Owners manual for MB-130 data bank - Audio Players & Recorders
Where can I find the owners manual for the Schwinn 130 model stationary bike?
Schwinn has the manuals for most of their bikes here: http://www.schwinnfitness.com/schwinn_fitness_us/customerservice/manualsen.jsp . There are three Model 130 upright bikes listed. Do you know what year your exercise bike was built?
The Owner's manual for the 2007 model is currently here: http://download.nautilus.com/supportdocs/OM/Schwinn/SCH_130-230_OM_RevB_web.pdf . The assembly and owner's manual for the 2016 version is here: http://download.nautilus.com/supportdocs/AM_OM/Schwinn/SCH.130.MY16.AM-OM.WARR.EN.pdf .
I hope this helps.
Mar 30, 2017 | Schwinn Motorcycles
I am having Intel Board SE7501BR2, i wanted to know how much RAM does it support and of what speed, because currently it is having 512 mb ram with speed of DDR$266 mhz.
This motherboard can support up to 2Gb of DDR266 RAM modules.
Attached is part of the memory detail from the manual.
If you need a copy of the manual. please click on this link to download :-
ftp://serwery.optimus.pl/Servers/Motherboards/SE7501BR2/Dokumenty/se7501br2tps.pdf
3.1.2.2 Memory Configuration
Memory interface between the MCH and DIMMs is 144 bits wide. This requires that two DIMMs
be populated per bank in order for the system to operate. At least one bank has to be populated
in order for the system to boot. If additional banks have less than two DIMMs, the memory for
that bank(s) will not be available to the system.
There are two banks of DIMMs, labeled Bank1 and Bank2. Bank1 contains DIMM locations
DIMM1A and DIMM1B and Bank2 contains DIMM2A and DIMM2B. DIMM socket identifiers are
marked with silk screen next to each DIMM socket on the baseboard. The sockets associated
with any given bank are located next to each other.
The baseboard's signal integrity is optimized when memory banks are populated in order.
Therefore, DIMM Bank1 must be populated before Bank2.
DIMM and memory configurations must adhere to the following:
• DDR266 DDR registered DIMM modules
• DIMM organization: x72 ECC
• Pin count: 184
• DIMM capacity: 128 MB, 256 MB, 512 MB, 1 GB, 2 GB
• Serial PD: JEDEC Rev 2.0
• Voltage options: 2.5 V (VDD/VDDQ)
• Interface: SSTL2
• Two DIMMs must be populated in a bank for a 144-bit wide memory data path
• One or two memory banks may be populated
Table 2. Memory Bank Labels
Memory DIMM Bank Row
J8D22 (DIMM 1A), J8D15 (DIMM 1B) 1 0, 1
J8D7 (DIMM 2A), J8D1 (DIMM 2B) 2 2, 3
Note: Memory must be installed in pairs; DIMM Bank1 must be populated before DIMM Bank2.
Memory within a DIMM bank must be identical; between banks only the DIMM size may be
different.
Functional Architecture Intel® Server Board SE7501BR2 Technical Product Specification
26 Revision 1.2
Intel Order Number C13977-003
Figure 3. Memory Bank Label Definition
Sep 25, 2010 | Intel Server Board SE7501BR2 Motherboard
I change the memory banks (from 256 meg 533 Mhz X 2 to 1024meg X 2) and the bios just see the first bank. I flash the bios with the latest file but the issue are the same. Is there something to verify or...
Did you check and make sure it can handle more than a gig of memory? Does it have 4 banks? A lot of newer motherboards need to have memory paired in the banks.
Apr 19, 2010 | Intel D102GGC2 Motherboard
Where can I get the manual for honeywell hfd 130 air purifier?
Hello, this is Ava with Think Crucial.
Please refer to the link below for the Honeywell HFD-130 online manual:
Honeywell HFD 130 Owners Manual
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 28, 2010 | Honeywell HFD-130 Air Purifier
User / owner manual = HP Photosmart 130
Please click the link below to go to the manual download page for your printer:
HP Photosmart 130 manuals
Mar 24, 2009 | HP PhotoSmart 130 InkJet Printer
1994 saturn owners manuels
Hi there, i have prepared you a link to a great data bank full of download manuals(car manuals).
Click here for the site.
Just type your car model/year in the search engine and, download your manual. Please rate my response if possible. Thanks for using Fix ya:)
Feb 26, 2009 | 1993 Saturn SW1
Gateway sb-4100-b won't recognize new memory
Check the owners manual of your computer for the correct installation of 2 sticks of memory, this can be critical on computers with 2 banks of 2 slots, it will also tell you the maximum ram that will work. If you do not have the manual, go to the manufactures website and then go to the support link, and browse for memory installation. BPCS
Dec 28, 2007 | Gateway Sb-4100-A PC Desktop
Owners manual
Unfortunately this is a purchase site. The closest I could get would be for an Activa 220 230 240 . You can download the manual.
Check the picture on no. 7 and see if this isn't your machine.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Bernina.htm
Hope this helps. Luck!
Dec 20, 2007 | Bernina Activa 130
49 people viewed this question
 Grubhead
Grubhead
