Question about Samsung NX10 Digital Camera
Broken plate samsung nx 10 18-55 lens Plate to click lens into camera has 2 broken feet and will not connect with the camera, this clip can be screwed off the lens and is only a couple of mm's thick
Www.flex-007.com offers a replacement for nx 18-55 for $20. It'll take 10 minutes to replace though;)
Posted on Mar 29, 2013
2006 Tahoe. Where is the auxiliary blower motor located?
It is located behind the right rear quarter panel , In the back right of the interior !
Remove the right rear quarter trim panel. Refer to Rear Quarter Trim Panel Replacement - Right Side in Interior Trim.
Removal Procedure
  1. Remove the rear seat. Refer to Rear Number 2 Seat Replacement or Rear Number 2 50-50 Seat Replacement in Seats.
  2. Remove the Third Pillar trim panel. Refer to Third Pillar Trim Replacement .
  3. Remove the garnish molding. Refer to Body Rear Corner Garnish Molding Replacement .
  4. Remove the door sill plate. Refer to Liftgate Door Sill Plate Replacement .
  5. Remove the quarter panel trim screws.
A lot involved in this but not to difficult !
  1. Remove the rear door sill trim plate. Refer to Front Side Door Sill Plate Replacement or to Rear Side Door Sill Plate Replacement .
  2. Remove the lower rear seat belt cover and bolt.
  3. Remove the trim panel from the vehicle.
Remove the sill plate. Firmly pull the sill plate up and out from the retainers.
Remove the sill plate from the vehicle. Start from the front of the door sill. Use a flat-bladed tool in order to pry the door sill plate.
Rear Side Door Sill Trim Plate Replacement
Use a flat-bladed tool in order to pry the door sill plate. Remove the sill plate from the vehicle.
Remove the rear upper garnish molding. Refer to Rear Upper Garnish Molding Replacement .
Pull down on the upper corners of the garnish molding in order to disengage the retaining clips. Pull in order to disengage the remaining retaining clips. Remove the rear corner garnish molding from the vehicle. Inspect the rear corner garnish molding for broken or missing retaining clips. Replace the retaining clips as needed.
Good Luck ! Fun job !!!!!
Jun 07, 2015 | 2006 Chevrolet Tahoe
Hello! I have a Samsung model S730 that will no longer turn on. It actually occurred while my wife had it so I don't know what might have preceded this, but the lens is in the extended position, the...
I'm thinking this camera was drop thats why this problem is happening, and this can be a mechanical problem inside the camera that some of its parts is loose now that's why it wont even power ON and the lens is not retracted and in fixing this the camera should be taken apart , but if the camera is still under warranty better take it to a service center or have it replace....
Hope that helps.........
Sep 30, 2008 | Cameras
How do i eject the cd from my samsung all in one
There are two ways you can do this.
option 1
1). Go into file manger or File explore.
2). Click on my PC or This PC.
3). locate the CD rom Icon for the drive you wish to get into.
4). right click on The CD rom drive Icon.
5). Click "EJECT".
Option 2
1). Get a paper clip. bend it in to a letter L shape.
2). on the CD drive face plate there should be a small hole. NOTE: Not the LED / LIGHT.
3). Insert the paper clip into the hole. While keeping the clip straight give it a small push and the tray should open.
Mar 09, 2015 | Samsung All-In-One Computer / Intel Core...
Mount broke won't attach to camera, where can I get replacement part?
dolphindaddy,
I have the same problem. (I call it a broken rear lens plate.)
I purchased the Nikon for this same size. However, I like the Sigma lens so much more. I can hardly wait to get it back onto my camera.
BobofOrd
Jan 09, 2011 | Sigma 28-80mm Mini Zoom Macro Lens
Nikkor Lens Cannot Manual Focus
It sounds like you had the lens set for manual focus when you took the A / M switch plate off. If this was the case then when you but it back together the little arm behind the plate is on the wrong side of a moving gear assembly.
To fix, remove the auto/manual focus switch plate from the camera (just the one screw not the ribbon beneath) Push the switch over to A. Hook the bottom of the plate back to the lens and put the screw back in. Done!
Jul 26, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
How to open Top-plate of Pentax MG
Sounds like the pressure plate for the viewfinder lens has dropped in front of the lens. If the viewfinder surround is craked this is very likley.
To learn how to remove the top of these cameras and other Pentax's there is a camera repair website where you are shown how to do this. Just click the link.
Nov 29, 2008 | Pentax ME Super 35mm SLR Camera
Lens not going in & getting stuck
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Samsung S760 Digital Camera
Samsung digimax s700
TIPS:
..to fix this...
Do as i say..
1.) Remove battery
or...
or...
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Samsung Digimax A400 Digital Camera
Bogen Manfrotto 3047 head
Dear spiderinkart,
To get the camera to secure properly to the release plate make sure that the bolt is screwed entirely into the camera bottom and then there should be a larger knob that rotates around the bolt that tightens down to the camera body. What I do to get a really tight fit is point the arrow on the bottom of the release plate labeled lens (that arrow when properly mounted should be pointed towards the front of the lens) to a 45 degree angle to the left of the lens, then I snug down the knob, and then I grab the release plate and turn it until the lens arrow is aligned with the front of the lens. As far as quick releaseing the camera from the legs when secured on the release plate you should be able to pull the lever away from the head and it should simply release the camera with the plate attached.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Mar 16, 2008 | Bogen Communication Bogen Manfrotto 3047...
Samsung NX10 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
