Question about Watches
TAG Heuer Aquaracer WAF1010, second hand contacts hour hand and watch stop working every 3 days...
The second hand touch the hour hand, blocking the watch. This occurs every 3 days. Why this happens? Thanks
SOURCE: Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
Posted on Mar 17, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
escapement
  • 2334 Answers
SOURCE: I own a tag heuer
Yes it is correct as your watch has a counterclockwise crown forward setting direction. This is due to the specificaly layered lever and setting gear construction, so, nothing wrong with your watch.
Do not forget to rate, please.
Posted on Jan 27, 2009
escapement
  • 2334 Answers
SOURCE: My tag heuer aquaracer has a problem: the second
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4-5 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Posted on Mar 11, 2009
dmbgo
  • 58 Answers
SOURCE: can't change time on tag heuer aquaracer 300 meter
Hi please make sure that the knob is pulled all the way out. If it is you need to take it to a watchmaker.
Cheers
Dave
Posted on Jun 22, 2009
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    How to reset the chrono function of a Tag Heuer Aquaracer Calibre S CAF7113.FT8010 after a battery change
    Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works..
    Jan 17, 2014 | Tag Heuer Aquaracer Calibre S...
    I dropped my aquaracer watch on the ground from 2 feet high. hour and minute hands not moving but the second hands working fine. please help!
    You need to go to a watchmaker. Sorry, I am good but not good enough to diagnose the damage without seeing the watch. In any case you can't fix yourself unless you are a watchmaker.
    May 24, 2011 | Tag Heuer Aquaracer Quartz Chronograph...
    I have a Tag Heuer Monaco watch. I has 2
    The small seconds hand do not stop because it has nothing to do with chronometer. It is ordinary seconds counter and will move independent of chronometer.Click on my profile (escapement), then click on Tips and Tricks. There you will find link to Tag Heuer watch manuals. It might lelp you. Rate me, please
    Mar 31, 2010 | Tag Heuer Link Automatic Chronometer...
    Sweep second hand does not return to 12 o clock position, few seconds out
    Click on my profile (escapement), then click on Tips and Tricks. There you will find links to TAG HEUER watch manuals.Rate me, please..
    Mar 29, 2010 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
    Tag Heuer - Aquaracer automatic (Day/ Date)
    Actually in the realm of things that is close to midnight. But if you want this changed you will have to take it to a watch repair person because the movement will have to be taken out of the watch and the hands pulled and rest to change when the calender flips over. When I set up watches i usually have the day/date flip after 2 am so that most people never see it change ( because they are asleep lol)
    Jul 31, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
    What type of swiss quartz movement is in a tag heuer aquaracer waf1010 ba0822?
    ETA or F0 movements are usually tags number 1 choice of movements.
    ETA G10.711
    Jul 13, 2009 | Tag Heuer Watches
    Date change on my Tag Aquaracer Calibre S
    Do as follows:1) At any time of the day pull the crown out and advance watch hands forward for EXACTLY 12 hours ( for example: if it's 6.35 on your watch, then after advancing hands it will be 6.35 again, just minute hand will be forwarded clockwise 12 full circles, while hour hand will be forwarded 1 full circle). Push the crown back in.
    2) Pull the crown out to the date setting position and change to the desired date. Pull the crown back in.
    Now your watch will be changing dates at midnight continuosly.
    Rate me, please.
    Apr 06, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
    My tag heuer aquaracer has a problem: the second hand stops and then speeds up really quickly for about 5 seconds. any idea why/how to fix it?
    Mar 11, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
    Watch second hand
    I had the same problem with my Tag. Same 4 second jump. It's definitely the battery. I'm surprised at only 3 months, but maybe it sat a while in the display case. Mine was over a year and a half.
    Feb 16, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
    Watches Logo
    16 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
