Question about HP Compaq d530 SFF PC Desktop
Hp compaq d530 make five beep and red light. ichange ram but no result. i change powersuply but sam beep
  • HP Master
  • 27,725 Answers
Diagnosing problems with your computer can be difficult, especially if you do not have any visual cues to guide you.
Fortunately, computer makers, like Hewlett Packard, make the job easier by using beep codes that computer owners can use to determine the source of the problem.
By carefully listening to these beeps, computer owners can find the malfunctioning piece of hardware and resolve the issue.
Look for the user guide that came with your computer.
Having the user guide available will make it easier to track the meaning of the beep codes.
Most HP user guides have a section covering the various beeping patterns and what each one means.
Start your computer and carefully listen to the beeping.
HP computers use both long and short beeps, so listen carefully to determine whether each beep is short or long.
Shut down your computer and restart it.
Listen again to the beep codes to be sure which pattern you are hearing.
Write down the beep pattern and compare it to the beeping patterns listed in your HP user guide.
Restart your computer again and look for any messages on the screen.
Depending on the nature of your problem you might see visual clues, or the screen might remain blank.
Check the status of the LED lights on the front of your HP computer as it is starting up and giving its beep codes.
For instance, a red LED light often indicates a faulty memory module or an overheating processor.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in
Test all power and data leads that attach from motherboard to your hard drive IDE SATA
make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat 40 pin ide it will be the first to fail
check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it
restart your computer the found new hardware wizard should activate
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
make sure all leads that are attached to your drives dvd\cd and floppy drive have secure make sure the connections and are not faulty or just replace them they could be faulty
a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error
also check the keyboard for secure dust free connection ps2 and or usb
also check the CPU central processing unit for secure dust free seating and thermal paste
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
Posted on Oct 31, 2012
SOURCE: 5 beeps HP Compaq d530
I'm having the same problem....... I don't think I've added any memory to it.
How do you fix if it's motherboard problem
Posted on Apr 26, 2008
SOURCE: HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS.
thats a sign of bad ram you will have to udate your ram
Posted on Dec 26, 2008
abhi_patil
  • 568 Answers
if it is a long beep then check ur ram, try cleaning ram. if not solved then there may be problem with ur ram try changing ur ram.
if it is short beep and if you have a display card installed check the display card
Posted on Dec 27, 2008
buffalonyman
  • 1865 Answers
SOURCE: ethernet driver for hp compaq d530
Drivers are located here: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
You must select the appropriate operating system for your application
Posted on Apr 25, 2009
  • 1479 Answers
SOURCE: I have a hp compaq dx6100mt that doesn't boot and
you can get an idea of the problem here http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bph07107
from a cursery look over the page it could be hat the laptop has died. might be worth taking the memory out and reinsert it but from experience it's probably dead.
Posted on Apr 02, 2011
When i pushed the power button it make a beep sound and a flashing red light and pc will not boot.
Please try to clean & re-seat or change your memory RAM and try to turn ON again.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jul 20, 2011 | HP Compaq d530 SFF PC Desktop
Unable to power on computer
When you here this signal sound beeping this is an RAM memory error. Try to open your CPU casing and remove the RAM, clean the RAM with rubber eraser.
After that insert the RAM and try to turn on the unit. Once you can hear again the loud sound beeping the RAM are bad or faulty already. So you need to replace the RAM.
Jul 25, 2010 | HP Compaq d530 SFF PC Desktop
Short beep and red light
Did your Bios Battery Die?
5 short beeps = BIOS recovery successful
Usually means bios has lost settings some how. You have have more significant issues if there was a power surge.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07107
Jan 02, 2010 | HP Compaq d530 SFF PC Desktop
Won't boot. Series of Beeps plus red light
If nothing was displayed on the monitor during the beeps then change the RAM stick(s)
Thanks
Oct 29, 2009 | HP RT935UAABA - HP Compaq dc7800...
There are two lights right under the turn-on bottom and one has a picture of a battery and the other is a picture of a light bulb and this light bulb is blinking red five times in about 3second intervals.
the blinking bulb is the speed or the utility of the ram memory ....if it is blinking then it means that ur pc is utilising memory of ram....if it blinks faster then its using more memory....
Jul 17, 2009 | HP Compaq d530 PC Desktop
4 beeps & 4 flashes mean problem with the power supply. For my experience, most of the time the PSU is good, it is just overloaded.
For more LED and Beep messages, check this link:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00067072/c00067072.pdf
Dec 26, 2008 | HP Compaq d530 PC Desktop
Won't turn on blinking red where green power lights should be.
plase open the cpu & plug in the ram in the right order.
Dec 10, 2008 | HP Compaq d530 PC Desktop
5 beeps
do you have the RAM chips installed in the right socket, and the right way?
Aug 09, 2008 | HP Compaq d530 CMT PC Desktop
HP Compaq d530 SFF PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
