My Technika TV model X22/14C-GW-TCD-UK loses all of its channels when I turn it off. I have to retune everytime I turn the TV back on, Any Ideas welcome, many thanks
Model X22/14C-GW-TCD-UK
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
All sets use a eprom in some form or another that stores the memory of what up/down channels are programmed into the memory of the set-I will presume no box is used in line with this set for signal---very rare for this problem to even happen---next try when turn on to direct enter a known channel and see if set goes there--then manually add it in the menu---if set does not lose that memory at worst you can manually add every channel one at a time.
Posted on Oct 30, 2012
57 varieties
  • 1653 Answers
SOURCE: Tuning problem
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Posted on Oct 03, 2009
SOURCE: I have a E22/13B-GW-TCD-UK logik
Typically you will not need a driver to use any monitor. Ensure that the monitor output of your computer is compatible with the video input of the television.
Posted on Mar 05, 2011
gopakumarg43
  • 74383 Answers
SOURCE: remote control code for technika
Hello
Three digit universal remote codes for Technica are:
000/ 001/ 004/ 005/ 008/ 009/ 013/ 042/ 046/ 053/ 058/ 076/ 105/ 109/ 170/ 174
Four digit universal remote codes for Technica are:
0031 0004 0005 0009 0051 0053 0105 0109 0170 0000 0174 0001 0008 0012 0042 0058
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
CODE SEARCH METHOD
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
Posted on Jun 12, 2011
  • 55 Answers
SOURCE: i have lost the remote
try
www.genuineremotecontrols.co.uk
or genuinecopies
Posted on Jun 23, 2011
vko007us
  • 254 Answers
SOURCE: hitrying to use AGK10133 PO4332
one remote can not be use for the different company TV
Posted on Aug 16, 2011
Hi I have a one for all remote but I need a code for my umc combination tv/DVD -model L22/01c-TCD -uk ..can't seem to find it anywhere ..appreciate any help thx
0382,0483,0481,0485. Check these codes. If you wish to get more codes with different brands of remote controls, check this link.
Feb 23, 2013 | Televison & Video
Can I replace the power supply in the TCD 540080 with one from a TCD 652160
Most likely not. What you can do is call Allied Electronics and they should be able to cross reference for you and let you know if they have the same outputs or if they have a replacement.
Feb 10, 2013 | Tivo Televison & Video
Technika tv code for a universal remote?
Hello
Three digit universal remote codes for Technica TV are:
Four digit codes are:
OK.
Nov 22, 2011 | Televison & Video
I have a E22/13B-GW-TCD-UK logik television that I want to use as a monitor for my computer. Do I need a driver?
Mar 05, 2011 | Televison & Video
F17 flashing
Ok, here is the service manual for your unit.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Dryers/TCD970P-19506725900_UK.pdf
This is a company out of the UK. I'm not sure if they have a number here in the us or where exactly you are located. If you are in the UK, I have included a link for you.
http://www.hotpointservice.co.uk/hs/pages/index.do
Apr 10, 2009 | Dryers
Sony Walkman TCD-D100
I have a faulty one as well, mine chews tapes, Sony has quoted me $500 to fix it. I can get a 2nd hand one for half that. If anyone has any suggestions re: fixing it cheaper, please email me at spin_orbit@hotmail.com
Apr 06, 2007 | Sony Walkman TCD-D100 Personal Cassette...
Televison & Video Logo
318 people viewed this question
Top Televison & Video Experts
Electro Med Services...
