothes and do the clean cycle as prescribed in the owners manual.
Nov 01, 2011 | LG WM2301HW Front Load Washer
How do I clean my washing machine? My clothes and the washer have a mildew odor.
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Aug 18, 2011 | LG WM-2277HW Front Load Washer
I have an LG WM-0532HW Front Load Washer. upon trying to fix a diffierent problem, something popped. I couldn't find anything broken. However, the inside metallic tub is not longer stable. During the...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jun 26, 2011 | LG WM-0532HW Front Load Washer
LG washing machine WM2277H tub off center does not spin electronically, manually its spins but rubs sides
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Sep 02, 2010 | LG WM2277H Front Load Washer
Oe error code, cleaned filter, checked hose
You might be using too much detergent and causing a sudslock condition. The machine uses very little water and any amount over a teaspoon of HE will simply cause the machine to lock down. An OE error means it took longer than 10 minutes to drain the tub. IF the machine is trying to correct a sud problem it will continually toss in more water till sudslock is corrected. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Jun 04, 2010 | LG WM2277H Front Load Washer
Our lg washer model wm0642hw tub clean cycle stops
software problem. regarding smell, after wash keep the door opened for ventilation, use fabric conditioner etc. also check whether any rodent has gone inside and messed up the place
Mar 18, 2010 | LG WM0642H Front Load
Jan 02, 2010 | LG WM2455 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
