How to reset channel - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
This will vary from set to set but basic: Enter main menu with remote and select cable or air/antenna and then look either for auto program and run or direct enter channels and add them one at a time.
Posted on Oct 30, 2012
My Emerson TV is stuck on number 1 channel how do I get it to go to other channels?
Need to go into the menu look for the channel setup then check the skipped channels make sure channel 1 isn't the only Channel not checked also Look at Your scanned channels in the channel list how many do you have is channel 1 it ? you may need to rescan your channels . If the TV worked OK before but Not now try resetting Your TV , BUT do this last as You will need to reset all the parameters in Your initial setup as well as rescanning channels also the Volume may blast you after reset I always install a set of earphones in the Audio phone jack first . To reset the TV Unplug it from the back of the set wait 30-40 seconds reconnect the plug while holding the Power Button Reset Your Options and Settings then Rescan your channels Don't forget the volume and to unplug earphones Good Luck
May 18, 2016 | Emerson Televison & Video
Tip
Toshiba 42HP95 Channel Block Reset
Toshiba 42HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Tip
Toshiba 50HP95 Channel Block Reset
Toshiba 50HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV channel block?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
How do I get my local channels back after pushing reset and auto channel scan?
and what was the point of factory resetting .check input setting it has to be air or antenna
Apr 27, 2015 | Televison & Video
How do you reset the LG DRT389?
to reset hit eject on the machine and the blue text button on the remote for 5 secs
Jun 24, 2010 | LG Cell Phones
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
Sony KDL-32S2010-Chicago area..channel 50.1 (WPWR) is now showing up on 51.3.(found it by accident). 50.1 showing spanish shows. Reinitiated auto tune erased all channels without antenna, then auto tune...
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mar 27, 2017 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Sansui TVM1300 13 inch TV - Set Auto Channel does not work. I go into the Menu and start Auto Channel and it does not find any channels. Yet I can manually enter the channel number and it will go to that...
Sounds like AFT, AGC voltages are not proper. Contact any service technician. The main board of your TV has to be troubleshooted.
If the main system control memory IC is bad, this kind of fault can occur. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
May 19, 2017 | SansuiS3275 TV
Need channels reset
If you do not have a replacement remote and their is no menu button on the tv then you will have to do a hard reset.
To do this you will have to unplug your tv and all connecting components until such time that the tv is reset. You will know it is reset when the tv asks you when you turn it on to run a channel program.
Good luck.
CH
Jul 29, 2008 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
