Question about Generac Electrical Supplies
Generac svp-5000 spark plug
What spark plug to use
3 Suggested Answers
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
mamicheddy
  • 79 Answers
SOURCE: no electrical output
It is possible that your voltage regulator is shot but before purchasing the volt regulator try flashing the fields first and make sure the brushes and rings are clean.
Posted on May 12, 2009
Replace the carburetor on a Generac 5000 generator
Have spark? Did you adjust the idle and mixture screws on carb after installation. - that has to be done. Also check coil - common nuisance item.
Sep 01, 2017 | Cars & Trucks
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
I have a generac mc alternator model -38 6938 my voltage pulsates underamload just started any ideas
Cleaned and adjust carburetor per Repair Manual. then adjust governor repair manual and should take care of problem on this old generator.
https://www.generator-parts.com/manuals/generac-rv/051834.pdf
Jan 07, 2015 | Generac Electrical Supplies
Why centurion 5000w generator has no spark
change the cdi on the motor sounds like it is fried
Jun 08, 2014 | Generac 5622R GP5000 GP Series 5000 Watt...
Generac mc-35 wont start no spark at plug
make sure magneto is VERY close to the flywheel. Like, two pieces of paper close.
Mar 26, 2014 | Generac Electrical Supplies
Cranks fine then dies out
check for spark when it cuts off also check the oil level some have a low oil shut off also dry and run it with the gas cap loose to see if the vent is plugged
Sep 01, 2012 | Generac 5622 portable generator,5000 rated...
Generac ix 2000 does not start. checked spark plug and it is good. oil good.
what a **** generator, worked for 100 hours and now wont start anymore.
did all the checks and replacing of spark plug and oil etc, simply wont start, ****, ****, ****..... service is horrible too. they just give you the runaround.
Apr 02, 2012 | Generac Power Systems Generac 5793 Ix 2000...
May 08, 2009 | Electrical Supplies
No electrical output
Feb 13, 2009 | Generac Guardian 065795 - battery charger...
Electrical Supplies Logo
76 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Don  Farrell
Don Farrell
Ottoniel
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
