Question about Jenoptik JD 3.1 Digital Camera
Jenimage jd 3.1 - Jenoptik JD 3.1 Digital Camera
Something you obviously know nothing about
the real experts on jd combine are the jd technicians so why are you on fixya site to get information
Jun 18, 2017 | Cars & Trucks
Engine turns over and getting fuel, put has no spark on JD 322
check for cracks in the spark plug wire it sounds like it is shortening out or a ground wire.
Mar 01, 2010 | John Deere &Reg Branded 27" Tractor Metal...
09 JD X 340 27hp Kawasaki eng\ surges
Hi
That is a fuel problem caused by stale gas you will need to remove and clean the carb with carb cleaner.
Sam
Jan 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My JD riding mower just stopped during a recent mowing
There was a time when my JD just quit and did nothing. After doubting the battery that is what it was-the battery. Jump start your JD and if it starts up then your battery needs replaced.
Oct 20, 2009 | Garden
I have jwin jd-vd503 it does not work it shows
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
  1. (Open the disc tray)
  2. Press SETUP
  3. Press 1, 3, 6, 9
  4. Press LEFT 3 x
  5. Press RIGHT
  6. A new menu entry appears (Version)
  7. Select it and select RC (0=codefree)
Sep 15, 2009 | Jwin JD-VD502 DVD Player
Won't play DVDs from asia .. need region code unlock.. help.
1- Open tray
2- Press setup
3- Press 1 3 8 9
4- Use Up/Down key from remote control to change the Region
5- Press setup
Apr 03, 2008 | Jwin JD-VD135 DVD Player
Nesesito un codigo para un dvd marca jwin grasias
Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Jenoptik JD 3.1 Digital Camera Logo
Top Jenoptik Cameras Experts
Are you a Jenoptik Camera Expert? Answer questions, earn points and help others
