Question about Ovens
We have a eurolec tecnogas oven model 35605506 and we cant get the glass to stop springing off when we close it, any ideas?
  • 87 Answers
SOURCE: Oven door does not close
One of the springs fell off or the door hinge assembly sprin out.
Posted on Jun 10, 2007
SOURCE: Broken outer panel of glass on cooker door
I found a replacement for my oven on ebay. Be careful, though, because one seller offered one that was the wrong size.
Posted on Jun 02, 2009
SOURCE: I need a user manual for my tecnogas oven and
how to operate tecnogas built in oven
Posted on Nov 06, 2009
  • 1531 Answers
SOURCE: Wall oven door hinge springs
YOu will have to replace the door hinges.The part number you will need is 318024714 should run about thirty dollars for the set.
Posted on Dec 14, 2010
SOURCE: oven door springs won't close door properly
get an engineer to change the springs for you.
Posted on Dec 15, 2011
How to bypass broken clock on eurolec 720ef electric wall oven
If you bypass the clock, how will you maintain a steady temperature, include safety features, or program functions?
What you seem to want is an outdoor grill. DO NOT bypass the logic board on your oven, sir. Help Me Find My Model Number RepairClinic com
Jun 14, 2016 | Ovens Ovens
Where can I obtain an Instruction manual for a Eurolec built under oven with grille?
Looks like the support is overseas. However they do have email support. If I knew the make and model I might be able to obtain more information. Otherwise here is the email link for support:
Reception@Eurolec-Services.co.uk
Jul 02, 2015 | Ovens
Does a eurolec gas oven model 8650g6gxbct have a fan in the oven
open the oven door and look for a fan hole and fan in the back wall of the oven
Jun 13, 2015 | Ovens
Hi the right hand hinge of the door has popped out whilst I was trying to move the oven using the door handle as leverage. The door is now wonky when closed as the hinged has popped out. Help!
All oven door typically lift off the hinges by design. If you open the door to what is referred as the broil position. You know when the door stops about 4 to 6 inches open at the top. Then do the following.
1. Lift the door up completely off the opposite hinge still in place and remove. Set the door aside carefully as if has glass window, you do not want to break.
2. Then set both hinges at the broiler stop position. If one is all the way in to door fully closed position pull it out with your hand or with pliers till it stops @ broiler position. If all the way down as if door was fully open, lift hinge until it stops at broiler position. CAUTION- THE HINGES ARE SPRING LOADED AND CAN SNAP BACK INTO FULLY CLOSED POSITION. You can use a heavy glove or if you have an oven mitten, that can work to protect your fingers. DO NOT GET YOUR FINGERS BETWEEN HINGE AND OVEN OR CAN PINCH FINGERS.
3. Now carefully lift the door over the hinges set at the broiler position. Careful not to bump them when doing so or can snap closed. If does, reset hinge to broiler position and repeat. Works best to hold door at angle that door is when in broiler position. Once you have them started evenly, you should be able to fully slide down back onto both hinges.
4. If one of the hinges no longer has spring tension you have to reattach the spring. You can usually access spring if needed by removing the bottom drawer.
Aug 27, 2011 | Ovens
My eurolec oven is letting the heat out and burning the cupboards
check that the fibre glass is still in place and has not been soacked with water, you can get some fibre glass from your local stores and wrape it just after openning the couvers and puting them back to place
Aug 02, 2010 | Ovens
I self cleaned the oven for 4 hours and it worked great. I decided to take the front glass off to clean inside it. it was quite dirty inside and the self clean did not effect it. Once I put everything...
The procedure to Disassembling the door is as follows:-- 1. Set the oven door wide open. 2. Lift the hinge jumpers with your thumb and index fingers, then turn them fully outwards to the end of stroke. 3. Turn the door towards the closure position and lay it on the jumpers: in this way the hinge's spring is blocked. By fully closing the door the hinges are unhooked from the connection slits which are integral with the oven muffle. 4) Re-assemble the door by carrying-out the aforesaid operations in the opposite order. Disassembling of the door glasses:-- for your safety, before removing the glasses you should remove the oven door. To facilitate the cleaning, after having removed the door from the oven, you can proceed with the disassembly of the glass. Release the two upper blocks so that the glass can be removed. After the cleaning you should reassemble the glass, replace the blocks and lock into position. Check that all components have been assembled correctly and than you can re-assemble the door onto the oven. check fig:-- For more help click this link directly. The model and brand is different in the picture but the procedure to assemble the door is similar to your model http://www.partselect.com/ModelFrames.aspx?ModelID=1015781&ModelNum=plef398aca&ManufactureID=4&Selected=QN7WQCV6&Position=1&mfg=Frigidaire&Type=Appliance&Mark=3 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 13, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Nov 04, 2009 | Ovens
Apr 01, 2009 | Ovens
May 04, 2007 | GE JT912SKSS Electric Single Oven
Ovens Logo
73 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
